View Full Version : Forced Induction
- therma coating for 200 shot nitrous
- Datalogger and V-AFC/S-AFC question
- 02 sensor wiring
- AIR mani VS JG mani DYNO RESULTS
- bigger or smaller
- the great oil debate!!! sory had to do it!
- air/fuel ratio
- Evap Purge hose
- Hallman evolution boost controller
- Why is Tial better?
- Vavle clearance/adjustment/lash for supercharger?
- Why do people talk about clips
- why not 60-1
- Nitrous Express jet sizes?
- INTEGRA GSR with jackson racing supercharger and have problems on MSD BTM
- High idle and jerky throttle - could a weak BOV spring cause this?
- best turbo kit for a d16z6??
- Dyno'd the GSR-T today, intereting find!
- Anyone Have Turbo XS Dual Stage Boost Controller ? please help
- AEBS intake manifold
- turbo rsx
- turbo hitting dipstick tube, can it be bent?
- some oils more prone to coaking than others???
- which turbo would you choose?
- Hondata Q
- installing apexi turbo timer
- anyone take apart an internal wastegate?
- Quick Boost Gauge Question
- Turbocharging with lots of miles!!!
- Turbo install
- best bov for the money?
- Saw this turbo on the EVO 8 Boards (56k, Im not so sure)
- Rods
- can you go to ig with a PWR ic?
- joined the 12 second club
- Injector size ??
- JRSCed GSR possibly blown cat smoking black/purple under boost??
- lovefab sidewinder
- !!!!!!!!!! help !!!!!!!!!!!!
- WISECO 9.8:1 B18c pistons in a B17a. Whats the compression going to be?
- TiAL 35mm gasket
- ebay greddy turbo power chip any good?
- School me on block heaters - the turbo civic's got Minnesota winter duty =(
- will pay for turbo install at my house! central cali!
- TOO many SOHC turbo clutch choices...:frustrated:
- D16 Tranny
- Two DSM intercoolers side by side for a front mount ... any good?
- what clutch for 400hp b16?
- Need help please!!!!!
- Filter Solution???? (Pics)
- Blitz SBC-iD English Instructions (Pictures Inside)
- Where are all the fast Honda's in the Bay Area?
- Garrett T3/T04E Ball Bearing???
- Precision GT technology?
- who here sells eagle rods with the larger rod bolts???
- Unsafe to drive with no BOV?
- <<Detaild Darton sleeving process with pictures and instructions!!>>
- Few Questions about goin Turbo!!! Turbo heads look inside!
- LS turbo guys...where do you set your timing?
- Curious question about compressor placement
- JRSC fitment issue
- Sohc Turbo transmission? Recomendations........
- max boost
- DIRep972 and I Did AEBS Intake Manifold Install and Car Won't Start! Help!!!!
- Opinions Wanted!!
- JRCS + 01 Type R Cams in a b18C1?
- Any high horsepower h series
- CP Piston Group Buy
- Where can i get Uberdata chip and whatnot for my b18b hatch......??????
- what t3/t4 has a 4" inlet?
- electromotive tec 3
- CLutch Chatter....
- egt reading normal??
- are toda spec b cam too big for turbo charge?
- turbo question please help
- Can't budge the turbo to clock it...one bolt being a bitch >:(
- Post turbo b16 crx pics plz <searched>
- Microtech
- ek h22 going turbo
- please help on if a B18B LS nonvtech is the best for all the way to go for a all out turbo setup????
- REALLY REALLY need help with my car!!!!
- Supercharger on stock engine.....
- Need a couple verifications about turbo fuel management
- DSM Turbo Set Up on 99 Si?
- Post pictures of GM (General Motors) 3 Bar Map Sensor installs
- Check Engine code is non-terminating long flashes??
- Emissions soon and need urgent wastegate help!
- what to do with hondata
- Cooling ? radiators
- Newbie turbo question and yes I searched
- Innovative Boost Controllers??
- RevHard Stage 2 T3/T04E question(s).
- Need a good tuning spot in S.E. Florida(Palm Beach area),any suggestions???
- Greddy 18g Dump-pipe Flange
- Cleaned engine bay....but something isnt right
- will the type r injectors work with the blue box?
- Greddy or Jackson?
- oil coming out of bov and in charge pipe but brand new turbo...whats wrong?
- RATE my set up SOHC!!!! When will I hit full boost??
- pics and prices on a few of my new goodies...more to come
- Where can I buy Aluminum mandrel bent pipes?
- Boosted daily driven D series questons..........
- fuel injector impedance for D-series/B-series
- 6-1 collector, anymore out there????
- about to go turbo but need some answers
- boost leak
- sohc greddy kit on b18b
- low oil pressure at idle
- Best turbo parts...
- DSM injectors install
- Where to buy TiAL spring?
- Precision Turbo InterCooler Contest
- Question about how safe it would be for my engine to go from SC to Turbo High Milage
- Smoke coming out of the valve cover breather?
- help with vacuum lines
- why misfire 1,2,3,4 when cold and at low rpm (3000) ONLY ONCE?!?!
- Would either of these welders be good for charge piping/exhaust piping?
- Oil Restrictors to Help Save Turbo Seals
- LEANING OUT WHEN BOOSTING
- What do you think about this setup? (Budget)
- good pipe couplings
- almost 400 mi on fresh motor. can i dyno yet
- LOOKING: for turbo kit for 91LS TEG
- manual boost controller vs electronic????
- d16 or b18b
- What is the best turbo kit for a 1998 integra ls
- injector help
- fmu install pics for 5th gen prelude(i did search first)!!!!
- Boosting B16
- can you do an vafc hack with an e-manage????
- edelbrock or str???
- ACT clutch life
- max boost on honda map sensor with afc hack???
- Guys running t4's...
- mounting greddy oil cooler with full race kit
- h22 darton MOD 2 or MID sleeves??
- Darton Sleeve Differences?? MOD2 vs. MID need help.
- b16 turbo setup FMU OR NOT TO FMU
- running rich
- Shit!! RS sleeves + Cometic MLS= No seal either!
- B16 Custom Kit <advice welcome>
- greddy b16a2 turbo kit, TURNING UP BOOST? BOV?Tranny? Anyone else with set up...help
- Moroso Spiral Flow muffler?
- B18C1 Dyno (Not what i expected) 278.7 WHP
- new turbo, couple issues, smoke ....
- What cable to get for willems eprom burner????
- Please help....Detonation still...
- MAJOR ISSUE WITH AEM EMS 30-1010!!!!!!
- List Products you'd use for Ultimate Boosted b16 Setup. Need help!
- should i stroke and boost my b16?
- blow off valve ?
- What all do I need to do with 10lbs. boost on JRSC?
- Who has tapped the oil pump discharge port for oil feed?
- Need help finding bolt for banjo
- dsm OR my ef b20 ??
- Do I have a boost leak?
- best break in method??
- AEBS' Hondata tuning exp
- cybernation motorsports kit?
- possible to crack sleeve adn still drive ??
- which fuel injectors?
- oil from a headgasket leak?
- b16 turbo issues
- Hondata + HIGH BOOST!??
- Sard FPR: Differentiating Type-S and Type-R
- Stock Radiator for Turbo, need advices.
- my street gas b16a2 60-1 dyno
- Strange behaviour at part throttle
- which wastegate and what turbo size?
- Would this be an air pocket in my system?
- fuel issues?
- Turbo size help...
- turbo piping ideas?
- Porsche, Audi, VW, Mitsu, Saab turbo car question
- JRSC hondata questions for SOHC.
- B18B vs B18C1 poll (not what you think)
- What do you think about this turbo ???
- What manifold should I get?
- Im gonna FLIP!
- STONE MOUNTAIN RACING SPORTS - Manifold - Reviews?
- whats the difference in DSM 450 injectors
- STOLEN CRX
- which sleeves for a nitrous motor?
- people with apexi turbo kit, i need lot of info
- Greddy 60mm gauges and Autometer double gauge pods ... NEED HELP!
- anyone know good places in cali to do turbo gsr motor rebuild
- B16 motor build.....few questions....
- What should I do with my setup? Please Help!!!
- BLOWN TURBO?!?!
- Compression Check
- uberdata willem burner....Hardware error...anybody else have this problem?
- Misfire at 26 psi ?
- HELP!! Budget Turbo Kit
- Wastegate question
- Piece Together a Turbo Kit?
- Help with setup please
- views on maxrev manifold.....
- Pix comparing the JG intake manifold with Endyn CarbonFiber
- Turbo Drips oil
- Opinions on Best BOV???? (not the sound)
- Can you use CROME or Uberdata for turbo+nitrous?
- looking for turbopanda.............
- Is this a good unit? I need a standalone...
- Internal Wastegate?
- Bigger Radiator on DX??
- Action Clutch makes funny noise after 200 miles of driving
- Anyone in CONNECTICUT or near Lebanon raceway with SLICKS?
- turbo question
- How do Rev rods compare to Crower's?
- Shot Peening Stock Rods for Turbo
- Anodize (Pinellas / Hillsborough Florida Members)
- what kind of numbers with boosted d15b?
- SCC ultimate street car... AEM EMS powered Talon
- HKS standard 40mm Wastegate
- turbo size - which is bigger
- anybody using itr cams with turbo?
- still running real rich on boost
- some tasty num nums...oh yeah and we have food in the pic too haha
- THE DIFFERENCE BETWEEN THE HONDATA S100 AND S200
- hondata
- Turbo B16 and ITR cams
- SAN DIEGO Help with torqueing down my B series head
- Techedge Install Question ...
- CP pistons, standard or overbore?
- The correct way to make your own Profec B switch
- JB Weld Sucks !
- the goods :)
- Watercooled turbo????
- oh my !!dynos are way expensive!!
- coolant overflow, how important is it??
- proper sparl plug gapping for turbo b18c1?
- ... tight valve adjustment = rich = low vacuum at idle... ???
- Shes here!!!
- tyrus fmic in gen2 teg
- Anyone's GE sleeves leak and if so......
- darton or golden eagle
- Can stock D16 sleeves handle 250whp?
- how to make MSD BTM work with distributor with integrated coil/ICM
- who makes saturated 650's???
- what car has a stock 3bar MAP in it?
- Is a T2 too small?
- BOV Flange Question (Blitz and Greddy)
- RX7 TURBO ON CIVIC
- ** AutoLock How many of you guys use this **
- couple of instalation questions
- ? about my Turbo
- Greddy type-r BOV
- Turbo Setup (Opinions)
- Piecing Together A Turbo...
- Is "P57" a VTEC ecu or not?
