View Full Version : Forced Induction
- Part number for GM 3 bar
- JRSC 1/4 mile times?
- Looking for creative methods to hiding turbo system...
- Why is car overheating only after being on for 5 minutes?
- Which Greddy Kit??
- is ther a such thing as a SAFE self tuneable ems?
- is it bad to have aft mrkt lightened flywheel on turbo car?
- building a motor....
- HAPPY NEW YEAR TURBO JUNKIES
- Anybody running two 255lph walbro's?
- PeakBoost H22 Eg
- whats the diff blue tops vs black tops
- neptuned Civic, Running way to rich for no reason?
- does any one make a intercooler piping kit for EK's W/ fogs
- 94 GSR Sputtering under 10-12lbs of boost fully warm but not cold
- Building a B18c1 need help
- HELP!!!! Buliding Engine, need question answered quick
- Bored? Check out my late Christmas presents to myself :)
- Tuners in the NW area
- Happy Boosting New Year to all the boost freaks out there!
- 14b + d16y8
- Where to buy Piping and Bends??
- My review of the BEGI/Cartech 2025 FMU
- FS: this is a EG 92-95 civic EX valev cover ( VTEC )
- boosted 2.4 h22
- Z6 budget boost builds thoughts...questions...
- Downpipe and exhaust flange question
- **300+whp STOCK block B16a turbo guys in here, chime in....**
- turbo inlet flange question
- Wastegate Brace - Can I Use top Port of WG?? (mbc)
- crossover break up under boost.
- Boost?
- which rod for gsr-turbo
- got a few questions for turbo installation and setup for greddy blue box
- car running wierd help!!!!!!!!!!!!!
- 550 injectors max out at ???whp ?
- your opinion?
- ok guys, i might be done for awhile. just letting you all know
- Ok WTF???? o.O Ahhhh!!!!!!!!!!!
- holsets vs. all
- Quickest Spooling
- Motor Help
- Built engines, acceptable blowby, and additional valve cover ventilation...
- Turbo
- H-T's highest HP on a stock block thread....
- Using NOS with Turbo
- are these ebay turbo kits crap?
- Max boost on stock sleeves?
- SS welds "grey"
- resistor box ???
- About that time, again!! Your FI wishes for "06"
- Best way to set up manual boost controller
- New Turbo, Exhaust Flange Question
- 580whp stock block?
- HELP turbo LEAk trustworthy shop in OC,LA
- drag turbo specs??? anyone know???
- Downpipe Flex Section. 4 feet back alright? Will it crack?
- 94 ls and greddy turbo kit?
- b18c turbo. help stuttering at 4k rpm and up. only when fully warm. help
- supercharger vs type r motor
- Which 4 Bolt downpipe do you guys use?
- Need help identifying ecu program.
- Innovative GT72
- fuses keep popping, please help
- My oil return line problem
- "complete longblock"
- Who Here Hates "WANTBOOST"???
- Intercooler Damage
- Turbo oil restrictor...
- 35mm WG + high boost applications = problems?
- Question from Argentina. How many PSI is safe to run ??
- Help: Weird Turbo Spooling Sound after Tune
- noob zex wet nitrous question!!!!!!
- 5 bolt flange with 3" dp?
- my new IC pix
- What i have so far and question about charge/intercooler piping ....
- b18a/b basemap question?
- Automatic and Turbo
- b16 tranny, LS motor? spool times?
- ECU!!!!!!!!!
- question about forged pistons
- MBC = EBC ?
- Thief finally gets his
- Turning up the boost tonight.... Any thoughts?
- AiResearch T3 with external wastegate?
- Calling out all automatic boost guys ...
- Wide Band 02 question
- checking compression with motor out and tranny off? HOW????
- smoke coming out off exhaust
- H-T's Sweetest Turbo Setups?
- EMS. uberdata and VTEC changover...
- boost guage vs APEXi safc2
- Question!!?? on nitrous HELP!!
- oil line help please
- blow off valve
- 00 integra ls supercharger???????info help
- SSAC shorty radiator
- walbro fuel filters
- 360cc injectors?
- My new setup in my DC2 integra
- Where to Buy Darton?
- -4 Brake Line Fittings Same as -4 Fuel Line Fittings?
- Check out my setup-OPINIONS
- Whats This?
- hks ssqv flange
- Buy nitrous kit or piece together?
- Ram Horn Vs XXXX how well does it flow?
- compressor map help (searched)
- Head Work w/ SuperTech Forced Induction
- 440 cc injectors?
- how much booooooost>?
- loosing coolant, searched.
- Electronic boost controller
- Copper o-ring sleeves, how to replace copper and with what??
- 3 bar map sensor,how to hook up???
- Still lookin for a turbo.....need some more suggestions on size
- which turbo should i get for the D14?
- XS power turbo kit
- Should this shop cover the damage?
- My Review on the new XSpower manifold. Dont hate. Get over yourself.
- what turbo for 400 whp on pump
- reading turbos: help need general info.
- Starting the Gsr turbo(experts please come)
- wtf Boost Spiking
- LSVTEC TURBO GUYS!!!! TELL ME YOUR STORIES!!!
- post B18C turbo setups please/I searched
- Drag Turbo Kits
- Jacksonracing SUPERCHARGER EP3 is good / bad ?
- upgrade injector greddy kit?
- turbo question...
- Will this work?
- TURBO 00 CIVIC SI TURBO
- should compressor nipple be plugged?
- HALTECH INSTALLER & TUNER.....SOCAL
- tubular manifold
- 2.3 turbo vid
- what kind of injector is this help?
- VAFC reading boost?
- Which Tread Pattern BFG Drag Radial is Best?
- help how do i install my moroso catch can???
- DRAG 3 kit on stock h22a4
- HMT std manifold w/ external wastegate?
- pic request - spark plug w/ signs of detonation
- Plug and wires question
- Spark plug stages....what do you need for FI??
- Garrett Rotomaster T3/T4???
- its already a b18b turbo buttt what i wanna do is....
- Will paypal $50 - need help emmisions
- s what do u think of the Blitz TWIN SBC?
- Any JRSC Guys Using Outlaw Engineering I.M. Gasket?
- about to go turbo checking to make sure i have all the basics covered
- Wastegate Actuator...
- Turbo storage and oil seals
- Turbo ls..looses 1-2 psi of boost after driving 30 min or so????
- rebuilt motor running sluggish! whats going on?
- whats the best set up for an LS turbo?
- question on a crx traction bar
- Boosted f22b... need help
- Car comparison
- Exedy Racing Stage 2??
- .63 a/r on a sohc ? anyone using one? need suggestions
- headgasket and 82mm bore?
- 2.25" catback too small for turbo?
- turbo si
- Help with turbo selection!!!
- help identify this turbo
- Greddy turbo kit numbers
- motor idles wierd
- How does my catch can setup look to you?
- need help
- quick sohc question
- nitrous setup
- put me in the right direction
- can i run low compression pistons with a stock ecu/tune??
- Custom Radiator Support???
- greddy turbo SPUTTER!!!?!
- WHat do you guys do with oil and filter?
- need help?any one sell and chipping ecu here ?
- Need to rebuild my drag turbo, little help please.
- .63 vs .82
- Garrett T3/TO4 BB conversion cartridges ?
- wich turbo should i buy for 330hp
- Need emission help in MD....
- For those with fuel sumps.
- Fuel System Question. Double/ Triple Walbro's... Why not for a Honda?
- I'd like to know if everything is properly installed *please look*
- P06 ecu and P75 ecu chipped?
- Full-Race turbo manifolds cracking issues??
- anyone have a link to show how to use aquarioum lines for a missing link
- How many turbos have you been through?
- any reviews on the ebay "XS" turbo manifolds?
- revisiting the "muffler too loud" thread..
- T3 turbo And light weight flywheel?! Good or Bad?!
- 2000 Civic Si Rev Problems pls read =(
- T3 / T25 ADAPTER
- H22 Sleeved Block & Boost questions.
- Ported out GSR intake manifold ....
- venting valve cover
- vtec vs. non-vtec
- Need help, check light everytime i boost over stock wastegate setting!!!
- LS/VTEC headgasket??
- A Diagram Of my Vacuum/turbo setup, **PIC**, correct?
- keeping the bumper!
- is it worth it
- is my turbo retarded?? need help asap!!!
- sohc jacksonracing supercharger
- JDM M2B4
- Best turbo for built B18B?
- Do those Cooling Plates work in all honestly? I have a 99 boosted Si
- Oil return for Greddy 19T SOHC turbo.....
- piston slap with cp pistons
- Nitrous question
- Rocker arms
- whats the most power you have herd the "STOCK" fuel system can make?
- :VIDEO: what do you think is in this car?
- peacing together a turbo kit??
- B18a turbo hatch
- lighter flywheel on turbo car??
- Fuel pressure gauge leak?
- will this turbo drain correctly
- Opinions on motor mounts?
- a/f richens at idle when I turn headlights on(in open loop)...
- turbo manifold
- What Twin Plate clutch to go with???
- !!!!Serious HALTECH Tuner Needed in Tampa Area!!!!
- Exhaust manifold temps (Full-Race) (Header coating related)
- small turbo + nitrous question
- thermal wrapping manifolds list your experiences
- Is this possible?
- Boost coming on to quick
- is it safe to run a wastegate without spring?
- why motor keeps blowing??
- running on 2 cylinders with cel 7 and 14
- what do oyu guys thank about this IM?
- Turbine F'ed up
- Need help with car dying
- Comp ratio's on D-series Head combos
- peakboost + b20vtec???
- Turbine outlet flange T3, T3/T4, GT28RS (T3 housing)
- Pics,pics & more pics from jamaica(turbo projects)
- blown headgasket, or cracked sleeve...? overheat slightly
- 4 inch downpipe/exhaust question
- What do i do about downpipe? the downpipe on my car is for t3 and i upgraded to td04 what to do??
- Exhaust Systems?? Not Loud. Good Flow....Which one?
- Problem w/ 99 boosted Civic... won't start
- Walbro 190lph Fuel Pump
- need help installing a Resistor Box for a turbo set up. cant find anything on here that looks ligit
- in need of some real world input...large turbo/low boost/tial 44mm
- blockguard
- Sc63 bigshaft vs. full race gt4088r?
