New turbo, sale pricing, which one help!
there is a sale for precision turbos going in the 500ish range I am using a B16a motor stock internally other than gsr cams/arp studs. a cast log manifold. emusa 350HP cooler, ebay piping. tial 38mm running 7lbs right now at 230whp on an ebay t3t4. there are two journal bearing turbos im after.
goal is atleast 300whp-340
future plans for 4-450 (built)
I need to decide whether i should use a 470HP turbocharger or a 375HP turbocharger. and the pros or cons of each one on this years current goal.
the 4831B, (AR suggestions?)
http://www.precisionturbo.net/turboc...ger---4831B/55
or 3254E (same question)
http://www.precisionturbo.net/turboc...er---3254E/473
other suggestions??
I could really use some advice on this one
other suggestions??
Re: New turbo, sale pricing, which one help!
exactly whats streaming my mind i read somewhere around 300-310Whp is more like 390HP! but more like 360ish and i dont want to be at max!
3254E does anyone running that and knows how it responds? Ill need to just cruise to the tuner im hoping for more power on less boost with the gsr cams, this turbo, and a more "lean"ient tune
if its making you iffy on running that size turbo then ur safest an smart way to do is to build the motor. Why do two build an waste alote of money in the long run just do it once an call it a day an run your 450 goal. Save alot of money in the long run an you will know ur car can handle with out worry. I did what ur planning on doing a simple bolt on kit an my motor went an went hard. Had to rebuild top to bottom trust me its better to do it. It cost me a bunch more in the long run for just a bolt up stock. Im running a t3/t4 50 trim turbo an it kicked my motors ***. On only 8lbs
Did you maintain it well and tuned ? I've ran the b16 dozens and dozens of times. On 7 or 10lbs. And sprayed 3 bottles through it as well. More detail on motor history before during and after boost ?
It's all in choice the way you build I can't have 450 till the car is more built and planned right. For now what's on there can reach my goals other than the turbo.
If there is another suggestion available that is good for honda motors lmk!
Who is Mr Robot?
Calm down when posting... your posts are so scattered I can't make sense of them.
If your goal is for 450 once you get the motor built then get the bigger turbo... no need to buy things twice.
The only reason I'm using two different turbos for my stock and built motors (theshodan can attest to this) is because I have roughly 30 turbos laying around and since I'm not using a standard/typical turbo for a Honda setup I'm doing a lot of testing. I.e. exhaust back pressure,4 egt and lambda sensors, pre and post intercooler temps ..
yea keep close eye on the motor with my s300 an my buddy owns a tune shop with dyno so was always on it atleast once a month
the motor was all stock but now im running a t3/t4 63 trim
build setup now is
b18a1 bore 82mm
9:2.1 wiseco pistons
eagle rods
eagle crank
brian crower stage 2 turbo cams lift specs intake .470 exhaust .470
blox cam gears
blox intake
tial 38mm wastegate
hks ssqv bov
greddy intercooler
ferrea +1mm valves
supertech valve guides
skunk 2 dual valve springs
brian crower valve retainers
grams 550cc injectors
build setup now is
b18a1 bore 82mm
eagle rods
eagle crank
blox cam gears
blox intake
tial 38mm wastegate
hks ssqv bov
greddy intercooler
ferrea +1mm valves
I'm still thinkin about eBay gt30/35r lol. But I guess the precision and an oil restrictor should make me happy for a couple bucks more.
Other than that I'm in for aftermarket mounts drag coils and 22"mt's
Who is Mr Robot?
Let's put it this way, I have 1 turbo worth 25,000
Don't go eBay... for the small difference in price get a precision. (While not my first choice precision is better than eBay)
Haven't read so many great things about their units either. I put 10-15000km on the eBay one and its still working. Hopefully I end up with somethin nice anyway
I know a bunch of guys running precisions. Be it the smaller ones...nothing bigger than a 6262....only know of one who had an issue. Havent really thought about it till now tho
Thats interesting. And thats why i said that they were running the smaller ones cause i know most honda guys go with something bigger. And the above 3 are all win
Who is Mr Robot?
I've seen numerous random bearing failures in the 6262s alone..., and anytime someone sends a turbo to them they always say oil contamination to get out of repairing/ replacing the turbo
Was cruising in my buddies t28 garret b18 it's a nice healthy unit for 900bux lol
Seem a corner is being cut and ill Max out this eBay 50 trim, upgrade the mounts suspension a bit more tuning and some body work for now. Will update a thread on what's happening. I cannot wait to boost Around again
Who is Mr Robot?
I would assume the flex is from the hub profile of the compressor wheel, diameter of turbine shaft combined potentially with the length it protrudes past the thrust bearing?
