View Full Version : Forced Induction
- Cutting OEM Integra bumper for FMIC?
- please help a newb out!!!!
- Should I keep this Wideband O2 sensor?
- OBDI timing gear?
- half radiator dimensions
- Feed line Heat Sheild
- turbo won't boost (need help)
- compression
- WHAT AFTERMARKET RADIATOR YOU GUYS RUNNING ON YOUR GSR OR LS,RS,GS INTEGS
- ZC turbo?
- So I got my SSAC intercooler today...
- cooling q's
- D-series eagle rods help ASAP!
- tre fuel pump on ebay? CHEAP
- building a ls vtec or ls vtec r help!
- highest hp non-vtec??
- how to meter oil flow using valve?
- my seals are going bad
- how many with boost have upgraded their cooling system?
- ITR cams on a turbo application
- Volvo Flange
- Read ECU error code with OBD2 - OBD1 conv. harness!?
- Dart block worth for the price?
- Best compression ratio for boosted ITR
- B18B Turbo Problem for you Techs...
- OS LS pistons
- a/w guys check this out even a/a
- heat soak, any cures?
- Fmax turbo kit help
- UUHH oh got shavings inside turbo
- The difference in Turbos
- Uberdata and 1000cc injectors?????
- Hondata Vs Neptune...
- precision spool up time
- Possible power loss?
- Good Ole' JDavis....
- front end vibration
- turbo ls oil feed leakin everywhere help
- picked up a turbo for almost nothing
- Oil catch can?????????
- walbro 255, 190, lp, hp, or stock fuel pump?
- d17 01-05
- Wierd cel code kill me now
- Bad misfire/headgasket issues on built Y8
- which manifold to use.......with dyno proof!
- Hondata & Romulator Issues
- clearance questoin
- Mitsubishi TEO4HE
- problem: turbo'd d16 drives like a slug till 4krpm
- boosted Integra gsr Need help
- In need of some help..
- blow off valve install
- td05h on a b16a
- Water Fittings / Lines for my JDM t25?
- Turboing a Prelude
- crank case venting and my vacuum pump setup.. Need advice
- What numbers with this setup
- what radiator are you running in your EF turbo? b series
- ecu's in washington
- Ideal Intercooler size
- auto supercharged?
- Where can I get this jdm t25 compressor flange?
- H22 turbo internals?
- wierd startup problem...not sure if ems related
- Cold start, large injectors
- ARP head studs acting funny.
- is this ok?
- Ok finally going forced induction on b16 91 four door....need help!!!!
- Stock number for NGK 9's
- Water to Air Cooler Question
- Where to connect MAP sensor vacuum line???
- CP, JE, and Wiseco
- need help
- where to hide nitrous box
- D-17 turbo manifold
- D series turbo manifold
- Help Car will keep turning off !!!!!
- Lucas oil stabilizer? and how much oil does stock pan hold?
- DIY Ceramic coat
- Boost problem - Wastegate or Controller?
- Greddy Turbo Kit D Series Q
- Pics or info from anyone using a LOVEFAB cast sidwewinder.
- turbosmart dual stage boost controller problems!
- hp potential...
- JRSC on B16B
- zeitronix dataloggin= cant instlal proggy help me out
- greddy profec bspec2 wiring
- I joined the 700+ hp CLUB !!!!!!!!!!!!!!!!!!
- ecu questions.
- newbie? how to turn the boost up on a drag kit?
- Traction bar clearance problems?
- will 1g dsm bov work with 2 greddy turbo gsr
- Ls/vtec turbo Neptune tuned loosing boost?????????
- Best Turbo Combo
- New Dyno #. Tony1 Tuned
- TRACTION???
- idle problems (searched)
- Is 1g dsm bov good for greddy turbo kit on my gsr
- Buying a ZEX 55-75 Wet shot for high strung LSVTEC
- what will this spool at?
- fluidampner for b16 and b18c same size?
- all you guys with b turbo dc's with a/c
- Tune Uberdata/Hondata to Idle motor right without IACV on IM?
- S-AFC II with RC 310cc injectors
- ???Greddy 18G kit for SI on B18b LS???
- Searched found not too much help, stock internals/max boost question.
- tourque specs for manley rods
- what kind of hp i should get out of fully built motor with sc61.
- strange starting issue, Need Help or Ideas.
- Need help, please
- 11:1 compression and 91 octane ?
- Oil drain with drag kit B16
- need help car is boosting at 4psi at full boost at 5500 why?
- piston sticks out of deck 4 thousandths
- what avg power should i receive?
- hiding turbo and others
- Where to buy thick headgasket?
- anybody using a drag kit on stock gsr
- Nj Tuning
- What gasket to use to lower 10:1 compression?
- Having problems with my new Turbo XS MBC. Not meant for low boost?
- help !!! car is cutting out
- Need help tracking down an oil feed fitting.
- Wastegate Sizing Question
- stock gsr turbo setups
- LS-VTEC TURBO POWER DIES AT 7200 RPM ...
- car over heating...
- possible 10's gt35r set up on a dc2 integra???
- where to download uberdata?
- turbo cars are u running stock brake lines
- boost jump from 13psi to 23 psi
- Block Guards worth it?
- two nipple wastegate
- ######injector question for those of you using dsm injectors#####
- My expriences with SFP & Hondata
- Question on Oil Pressure Gauge install
- Greddy type R instructions?
- Need Help car is not boosting right ??????????
- !!!!!!!!!quick question for people with water and oil cooled turbos.!!!!!!!!!
- turbo student: how to lower compression k20a2
- could i hit 12's with a jrsc
- 75 shot on a GSR EG Hatch ?
- question bout BOV flange and turbo timer.....
- homemadeturbos suck?? wha'what??
- Oil Cooler Orientation?
- Where do i go to sleeve my block in CA?
- installed 1200cc injector with hondata basemap, car wont start now
- any eg hatches with a jrsc?
- Turbo B16A and D16Y7 dyno graphs
- Anyone got 2 Eagle rods for a B18C? I done screwed up...
- Dyno - Bone Stock B18b - T3/T04e - 8.5psi
- Vitara piston slap
- Air temperature sensor!?!??!?!?!?
- cheapest place to get fluidampers?
- Finally Turbod the D14..(kinda)..NEED HELP (car dont cranck/start) pics and vid
- Ls/Vtec Stock Sleeves 463hp/312torque
- XOXO performance intercoolers?
- 2.5 downpipe for a greddy kit?
- zeitronix wiring
- Exhaust Sounds like Garbage After Turbo......
- anyone here make up a custom interooler for the jrsc??
- Greddy 18G Guys... Porting wastegate flapper hole?
- List of parts needed for engine build - have I missed anything?
- st00pid tuned Neptuned 469whp 353 tourqe. B16 powa!!
- Update, New Track Time LS Turbo Hatch
- witch stand alone should i use
- ecu
- try to make 350WHP
- Stupid MAP sensor question.....
- proof BOV not blowing off?
- jdm 450 injectors plug and play for obd0?
- O2 sensor question !!!^%@$%!$^%@$%
- My new Setup finally came in!
- what kinda injector is this?
- oil return with moroso oil pan
- Oil Return line is leaking
- should i install engine into car with turbo already mounted to engine?
- Fitting the new turbo in...
- Oil return help...
- b16 turbo questions
- my spark plug is red??
- Advice needed for RSX with forged internals and Nitrous
- About to get head work done but have some questions...
- L15A Engine
- Another Oil Return Line Post
- Need a reputable tuner in New England
- TIMING ON BOOSTING CAR
- can 8psi on a jrsc and n20 get me into the 12s?
- I suck at searching- help finding the busted XS compressor thread.
- greddy gauge question. IMPORTANT
- t4 wheel into t3 housing
- 9 Sec. Turbo Geo Metro !! Whoa !!
- which car would be more reliable with same turbo setup?>
- D15B engine ----VSss ------ Mustang V8
- d15b engine
- d15b high compression head
- Wrist pin
- Boost controller settings...Linear boost or no?
- Intercoolers
- Just looking for some opinions
- Supercharger exhaust rec..
- is kseries closed deck?
- Turbo Gasket questions.. which way does this gasket go?
- Very odd stutter....
- wategate question
- Give me a List of EVERYTHING that i will need when rebuilding the bottom end of my b16, including st
- where can i find silicone hose that wont melt?? (for mbc)
- CIVIC TYPE R
- Turbo B16.....
- FMIC blockin radiator
- Need some advice, getting tuned tomorrow
- MayhemSi (Peter) & ThisOne (Matt)
- How much HP can the greddy type S hold
- ssautochrome? from newbie
- Hondata Nitrous Control help (tried searching)
- kteller 2.5 downpipe upgrade?
- Is race gas worth the trouble?
- WHAT INJECTOR'S ARE BEST?
- filter for type s bov
- Is this to close
- hondata box go bad?
- safe to start the car without a dp???
- kteller is screwing me
- street lite or prolite for turbo ls vtec
- nitrous Air fuel ratio
- Just installed uber basemap, car runs like poop
- Dual Pass Intercooler, silicon couplers and T-Clamps
- probe forged pistons anyone??
- other motors running on honda injection
- inline fuel pump?
- Everyone with stock B16's let me know what turbo your running! (b16 specific)
- Auto Boost (Automatic Turbo Guru's Welcome !)
- strange fuel problems only after a fillup
- hondata p28 socketed ecu
- tunning trip... problems to expect.. will I make it...
- so i feel like saving some bucks on my build
- compression results and plug question
- Boosted LS w/ stock head
- Does this look like 10:1 H22 Pistons?
- SCAMMER jsprelude
- how far will it go a stock gsr crank
- whats a good sounding bov?
- Small scratch on Crower cam. Repairable?
- High compression Turbo people please chime in
- Not your average Turbo Sizing Question
- Wideband sensors for 60 shipped. I found a hookup!
- turbo help
- need flange...
- D16A1 and D16z6 Exhaust manifolds... Are they the same flange?
