View Full Version : Forced Induction
- JRSC setup...
- ignitor ??? with ems
- any non-titanium retainers out there?
- getting valves in the morning, all oversized or just exhaust?
- HELP w/ fuel setup on SOHC
- zdyne injector question
- NOPI NATIONALS: IB Car takes first place in HP contest!
- Best way to tune this setup ?
- What kind of coolant are you guys using?
- read it and weap!!!!!
- stock b16a2 + turbo + alcohol (ethanol) is a good idea???
- bosch pump?
- Greddy 60mm EGT... Where to put it?
- afc hack?
- What size injectors should i get for a jrsc b18c1??
- ford probe intercooler?DIY
- Oil Squirter Question
- MSD 95lb injectors for sale
- Anyone in here road race?
- Need Help w/ Srp Piston Ring Gapping
- Vortech FPR problem...
- who still sells scatter shields?
- JRSC Intercooler
- Any Pics of a T51r SPL or a Y2K?
- Did a compression test..
- OEM headgasket+copper spray-a-gasket=???
- 3 bar map needed?
- how hard is it to tune a Zydne at a dyno without datalogging?
- How can i go about setting this up? (pic)
- irregular idle problems
- what is a good manual boost controller
- Dart Block
- FS:Hondata Stage 3b with ecu
- OT: how do you pronounce "Tial?"
- my car is sold.........i need to get drunk.
- d16z6 turb ?s
- CEL codes 71 72 73 74
- Who are you? Please join.
- which blockguard are you using?
- Anyone regret going turbo?
- Who has a LS tranny for me?
- #1 Cylinder rings are toast, honing ?
- Piping and BOV questions.
- B16 vs.B18 turbo build up
- Sold the Gs-R, look what i got now!!
- GB info: Wide band O2 sensors for DIY meters.
- My Car's Been Found---NO ENGINE, etc
- FS: AEM EMS $950 obo
- 99 accord mani?
- i need a complet turbo kit for a h23
- fs: vortech fmu
- Can ya put a turbo on a b16a sir1(first generation) with out f***ing up the vtec?
- Relatively simple mods to increase boost a stock motor can take..
- sounds like a stupid question
- Thinking of getting out. FS: Fully built motor inside.
- who makes 3" mufflers
- Group Buy on Custom Intercoolers... Would Anyone Be interested?
- Valve adjustment on a built motor. Help please.
- Alright......lets hear your turbo horror stories....
- Opinions Please
- best place to get hondata?
- Polishing the Tial wastegate...
- has anyone here ever cracked a piston?
- Anybody interested in buying my JG intake manifold?
- How do I get my oil pressure down for my ballbearing GT series?......
- turbo help???please
- wtb: hardcore axles for h22 swap
- Fuel Problems
- Parting out race car
- what size bolt to use for intake manifold
- Well I finally got the Civic running yay!.... so naturally, I crash it!
- Help me pick a turbo...
- Good place for JRSC install in tristate area
- Hard parts to find for homegrown turbo?
- Adjusting boost on a Greddy TD05H-18G
- Junkyard turbo or custom turbo questions?
- 2-step on a stock ignition?
- Which Turbo Upgrade for WRX?
- detonating
- Which motor is better for turbo?
- Input on street tire size....
- Hondata Question...
- Turbo for 96-98 Civic
- EGT's on a completely stock GSR
- Tial BOV
- Need a new standalone!!
- More pvc questions
- JRSC for sale 94-up gsr
- My weekend at fun ford.
- gb: $375 for weisco piston w/rings
- Q's concerning turbo in an 94 hb 1.6 si vtec/ ebay turbos and parts needed?
- What kind of "swap" class do you guys think I would be in right now?
- FS: 3" Tanabe Racing Medallion good for Turbo/U bends/straight pipe
- What finishes do you guys prefer?
- few questions about wastegate....did search already
- Anyone finished the project lately?
- Slow spool... Help.
- What head gasket should I use with my GE sleeved block?
- what would you guys like for a group buy?
- first start?
- Greddy Kit for 94-95 Gsr
- b-series junkyard setup
- FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (with Ceramic Coated Turbine) AGAIN...
- fuel tuning when using greddy fcu on sohc vtec
- where to get a 3" downpipe
- TurboXS Type-S vs. Type-H RFL
- FMU and BASE fuel pressure... Vortech fmu with Adj. regulator
- How high can you boost on a 00 gsr b4...
- bov flanges??
- how to run aeromotive pump?!
- Need Help Reading compressor maps
- did any of the 94+ gsr cams look different than on the FFsquad site?
- wastegates...
- Inline pro manifold
- Need downpipe advice!
- Going Turbo, need help
- Dont buy from Turbo-Performance in CA..
- i need a manifold!
- Exhaust BlowOUT!! Apex'i and Thermal FREE OVERNIGHT SHIPPING
- pictures of my turbo car(interior/engine bay)
- Looking for pics of 96-00 civics with Greddy Type 31 or Type 24 front-mount intercoolers installed.
- Clutchnet stage 2 question
- Break- in
- Turbo stuff for sale.......look inside:)
- anyone sick of loosening/stretching/breaking turbo bolts?
- Guys with turbo'd 96-00 coupes, please post pics of your rides w/mod lists.
- who will host 5 pictures of my car for me?? (engine bay/interior)
- FI Guys: Spend this $450 for me!
- Big Brakes
- Techedge WB system setup.
- Good tuners for hondata in IL area?
- Hondata Sun Clock?
- differences between drag 2 and drag 3 turbo kits
- Just ordered my inlinepro head gasket!
- underdrive pulleys with turbo.... good or bad????
- 2nd gear boost problems
- My dyno plots/ please help critique
- MAP sensor question
- A/C with Turbo
- HKS Turbo Timer question...having trouble..
- New Turbo ITR times...
- No boost and TT question
- Turbo fittings
- Built D series.... what do set your rev limit at?
- Anyone know of problems putting in a new Headgasket?
- Injectors blow out special
- ... head gasket recommendations
- Hondata base maps for b18b turbos??
- Tial Group buy
- how much HP is the stock oil pump good for??????
- 310s good for 8PSI w/ SMC???
- On Point EK's HB ... Theives in Northern Virginia!
- Which Turbo!!!!!!!!!
- Jrsc'd Cam setup
- Is my boost controller hooked up right?
- Fully built race engine possibly for sale. <---------
- Help Me!!!!!!!!!!
- Blown Head Gasket
- GM 3 Bar Map
- 250 shot on a h22, am i crazy?!
- what size turbo for 4-500 whp on an h22a1?
- I have seen tons of people thinking about electric turbos, read this.
- Which Intercooler is better:Air2Air/Air2Water/Icebox/Straight up Methanol for Str8 Racing?
- Barrel intercooler pix
- HELP...Jumpy Tach!? No fuel, car won't move!
- map sensor
- What can I use for an intake pipe leading to my turbo?
- ?'s on rebuilding a turbo
- turbo for a h23
- having problems with turbo sohc and map
- Super Charging Limits?????
- missing link.
- How do I hook up my resistor box for my 450cc injectors?
- optimum timing.
- Ok, I have 2 S-AFC/boost questions. Thanks
- LS/Vtec turbo?
- Sohc Turbo vs Dohc Turbo
- Can I use an intercooler in place of an intake?
- need input:jdm- ct 26 toyota turbo
- Poll: How long have you guys had turbo on your cars?
- Recommended valvetrain upgrade for N20?
- Post your Nitrous (n20) setups:
- Low Profile Oil Pan?..
- B20 or B16A to turbo?
- Anyone know any good tuners in the O.C. area?
- haha my h23 beat my friends turbo h22 on interstate. lol
- New dyno
- I need help
- D15/16 people, what internals you guys running?
- Wise To Boost Stock 93 SI Motor?
- whats kazz website?
- question for you turbo guys
- Passing SMOG/State Ref with a built block?
- DIRep vs. BPU supra *video*
- Need help with boost leak!
- Who sells turbo parts?
- AEM cam timing and fuel curve tuning for greddy turbo d16z6
- someone tell me about this turbo!
- Electronic boost controller/Turbo timer in one.
- Intercooler sizing?
- wonder what it's like...
- need opinions from B18C turbo owners
- WHO runs an oil cooler
- Where can i find a t3 exhaust housing???
- Some one tell me if this is possible
- b18b or b16a2 turbo......
- Anyone here use C16?
- Spark plugs...
- anyone use a loan?
- Do any of you guys use AEM cam gears?
- Would this fuel pump be sufficient.....
- rc injectors 550 saturated?
- running too rich? RC 310 injectors?
- 96 EX Motor Swap
- Deshround headwork $?
- Help me decide Fmax/Apexi/Drag a SOHC
- Toluene or Xylene as an octane booster?
- Should i keep my Flywheel ?
- When's a good time to get into OPEN lOOP???
- Compression test on a friends car reveals something terrible!
- prep for a turbo???
- Kinda OT, but still, Forced Induction Texas Meet??
- Blow Off Valves?
- Car Stolen!!!!!!!! ALERT
- FS: Turbo Manifold
- Intake piping, filter location for turbo
- Turned down the boost and my car felt faster?
- ...Need help wiring up SPEEDPRO...
- bosch 255 lph fuel pump
- Newbie to Honda-Tech Here.
- Almost finished! (pics)
- fuel pressure regulator?
- Question about Detonation ??
- YOUR "rumors" and "myths" about turbo-ing
- Why is my car so slow??
- Race Related (in St.Pete/FL) turbo manifold, good?
- Turbo Install Help
- Problem with DRAG 3 Kit!!
- bout to turbo (turbo prep)
- Went to e-town again today :D VERY pleased with my auto's results.
- Best price for AFC or Hondata (new or used)?
- At what point should you get a fuel rail?
- Looking for some technical info on the PT60
- where to buy a flex pipe
- opinions on revhard downpipes?
- OT: Where to buy EG hatchback shell for my RC CAR 1/10th scale gasoline
- Force Induction People. Put all your worries away and stress. Have some laughter.
- Which Standalone to go with?
- time slips
- To sell or not to sell ( my car )?
