View Full Version : Forced Induction
- SOHC TURBO or H22
- 2bar or 2.5 bar for uberdata
- Check my oil return line
- Newly B00sted K20
- most reliable set-up OVERALL???
- Apex I AVC-R questions
- Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo?
- Turbo Set-up in a Stock B16a to Good Top-End
- Fuel System upgrades... drag h22?
- Action clutch review 2ms
- quality difference between oem head gasket and aftermarket
- Uberdata and Neptune
- Greddy Profec B II and Switch
- Any Expereince With The Blitz Style BOV ?
- FINALLY got the Prelude tuned
- just installed a turbonetic turbo kit and now the car overheats HELP!!!
- The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan /
- questions about turboing stock motor
- stock b16a2 turbo questions
- ECIMULTI down. Need DATALOGGING version of UBERDATA.
- gurgling sound from open wastegate.
- boost controller=albert einstein
- PLX M-300 wideband display dim???
- Anyone know the AN size fitting on the fast-turbo universal oil return line kit?
- hotrex hits the dyno, pics and graph, i was pleasently surprised....
- Hondata and Peak and Hold injectors
- which turbo
- .::Need resistor box for Peak and hold injectors::.
- Length of test pipe on Greddy 18G GSR with Thermal
- Need a vafc II wiring diagram for my 98 civic HELP!!
- TTS Rotrex Supercharged EP3 CTR makes 390hp
- FI gurus help me with my predicament
- White smoke (searched)
- turbo on high compression?
- askin the boost god for some advice
- fixed timming issue, still have low compression...
- Johnny race car intercooler
- anybody have the kteller downpipe upgrade for the greddy 15g?
- need to know the distance between the 4 bolts on a T3 flange on the manifold!!!!!!
- Pressure sensor
- With Uberdata, can a Stock Honda MAP Sensor Read Boost?
- wat rpm will a t70 spool at on a stock gsr motor?
- Who has best price on tilton clutch?!?!
- updated pic of the engine bay.... dyno today, lookin for 300whp on 10-11 psi
- where can i buy a dp flange for this turbo.....
- stealth turbo kit? how to?
- is this turbo ok for b18b? 0.53 A/R and a 0.47 EXH
- what headers should i get for my turbo?
- my hmt setup
- Tuning with a wideband o2, no dyno, and a vafc.... heh... :|
- stock HG or cometic l c/r for new shortblock?
- blowing head gasket....????
- Driving Lean b4 tune
- Tons of Info on Garrett Turbochargers ** including useful formulas/compressor maps/more **
- ATTN:AEM tuners: turbo b18b wont start
- How do i lower boost on a stock 1st gen dsm turbo
- Beta II engine build ( hyundai)
- High compression with moderate boost?
- CP pistons clearance
- What can I expect to boost with...
- I Need To Talk To 5litereater........
- downpipe
- Cooling ?
- Compressor map gurus...
- Cant seem to get a straight answer.....Exedy Stage 1 vs Stage 2 Clutch
- TURBOCALCULATOR RIPPED ME OFF
- Where can i find this cable at?
- stock ls block, gsr head compression ratio
- Anyone wondering why their Project Boost Controller is a POS?...
- The weekly "What turbo for my h22" thread (I've searched..)
- P28 ECU part number
- .::Help me choose my Turbo::.
- look what came in the mail...
- D16 stock sleeve turbo bore
- Larger Downpipe for Greddy turbo kit 99-00 Si
- oil temp guage???
- Oil Catch Can Install
- ITS GT61s info....
- Norcal dyno tune and/or turbo installation???
- top mount turbo manifold
- RSX come with a Wideband???
- d16y8 vs jdm d15
- safe to run without a BOV?
- atp turbo oil line restrictor
- resistance for dsm 390s?????
- dyno pulls.....what gear do you guys use?
- bracket for turbo
- PCV to exhaust. What check valve to get?
- Has anyone tried a 3" collector header? (For supercharger/ blower)
- Cusco clutch ?
- 1st gear problem
- SOHC Turbo chokes up at 5k :( HELP!
- MN based SFWD lays down 917whp !!
- 38mm wastegate issues. kinda odd. suggestions?
- how much oil blowby thru turbo is acceptable?
- Boosting a JDM ITR?? many questions...
- K series Boost Gas Mileage..vs B series Gas Mileage..
- TUNING
- boosting stock gsr.. good tune = ??lbs
- GSR oil cooling question with boost
- anyone here run a full T4 turbo in a street car?
- GSR boost question
- just dynoed my car DAMN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- The future of EFI and standalone's?
- MSD BTM or not?
- How close is the downpipe allowed to be?
- WTB SOHC TURBO
- Finally put my turbo on and I am only getting 1-2 lbs of boost? Help!
- IMPORTANT BOOST QUESTION
- Which cams are the best u think from my list?
- Greddy Profec B spec II? or profec type S? which one?
- Greddy Kit 92-95 vs 96-00...
- is this normal on a greddy turbo timer??
- Changing sfp to inline manifold ?'s
- ac friendly turbo mani in a eg hatch
- Where to get custom valve train?
- uberdata
- Air filter size (does it make a difference?)
- are fine tuned A/F ratio's from trial and error?
- Blaast Performance, tried to no avail
- inline pro vs blox
- d15b2 stock turbo?
- JDM CTR tranny or USDM type R tranny
- ok having problems getting to jrc site anyone have a link
- Exospeed??? R they any good???
- What is more sleeper?
- weird t25 turbine housing(56k beware)
- different emissions test
- Coilpack suggestions for B/D/H/F series motors
- How much boost can I hold? B16A2
- what is the biggest bore you would run for turbo??? discuss.....
- wisdom from the gurus
- Turbo Oil Drain Size
- Is this true?
- JRSC on aautomatic D16Y8
- Contact INFO and EMail for rank1racing.com!!!!
- One-Fab?
- Greddy Profec B1 bench calibration
- Voltage drop mysteriously???
- D16Y8 stock engine turbocharged: What is the most power these can handle?
- Skunk2 Pro Series IM? What's the difference?
- piston and rod setup
- Turbo LS setup...Help...
- Whats the best wastegate for the money?
- Suggestions: I have new EGT Probe, fitting is too big for hole tapped in mani. more inside...
- Does anyone use an external/ aftermarket knock sensor for tuning?
- Quick bov question w/ use of Edelbrock kit...
- B16 Del Sol what are the capabilities for FI?
- what precision turbo is good
- Precision turbochargers
- Victor x Intake Manifold VS Skunk 2's
- Question about 450cc injector idle w/stock ecu - startability
- Intercooler piping hose clamps -and- Easy oil feed and preasure setup - What do you guys think about
- just bizarre
- CRX Fuel system upgrade
- Engine components 300 degrees after boost
- anyone running 6.5l gm turbos
- small civic radiator in a ef9??????????
- Which Valvetrain to go for in my situation?
- Turbo B16 Fuel
- No gasket for oil inlet and return flange?
- Turbo Or NOS 11sec. Car
- LoveFab SST thread pitch
- Possible Blown Motor?
- turbonetics wastegate top adjustment bolt *help*!!!
- best website to order pistons ??
- nitrous on my high comp motor?
- Engine Bay smoking randomly Please help 99 Integra GSR Boosted
- fmu or afc hack
- What to shoot for at dyno on biult LS
- new exhaust put on...i need advice..bad!
- timing and boost timing controller ?'s
- progress on the d15 turbo project
- Here's a new one I never read about in the FI forums...might just be coincedence.
- Head studs
- need help with Apexi S-AFC
- average temps for turbo
- EManage - the right led - it it supposed to blink all the time ?
- D15b JRSC dyno! Finally!
- xs-power turbo kit?
- Check Valve QUESTION
- Check Valve Question????
- new turbo integra on ht
- Turbonetics deltagate spring color codes
- inline pro manifold what are some other options
- blitz turbo timer install help
- turbo rebuild
- supercharger lag???
- First Dyno ever
- [FAQ] How To: Mount a Johnny Racecar Intercooler onto your del sol/eg+ civic
- 1000 low impedence injectors and aem
- SC61 Drain Question and housing Q
- I want to Turbo my D16A6. what would you do with $2k? fuel management,turbo,etc.?
- First start turbo problem...I think
- 4 bolt DP measurements
- boost and spray ok?
- what turbo will best support 500whp
- Edelbrock Turbo Kit UNDERBOOSTING? BOOST LEAK?
- AEM EMS Tuner in the Mid-West
- What color are the deltagate II 5-6lbs spring?
- So what does 18 lbs of boost do to stock pistons?
- Well its time to go all race what turbo for me?
- ngk part number for 2 steps coler than stock plugs for b18c1??
- Dhracing portwork?
- Tuning hondata yourself...Do i have everything i need?
- Who can get me an ARP tappered ring compressor and ship it USPS!
- chicago guys...garage kwai for tuning?
- AFC hack question
- y7 vs y8 head turbod...
- what do i need to do
- Where to get a JG throttle body for the cheapest price?
- Need advice to choose a turbo
- .::what turbo kit for a K20 (EP3)
- flowmaster?
- Roller/Ball Bearing
- MN tuning for my single cam
- Vtec and Turbo ?Overkill?
- Which catch can
- Help with Zeitronix and Hondata
- Charge pipes? Clamps what is everyone using
- is there a way to run 3 different boost settings?
- what does a standard T03 flange on the exhaust side look like?
- need boost upgrade pulley for my sohc jackson supercharger
- Calculate HP from load?
- Dynoed the SOHC with my new mods.
- **Need to find New Tial wastegate spring!
- momentary switch relay for boost controller? do they exist?
- softer engagement?
- gsr hack settings
- Force Induction guys Aluminum DIN sized Gauge pod for 3 gauges will FIT greddy, autometer etc.
- Tuning with WB, What A/F to tune at
- To tilton or not to tilton? That is the question
- HMT doing "Turbo Kia"
- Problem with breather kit on turbo gsr motor
- Best method to change from from high to low boost?
- Full Race Prototype Intake Manifold Testing
- Greddy turbo kit, car dies after 5 sec of idling
- Turbo setup, is it good?
- T3/T4 flange dimensions/size
- Dawes Devices - Dual Stage Boost controller
- Where to buy oil return line?
- Confused with injectors/ohms/resistors, someone please clarify for me?
- Won't Go Past 7 Psi.
- a noobish post
- wtf, my car is falling apart, literally.
- friends manifold broke, need some suggestions for a new one
- Tubular Manifold Flaws
- Making own custom pipes, how to bead roll?
- GT35R and T3/T67 H.O.
- CHECK THIS OUT
