View Full Version : Forced Induction
- V-band adapter, T3 5 bolt to 3" V-band
- B16 Turbo Head Upgrade Questions
- tial bov sealing?
- Oil cooler turbo question
- Looking to get new ignition system. What to get?
- blox b on boost.
- ok, rod bearing part numbers throwing me through a loop
- Best car to boost for price
- Best compression ratio to run with JRSC @ 11PSI
- D16 turbo for 300whp
- LSV Turbo Major smoke from valve cover
- h23a vtec on 12psi daily driver oem vs lightweight flywheel
- 1000cc injector question.
- P2W CLEARANCE AND RING GAP HELP
- 1999 Turbocharged EK...400whp daily driver?
- Can a turbo obd2 civic pass emissions
- turbo too big
- about my rod bearing clearances
- Parts/check list needed for build
- Losing boost at high rpm
- Bad turbo cause knock sound???
- Civic Build
- Is it possible to put a blow off valve on a car with no turbo?
- James Bond smoke
- ihi turbo question
- Got a D16y8. Torn between nitrous or a turbo.
- EG6 SIR B16a EVO Turbo
- E85: Lambda vs Gas AFR vs E85 AFR chart!
- oil pressure readings at WOT
- Tial WG Springs Question (Pic Inside)
- ITR cams over GSR?
- Engine Sitting! HELP
- Needing some help
- Help with mani choice
- looking for input in resleeve b18B/A
- 1.6 vs 1.8 Powerband?
- Greddy!!!
- parts or repair/rebuild kit for jrsc b series ?
- Good turbo for GSR for up to 550hp
- What exactly has failed? Picture of turbo inside...
- forced induction with a 95mm crank? good or bad
- First turbo build, looking for advice
- TRC- VIDEO** NSX Supercharged Dyno Flames!
- Fuel pressure problem?
- is InlinePRO manifold same as eBay?
- Hondata CPR wiring help
- GT3582R GSR Tranny Selection Street/Strip Car
- Do I need to retune?
- b18c1 build up questions
- Log/Mini Ram
- 70mm Throttle Body and Intake Manifold?
- popping idle
- S/C Header
- B16 turbo, AC fan removal
- b20 vtec nitrous vs b20 turbo tq curve?
- Proper piston to deck height.
- is this worth the effort?
- Cam Caps
- turbo suggestion
- anyone run log manifolds
- b18b1 turb help
- HELP WITH EXHAUST MANIFOLD .....
- Comp Turbo ct4 6465 billet or Precision 6266 billet, for 600hp goal
- Civic asking for 500 hp
- Uncontrollable boost; check this manifold out..
- Aeromotive stealth 340
- Started my b18b1 tear down
- Can anyone ID that noise? fuel pump?
- Building a turbo oil line kit
- what clutch?
- Sign the E85 Petition!!
- D16 Boost leak?
- neptune tuned JRSC'd gsr stalls?? HELP
- race fuel = more power gain?
- Tdo4h 15g
- Hood clearance issues with a JRSC and a K24 in a EG?
- weird wastegate issue.
- HOW MUCH BOOST FOR LS MOTOR?
- HOW MUCH POWER CAN A STOCK BLOCK H22 WITHSTAND
- b16 head or gsr head
- HOW TO GET MORE PSI?
- t3 vs t4 exhaust housings
- Boost by gear question s300
- How to make more boost with a Garrett Gt2871r?
- aem fuel pressure regulator concern
- hole through exhaust manifold stud port
- B20B Turbo Questions
- has the vitara d16 hype died?
- anyone using T3/T67 HO turbo?
- drew17th's 84mm b16 6262 build
- rear wheel speed sensor
- Garrett turboo questionn..HELPPPPPPPPPPP!!!!
- were to find a 3/8" fitting for rail
- putting a kit together
- OEM Darton Replacement Sleeves...
- Freshly built z6 No spark/No start
- JRSC H23A EJ8
- boost creep problem
- fully built 2.0 GSR blue smoke from exhaust
- skunk2 pro 3's question
- Aeromotive Pro vs Dual Bosch 044
- going b16b turbo/need advice
- Looking for a mechanic in MD area
- Push to connect fittings with Viton hose?
- veteran advice needed!
- cast vs ramhorn manifold - sound ?
- Anyone got a GT3251B map?
- Happy Holidays!
- H22A Turbo 6765H .81 A/R vs .68A/R hots side Witch is better
- Is this a joke ?
- Hondata S300 not controlling MAC valve
- JRSC for GSR no longer made ?
- Choosing a CR
- SMOKING TURBO HELP!
- Good turbo kit for a b18c5?
- turbo on gsr
- Massive amounts of boost creep d16
- push to connect fittings to tial????
- d15b7 turbo using p28 and injector size?
- where can i find a gasket for my 70 mm bdl tb?
- My Quest for 500whp on a Stock Sleeve / Stock Bore B16A and 93 octane
- Know this Turbo Manifold?
- OIL FOR LOW BOOSTED 2000 SI
- Need your Expertise on JRSC'S !!!@#$#$
- Ls-T questions
- Help with reading plugs
- n00b needing turbo advice
- Good wideband??
- Pressure and Temperature oil gauge?
- Dyno'd my NSX today. *Vid*
- my b16a2
- info on basic turbo setup, is it correct???
- CylinderSupportSystem Amazing results!!!
- F20c vs K20a
- Does this seem like too much piston to wall clearance?
- CT3 5558 comp turbo vs gtx3071r garrett
- cam gears question?
- Need photos of OBD2b Internal Dist
- Any use a phearable manual boost controller?
- Car runs soo hot
- Lsvtec dies when hits boost
- What head gasket to buy on boosted b18a on 8 psi?
- how much power
- temp turbo bypass
- Can a t25 turbo be upgraded?
- id1000cc and others
- Planning phase
- Boost gauge showing zero
- Is This Decent for A Turbo Kit!?!
- Boost gauge choice - Link
- dancing sleeves
- id2000
- Looking to build my gsr bottom block (info)
- G23-2b-turbo build couple questions
- Quick boost by gear question
- Go-autowerks Turbo kits
- ls/vtec oil capacity
- are these sleeves bad?
- Fuel System Help!!!
- are these really darton sleeves
- Safe boost
- Petition for Smog Exemption
- Questions on a daily budget build b20 turbo
- Greddy SP2 for turbo setup?
- Boosted D16Z6
- New wastegste (21psi) dyno numbers 630+ mustang dyno H22
- Can a 98 auto trans stand up to a d16 turbo?
- S Max products??
- Nitrous, mounting solenoids
- POST your turbo f20c setups!!
- Which turbo clear the block with SpoolinPerformance Log mani?
- Brand New Motor Gone
- D15b7 boost till swap
- 92 civic si hatch d16z6 stock .... turbo ?s
- cruise control high/low maps
- pic request 24.5x15 and 24.5x13
- 6266 and 6766 Dyno numbers and Spool?
- Need help, d16 turbo
- High Horsepower,boost by gear,17inch wheels will it work
- resleeving my gsr
- Oil Catch Tank 2 or 3 feeds?
- Turbo Mani's question regarding A/C and what's available.
- Helicoils, why do they not work?
- Deciding on the right Precision turbo
- goin turbo on poormans r. have ?'s
- ahhh fuel setup help!!
- My d15b on stock internals *VIDEO*
- PTP turbo blanket issue
- How to hookup items on intake tube by throttle body
- What size turbo?
- N/A to FI: AFAccord's 10:1 Comp Turbo F23 Build/Restoration Thread
- d16z6Tcrx's 9 sec stock sleeve daily driven build thread
- srt4?
- Getting ready to do a 14B, D16Z6 build. Lots of questions!
- walbro intank with 044 bosch inline pump
- What crank should I use
- Turbo B18C1
- Can you plug the external w/g manifold runner if you have an internal w/g turbo?
- HELP identifying b series turbo manifold
- New to the forum. F22A6 5psi on new internals
- Wastegate and blow off valve hookup howto
- On my s2000 motor, is there an upgrade from the OEM Oil Pump?
- 31x12x3 or 28x8x4 intercooler for 600hp?
- turbo lsvtec o-ring block issues
- D16Z6 Turbo Manifold for TD05H-14B turbo?
- oil pressure gauge
- Boost on gsr questions?
- New Turbo set-up
- lbs spring pressure at .500" lift specs for ITR/GSR/LS valve springs ?
- Boost creep oh noes! Advice please?
- How to identify "Darton Sleeves"???
- journal or ball bearing?
- Precision Turbo Selection
- ARP Stainless bolts and studs for turbo?
- EK 24x12x3 FMIC?
- FIC injectors?
- Cammed b18c - 6262 Finally!
- New to the forced induction world need some help with this turbo
- turbo play
- plug diagnosis - lean or burning coolant?
- Turbo Question for H22?
- Boost issue
- Wanting to achieve 300whp on y8
- cnc werx sleeve support
- Victor X vacuum leak help
- Turbos for b18
- Garrett T3 Rebuild kit in Ebay Turbo?
- dual wallys and 044
- mid to high boost timing numbers???
- billet fuel filter mounting setups..
- Lets talk oil return lines
- Sick Looking B series manifold!
- Need More than 750cc injectors?
- More Torque?
- Brand and Tire size for my car
- Oi return for foreward facing manifolds.
- question about slick size
- Wastegate Placement!
- Precision injector/resistor box help!!!!
- How many max boost pump gas 95
- Guess how much our Display case weighs, get a free AEM wideband
- Which Throttle Body?
- is this an ebay turbo setup and what should i do about my wastegate dump?
- Turbo Selection
- Quality Control Question
- What cams to run in my b18c1 setup
- car cuts out in boost
- good turbo kit for my stock b16a2?
- I'm needing some advice..
- Spoolin log manifold
