View Full Version : Forced Induction
- xs power turbo
- Timing for turbo set up
- who are some good engine builders for a Turbo B18B (will stay nonvtec) I am on a low to modest budg
- Oil return line issues, need some advice...
- why aren't turbos made like this:
- MBC's bad news for my turbo?
- Is OPEN LOOP in VTEC always... or is it my EEPROM program?
- Vaccum for boost gauge, BOV, wastegate and FPR?????? Searched
- how do you get past the h22's weakness
- turbo-exhaust system
- help with BOV and boost gauge..
- question about the engine of the Honda Jazz
- Octane rating..
- Neptune questions..
- 92 Accord H22a Supercharge w/ 6psi ok?
- blitz dd bov...anyone else getting compressor surge?
- She's alive!!!! starts right up, no leaks...
- Has anyone ran a Holset HX35 with a 14cm^2 turbine housing?
- the BEST cams for turbo B20
- Mental Addiction B-Series turbo kit
- d16y7 REMOTE IACV ISSUES!
- bottom end problems: opinions
- wastegate question?
- will these DSM injectors fit a B18B?
- CRX b16 JRSC ?'s
- Finally up and running, STONEY TUNED
- Will a msd 2 step work on a sci 6300 model
- What is the maximum hp a walbo 255lph pump handle?
- What kind of Turbo is this??
- B16A2 turbo bottom end set ups
- am i getting ripped off
- Question about pistons...
- Blue smoke from exhaust
- how much would you pay for this?
- Quick hondata question.
- just another b20/vtec sc61 dyno!!!
- POS Walbro pump
- Greddy gauge wiring question
- check valves question
- Eagle rod issue. ALWAYS weigh engine components before assembly
- will a 35mm WG fit on a 38mm flange on the manifold?
- 1 fab i/c setup
- is that ok?(open internal wg)
- spun a bearing on 5 psi - 9th motor
- faulty Ecu fix ( won't prime fuel pump)
- boost creep using elbow
- Help with my t3
- First time turbo
- Vortech aftercooler question
- F20B Pistons & Rods
- Electrical Gauges - Need suggestions
- Best place to buy GT40
- 320cc injectors
- boosted d16z6 and broken ringland advice needed please!
- JG valve train parts. Good, bad indifferent?
- PCV catch can
- OBD0 / Turboedit / ECU Control update for the DIY crowd
- UBERDATA TUNER!!!!
- t-3 flange
- apexi turbotimer and it's o2 gauge
- TURBO SETUP
- How much have you spent on your car? :)
- What flange is this?
- Holset Turbo Question (What does the W on a HX35W signify?)
- 300 hp ls
- Pistons to buy and actual C/R? *read*
- Emanage HELP!!
- turbo boosting 1 lb?
- hf adaptor
- Need A Tuner! East Coast, NEW YORK Long Island! HONDATA
- Integra GSR 300WHP stock internals?
- NEW TURBO DESIGN THOUGHTS ??
- Injectors sizes (HELP)
- DYNO video + chart of my t-charged b18c hatch
- turbo piping - ed9
- turbo noise out of exhaust
- stock sleeve integrity?
- its gts66
- those running an oil restrictor fitting... what size is the opening?
- cam timing..please help so i can sleep.
- first gear sucks!
- Finally got some water lines hooked up to my turbo! **crosses fingers**
- Tuning Greddy e-Manage in NC
- oil return...
- who has a Neukin Manifold
- building a turbo kit for under $1500?
- LS VTEC Progress and RC 550 Ques.
- passing emission in NY
- Where can I get a 90 Degree Transition Coupler 2" -> 2.5"
- how much to exspect for a built block...?????
- help me make sum builid motor desitions
- high vacuum at idle...sputtering...next to no boost response
- 10psi (HELP)
- How are SSAUTOCHROME INTERCOOLERS?????
- Bore Size & Boost
- Please take a look at my numbers! Are they right?
- boost controller on internal wastegate
- Quick question regarding GSR block.
- bad bov question
- What I've been spending all my money on this winter aka Built/boosted d-series...
- CAN'T GET A BOLT THROUGH THE TURBO TO BOLT UP MANIFOLD?????????
- how many of you run the precision sc63 turbo?
- p28 in an em1
- safc II install instructions plz searched all day!!!
- help were to find more info (details on capabilities of kit)
- intake/charge pipe size
- Oil lines
- Boosted civic something weird is going on with fuel
- quick question
- Walbro 255lph fuel pump
- OBX/SS Autochrome Manifold Direct Fit/Replacement
- 97+ Prelude injectors
- Super or Turbo. Read before voting
- Diagnose the gasket (pics included)
- LS/VTEC automatic...... ecu question
- Little Chip on the top of my sleeves, is it ok?
- Neptuned B16 Goes to Track and Takes Home First....
- K20 fmu?
- Upgrade fuel pump with d16/14b?
- B16 and Edelbrock intake manifold question
- Reducing underhood temp.
- low oil pressure after turbo install.
- What fuel pressure to run 1000cc Injectors at
- Turbo gas?
- RC 440 injecter flooding.???
- annybody ever swapped small ic for big ic with same setup?
- 408 TurboTeg NEEDz A TUNE!!!!!
- b18c1 jrsc w/ 01' itr cams? has anyone done this
- What turbo kit do you guys prefer? 500 - 600hp
- Can I have a bad fuel pump even though my afr's read fine??
- what do you think of this setup???
- Question about Greddy return fitting...???
- can i run a turbo without a fmu? uberdata + injector questions too
- thoughts on the t3/t67...big kahuna
- Innovative Street Heat Turbos
- what size vacuum hoses?
- Peakboost Autochrome
- BOOSING AN 89 HATCH NEED HELP!!
- Help! cleaned engine bay. now my car is smoking? and misfiring!
- Necessary turbo items...
- LS/Vtec JRSC build
- cheaper than scats and just as good?
- Cracking Manifold
- driving a fwd turbo car? problems?
- Turbo Back help
- b16 rev limit
- vacuum manifold
- TB03 TURBINE INLET PROBLEM
- MAHLE FORGED PISTON FOR H22
- foil under thermal wrap?
- would this work with my 14b dsm setup??
- B-Series different?
- boost controller?
- Honda to release 260 HP Turbocharger K-Series?
- Apexi and t3
- B16.........turbo or supercharge?
- .::Hondata Base map?? ::.
- Use flexible exhaust pipe as downpipe?
- Junkyard turbo.. Suitable turbo? Pics..
- ACT HDOO suitable for my app?
- Two Quick Questions
- FMIC Installed..assembly finally gets under way
- Should I be buying a turbo kit from ebay?
- DRAG manifold questions
- do you suggest using a walbro 255?
- A/F Ratio Monitors/Dataloggers - What to buy?
- what size AN line and fittings do i use
- cluster questions
- Going lean at 4K WHY???
- Low compression b18c1
- safc and timing
- Turbo D16
- Might be boosting again soon... pic intensive
- dsm 450cc duty cycle
- Look at this manifold
- h22 turbo
- dump tube rejoin to exhaust.............actual dyno numbers????where
- Turbo oil drain ?
- Timing on a turbo prelude?
- Honda BOV
- #*%&^@..... My turbo DP bolt threads are stripped, what should i do?
- Hey JRSC guys.
- *SOCAL* where can i drop off my ECU to get it socketed for Hondata? *SOCAL*
- fuel injectors for my turbo set up
- MANIFOLDS
- Does boosting over 8 p.s.i require a boost options from the hondata system
- Are some BOV's designed to not hold vacuum?
- Some tranny troubleshooting
- Rev Hard Turbo Kit *Opinions*
- Anyone made 600+hp with AC & PS yet?
- radiator/vacuum hoses for my b00sted DA...
- neukin manifold question?
- map sensor pins location
- Gauge questions
- Torque for HKS 3mm headgasket?
- TW- Brand New Precision Turbo!!!
- Nitrous Direct Port System
- annybody ever tried the big obx fmic (in a delsol)
- UBERDATA question (p28 5speed vs auto)
- Just got back from the dyno [HAVE QUESTION]
- Profec E-01 Problem
- D16Z6: Choosing the Right Turbo
- 83mm gsr injector question
- Emanage question
- Turbo ITR firing on 3 cylinders - broken distributor?
- Street Tuning with Turboedit in IL area???
- yet another Exhaust question..
- Want your opinions on this particular Turbo Manifold
- LS High Compression Tuning Questions W/ Nitrous, 9.2 to 1 OR 10.5 to 1
- Just got by from the dyno!
- "Clocking" a turbo?
- anybody ever ran a greddy 15g turbo on a b16a?
- old school sequintial hks
- t3/tO4e 57 trim 63a/r stage III ON a b16
- competition clutches(searched)
- Cometic is SH**
- Help identify problem with built block <56k no way>
- Need new clutch any suggestions?
- are all aftermarket sleeves closed deck?
- sc61 questions
- Q? turbos
- turbo b16a2 block
- d16y8 valves and boost?
- anyone have a pic of greddy blue box wired to ecu
- Braided line instead of hard line for direct port setup ?
- Turbo then swap?
- y7 boost
- OT: VW/Audi 1.8T Tuning Question??
- safe boost for my stock b18c1
- boosted D16Y8 Ninja's .... whats your total timing at ??
- NITROUS question
- any suggestions, rods and pistons please look!
- boost gauge showing no signs of boost help!!!!
- i want to go turbo.....but first i wanna build my engine. NEED HELP
- Car runs like shit
- Using a punch or step drill for oil feed line
- Blown turbo seal (i think)
- Can I get away with this angle in my turbo?
- Hondata or E-Mange?
- Anyone know of a good plumback BOV for 300whp?
- Anyone have info on the SARD R2D BOV?
- Looking for OBD-1 ecu.
- DA integra B20 Turbo
- AEM EMS Tuners in New York/New England... big HP# cars, experience, turbo, etc...
- ok im requesting some sohc downpipe pics
- Uberdata tuning
- 98 GS-R Turbo Build
- comparing turbos
- Stoney does it again
- GT28RS oil seals
