Camshaft specs: NA vs. SC vs. Turbo
I would like to get an idea what Honda engines (with VTEC) like as it relates to camshaft specs. i.e., "turbo applications like more (exhaust) lift and duration, superchargers like more X"
Thanks.
Thanks.
Re: Camshaft specs: NA vs. SC vs. Turbo
There is far too many other variable including compression ratio, displacement, cylinder head flow, back pressure, boost pressure and many other things to generalize it to merely the method of induction. But I'm sure others with more knowledge will chime in.
R.I.P. Mark
SuperCharger is an easy one
best combo cams and a proven history of results
gsr intake + Itr / ctr exhaust with reduced duration on both
Good luck. Very few people on here actually know the specs of the cams that are in their cars.
