Turbosmart wastegate actuators
Old 12-09-2012, 08:26 PM
Good, Bad…I'm the one with the gun
Ash J. Williams's Avatar
Location: Trapped in time, Surrounded by evil, Low on gas
Default Turbosmart wastegate actuators
Is there any reason why i should consider the TS internal wastegate actuator for my GT28RS? What are the benefits over the stock Garrett unit?
Old 12-10-2012, 05:59 PM
Default Re: Turbosmart wastegate actuators
no takers?
Old 12-10-2012, 06:03 PM
Moderator
TheShodan's Avatar
More than likely just a higher pressure actuator like the Garrett version. Contact your Garrett dealer to obtain a higher pressure one if needed. Otherwise the stock is fine. There is no advantage. Its just an additional option.
Old 12-10-2012, 06:13 PM
they are the same PSI rating (7PSI) as the stock Garrett unit. i don't need a higher one, but i have been infatuated with the TS stuff and wondered what the advantages would be.
thanks for the reply
Old 12-10-2012, 06:20 PM
Moderator
TheShodan's Avatar
They make a higher psi (both Garrett and Turbosmart) as well as the stock. No real advantage but looks.
Old 12-10-2012, 06:24 PM
yep, not worth the extra 200 then.
Aero91
05-11-2009 01:43 AM
typexero
11-21-2008 06:48 PM
UNforgivABLE
03-29-2006 02:56 PM
boosted hybrid
07-09-2002 11:16 AM
Quick Reply: Turbosmart wastegate actuators
