Anything wrong with a high idle?
Old Aug 30, 2015 | 12:34 PM
daboy155's Avatar
Default Anything wrong with a high idle?
I have a light flywheel built engine /turbo bigger cams and had some issues with the car rpms dipping and catching too low right as it would almost stall every time, I put the idle to about 1300 in hondata, problem solved, gives it an extra buffer to catch itself and it runs great. Anything problematic with having the idle that high? Thanks
Old Aug 30, 2015 | 12:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Anything wrong with a high idle?
No problem at all.
Old Aug 30, 2015 | 12:49 PM
NotARaCist's Avatar
I never narc'd on nobody!
<p>Can you be more specific on what parts you have? &nbsp;Or what engine you have? Or...any relevant?</p><p>https://honda-tech.com/forced-induct...round-2164678/</p><p>
2. BE SPECIFIC<span style="color:rgb(0, 0, 0)">&nbsp;</span><br /><span style="color:rgb(0, 0, 0)">-Make titles for threads, and questions clear and to the point!</span><br /><span style="color:rgb(0, 0, 0)">-Be clear and objective.</span><br /><span style="color:rgb(0, 0, 0)">-State the specifics of your situation (set-up, car, year, engine, components, etc).</span><br /><span style="color:rgb(0, 0, 0)">-The more information you can give us, the better answer you will receive.&nbsp;</span>
</p><p>Maybe your cams are supposed to idle high. &nbsp;Or maybe your IACV is failing. &nbsp;Or maybe you have a vacuum leak after your TB. &nbsp;Or maybe you need to bleed your coolant. &nbsp;Have you checked all of these things?</p>
Old Aug 30, 2015 | 01:23 PM
daboy155's Avatar
Originally Posted by JRCivic1
No problem at all.
Thanks just wanted to be sure
Originally Posted by NotARaCist
<p>Can you be more specific on what parts you have? &nbsp;Or what engine you have? Or...any relevant?</p><p>https://honda-tech.com/forced-induct...round-2164678/</p><p></p><p>Maybe your cams are supposed to idle high. &nbsp;Or maybe your IACV is failing. &nbsp;Or maybe you have a vacuum leak after your TB. &nbsp;Or maybe you need to bleed your coolant. &nbsp;Have you checked all of these things?</p>
B18B standard bore
Eagle Rods
weisco pistons 9.4:1
full supertech valve train w dual springs
gtx2867r on 13lb with 17 timing WOT while i break everything including new clutch 300whp at wheels
ACT 11lb flywheel and excedy clutch
Brian Crower Stage 2 Cams(not my favorite brand but will do for now)
I know all the specs with lift/valve lash too
Coolant is great, I bled it really well it never goes over 190 even after multiple pulls, Oil temp is steady at 180 as well.
No vacuum leaks, I smoke tested it in my garage for quite awhile
I took the IACV off and cleaned it out few weeks ago, it looked just fine when I pulled it but i sprayed a bunch of MAF Cleaner in there anyways.
The rpms just drop when I push the clutch in really fast and it cant catch fast enough, but after me raising the idle to 1300 it catches at around 700 and recovers.
Old Aug 30, 2015 | 03:54 PM
wantboost's Avatar
Who is Mr Robot?
Most cam profiles don't pull enough vacuum at lower idle speeds for the engine to ilde appropriately so you have to raise the idle. I've had it as high 2,000-2,500 depending on cam profile but never that high on most honda cam profiles. Now my Tomei 280s for my SR are retarded lol.
Old Aug 30, 2015 | 05:17 PM
turbohatch96y7's Avatar
Need to clean up the tune breh <br /><br />I would say 1k rpm idle is max <br /><br />Unless those are beefy *** cams look back into the tune <br /><br />Although if youre using crappy hondata theres no much you can do to fix it
Old Aug 30, 2015 | 05:28 PM
Geis's Avatar
lmao
Old Aug 30, 2015 | 08:19 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Not true, I have had Skunk2 Pro2 cams idle around 950 RPM just fine on both CROME and Hondata. With Hondata I even had 9lb? (maybe it was 12? Idk) flywheel and was easily able to get it working correctly. Sounds like the OP's tune is off. Look into your fuel cut resume RPM set points as well. There is a lot more to getting it to work flawlessly than just setting table numbers... Was the mechanical idle set or did you just play with the IACV slider?
Old Aug 30, 2015 | 08:32 PM
wantboost's Avatar
Who is Mr Robot?
The sad thing is most don't bother tuning idle because they want the lope.
Old Aug 30, 2015 | 10:12 PM
Geis's Avatar
So I take it the ring thingy came swimming out of the oil pan?
Old Aug 31, 2015 | 05:55 AM
Flr Power's Avatar
It Just needs better tuning.
mrx
13
Apr 4, 2009 08:31 AM
tech0937
Jan 31, 2009 09:04 PM
EK45VTi
Dec 11, 2007 06:46 PM
Dawsonb17a
Jun 19, 2004 03:44 PM
