View Full Version : Forced Induction
- My new k series setup...
- fuel psi/boost cartech fmu question
- Good widebands
- garrett part number 757197-5004 what turbo is this?
- PeakBoost B-series Topmount Kit
- s15 turbo in my b18c
- XS POWER TURBOS??
- Project 500whp h23
- 18G Help!!!
- Built LS motors, come on in!
- question about getting a bov
- walbro 255lph W/JRSC fuel pressure too high>??
- how do you guys launch at the track
- Supercharger Help Needed
- Cams for B16
- weird fuel pressure problem... 0psi during prime, 40psi at idle
- How this turbo on a B16?
- Cooler Air mean more HP????????
- Need LSD...what would you recommend? and best price?
- Best boost controller??
- Fake HKS wastegate?
- VTEC head vs. LS head, questions.
- safest boost level with borestock JDM B18CR?
- 94 integra with jdm fogs and FMIC?
- gt30R topmount 10psi street pulls VID FINNALLY!!!
- Making t25 fix on d16y8!?!?!?!?
- Quick question. noobs go away.
- Jackson Racing Super Charger interchange to another motor?
- bov. quick question
- D15b vtec plugs?
- loosing pressure!!! HELP!
- What gauges are MOST recommended to have for boosted applications?
- renegade racing fuel???
- reddish/brown on ground strap?
- b-eries dip stick and d-series same??
- OBX Turbo Manifold????
- compresser A/R
- Overheating due to intercooler
- does this piping look right
- Pennsylvania crome tuners?
- h22 what shot of nitrous direct port?
- What size injectors do i need?
- how much hp can the stock h22 honda oil pump take?? or will i need High-flow Oil Pump
- garrett gt2860rs
- what temp (#) spark plug do i need?
- Any reason not to go LSVT over B16t?
- Most common comments made by (non car) friends and family about your turbo project car
- 13s civic
- will this screw my basemap?
- Still fuel mani issues....race sunday....car still wont run right....help!!!
- anyone used kordenbrock motorsports parts? aka kms-fab?
- universbo kit
- TSX and Accord forced induction same/>???
- F it I will build my own turbo kit
- Help w/SOHC Turbo Setup?
- whats the torque spec for the jdm d15b vtec head w/ greddy headgasket and arp headstuds?
- Worried about potential exhaust leak at turbo/manifold! *PIC*
- Check out this dyno.. how much power is it putting down?
- d17 oil pump on a built z6? boost'n
- wondering price on turbo setups
- vitara pistons?
- Ebay boost controllers
- Tuning with hondata s200
- Identify precision sc6152e.
- identify this turbo
- TDO5 H22 manifold or Adapter Plate?
- HKS SSQ bov, and different fins or inserts
- b16 arp studs
- Anyone with experience with passenger side turbo inlet manifolds ?
- high compression dyno graphs
- Tell me what you think about these mounts
- Turbo Kits for D-series
- do d16z6 arp headstuds work w/ the jdm d15b vtec?
- Turbo H22 Accord setup
- D15B VTEC turbo setup
- Post your best times on true STREET TIRES
- Evolution axles???
- Which Turbo Would You Choose??? GT-K or Tomahawk
- Looking for a nice, cheap standalone wideband setup.
- problem with std mani and t3 turbo
- how to supply coolant to turbo? where to tap in for it?
- Running Oil feed from sandwich
- 10:1 fmu? who's using it?
- Clutch Flywheel for LST?
- Who has the most accurate gauges?
- WHo's shop is this? Look at what there up too!
- GSR-T Won't idle after fuel up??
- 14b adapter plate
- b20vtec on nitrous?
- oil restrictor part 2
- Hard to find car parts!
- Whats the Diff between a log, top mount, ram horn manifold???
- need high quality vacuum hose for turbo
- do B16a respond well to boost?- daily driven w/ OE internals...
- JRSC parts question
- Need an opinion on fuel lines...
- Turbo Gsr dyno
- H22 with T3/T67 gt37r
- had my car tuned over the weekend...
- Ebay Turbo Kits
- trans vs power
- Info for a turbo kit!!
- intercooler piping problem!!!!
- What do you think about this sumped fuel setup
- anyone have any expierence with RHS dohc vtec gsr heads
- T28 or T25 for AutoCross?
- big bore b16a build up. help plz
- precision or RC injecters?
- 3.5" to 3.0" 90 Degree Coupler?
- Master Power turbo's?? help
- Differences between Innovate LM1 and LC1 widebands??
- Cutting out in boost
- common turbo problems
- 2 Oil pan taps
- So i bought a head... Big valves..umm....
- carb legal turbo kit in CA???? and a couple of turbo related questions!!!
- Is there any way to add 2 step on my hondata s300
- Rebuild options....What do you think of my setup?
- Greddy Profec B Spec II boost level warning??
- WTT/WTB stage 5 axle hubs
- 14" rims with Turbo LS
- Crower billet vs Manley turbo tuff vs Pauter vs Carrillo pro-h rods
- D16 needs help from Singapore
- Spark Racing, Current Problems? (H-Beam Rods)
- e-manage ultimate
- Has anyone use this downpipe for their D16 Set up?
- most whp and fastest times on CROME thread
- ZEX Cams and Turbo Setup, Im Getting Mixed Thoughts???
- List your high mileage turbo cars.
- .:spec IV and turbo?:.
- Comparison - Turbo Kits - SSAC Vs Treadstone/VECCO
- JRSC compatibility question
- Tuners in the Wisconsin Area??
- wastegate vac lines / oil lines the same ?
- FS: Honda racing radiator.
- Anyone Using The Borg Warner GM-1???
- full throttle shift?
- looking for injector clips, need some help
- Cant decided between top mount or Ramhorn. what would be best?
- calling out Cuin9sec - on being a total dipshit...lol
- MAP Check Valves
- new to boost..
- GT3076R .82AR FTW vid inside
- 4" Air filter
- Help!!!! Vacuum lines for a B/C
- What do to? K20 NA or B16b Turbo?
- How many people had their a/f ratio tuned for power?
- AEM tuner in the MD,VA,PA area
- blow off valve stuck open???
- best turbo for me?
- Typical smoking problem need suggestions
- H22 Turbo Setup questions
- T3/GT40 good for a mild setup?
- A/F ratio gauge wire help?...
- Knock Off Koyo Radiator.....???
- dsm questtion bout the injectors
- Is this piston re-usable?
- Best advise on how to teardown & clean tial blowoff/wastegate
- Need some help Asap
- need info. for turbo kit
- JR-What do I do
- is a dyno tune or a street tune better for a daily driver????
- Help with misfire around 5500 rpm.
- do oem fog lights fit 92 si eg w/ type 31 greddy intercooler/piping?
- HELP!!!!!!!!!
- Help me out guys...multiple problems, or just a bad turbo?
- edelbrock performer x turbo kit any place w/ good price
- cali nitrous law..
- Sprayin
- b16a2 t3 setup slow spool up?? and boost creep?
- intercooler sprayer
- should i use an oil restrictor?
- Anyone know whats up with AFI?
- Greddy profect B type II boost controller Boost BABY!!
- Setup/Build Traction Bar Control Arms - How Do You Set Them?
- b series budget street set up. mystery parts. (dyno)
- What is MY weakest link?
- Throttle Body.
- Greddy kit on GSR, questions.
- d16a6
- hondata s200 wire question?
- How do i install PLX m300 (searched)
- Converting back to NA have a few questions
- q about motorola 3 bar map pinout.... need help asap
- 45mm boost gauge? where to buy?
- Dyno and question???
- Running This Rich = Bad?
- New exhaust...having A/F problems???
- keeping my a/c
- Ebay turbo kit/Stock boosted LS dyno results
- What Ecu will work with both vtec/nonvtec?
- Alright folks.. I Have a problem with a supplier on here...
- installed new in. manifold & TB, idle is way high. help???
- Nitrous in Albany, NY
- Fully built high compression block good with turbo? Already searched for it....
- Check out this turbo kit
- exhaust warp
- Question about Turbo GSR
- Help ASAP, Car wont start after obd2- obd1 conversion
- Simple question
- NEED HELP!
- CRX Ram horn clearance issues!!!
- TB type R oversize?
- high boost head bolt question?
- Valve Adjustment Making Car Rich at Idle?
- Dynoed my stock motor LS yesterday. Graph and pics inside!
- JRSC and Dry Ice Charge Cooling Experiment
- GT Series BB Turbo Oil Fitting sizes/Oil Restrictor size
- turbo timer
- Some Nitrous help PLEASE!!!!!!
- which is the best fmu for the money?
- do braided lines need the steel braiding for strength??
- Compression #'s on an 92-93 ls motor
- 10psi stock bottom end?
- Sohc turbo d15b how much do you think I would lay down number on dyno?
- Results from the GT4094R???
- do blowoff valves need to be recirculated to the manifold?????
- Upgrading to dual walbro's and fuel line,which parts to get or use?
- golden eagle vacuum manifold fittings?
- What fuel managment
- D series turbo.
- crower 3's on nitrous gsr.. need opinions and facts..
- ecu conversion ??
- NEED HELP.... on what kind of clutch kit should i get for 400-500 hp
- Tuning an automatic D16?? (yes i seached!)
- help
- Turbo B16 Build, Help wanted with turbine selection. (Warning: Long Post)
- Blaast's IHI RHB5
- oil restrictor in flamenco-t's oil line kit
- radiator
- gsr JRSC conversion into LS
- Need help with 700+ Hp Fuel system
- anyone using venom injectors?
- installed the topmount!
- b16 Fuel Inj. wiring question??????????????
- Drag Manifold + 57 trim = no fit?!?!?!?
- Motor done
- building a nirous motor.....need help
- Slim fan wiring question
- need to know sizes i need for turbo oil lines
- Crvtec turbo...
- EBAY 60MM WASTEGATE whos useing one ???????
- bolt on turbo kit for EP1
- What bolts for Tilton flywheel
- could my head be cracked? if not then any other ideas.
- spoon n1 muffler
- shaft play?
- 300whp stock b16??
- H22 - 10:1 - 16psi OK?
- RC 750CC + GE fuel rail + skunk2 mani install questions
