no boost
Old Nov 19, 2012 | 09:13 PM
MurtazaDSM's Avatar
Default no boost
my turbo doesnt spin at idle I searched and some people are saying shot bearings and some are saying it normal. I have a godspeed 57 trim. Also my waste gate is letting out exhaust at idle, can missing a fire ring cause this? Also can missing a fire ring on my waste gate cause no boost at all, I can hear the turbo spinning but dont feel any boost at all I did a leak test none of the couplers or piping is leaking wich only leaves the wastegate im assuming. My bov also makes no noise can the fire ring cause this as well? I did search and from what I read missing the firing ring is the problem but can it really cause no boost and my turbo from not spinning at idle? thanks
Old Nov 19, 2012 | 09:37 PM
Muckman's Avatar
Moderator in Chief
Default Re: no boost
You are a problem and a solution all rolled into one.
The missing fire ring is your entire problem.
Old Nov 19, 2012 | 09:56 PM
MurtazaDSM's Avatar
fasho thanks i searched just wanted to make sure that was the culprit that can cause all the problems listed
Old Nov 21, 2012 | 01:44 PM
MurtazaDSM's Avatar
i cant find a fire ring for a ebay style will a 38mm tial fire ring fit a ebay wastegate? dont tell me to just buy a new one or a tial im not point blank but just need to know if anyone has used a tial one with no leaks thanks
Old Nov 21, 2012 | 05:23 PM
MurtazaDSM's Avatar
Bump
Old Nov 21, 2012 | 06:46 PM
wantboost's Avatar
Who is Mr Robot?
The fire rings are the same... the only people that sell replacement fire rings is tial.... or you could try searching Google
Old Nov 22, 2012 | 09:13 AM
MurtazaDSM's Avatar
thanks I already found a ring for a good deal but its a tial just wanted to make sure it will fit..close
Old Nov 22, 2012 | 09:25 AM
Schister66's Avatar
Man U FTW
Even with the fire ring installed, your turbo may not spin at idle or build boost on free rev.
Old Nov 22, 2012 | 10:40 AM
wantboost's Avatar
Who is Mr Robot?
The 57 trim should spin.... just saying
But without a fire ring there was too much exhaust gas/pressure bypassing the turbine.
Old Nov 29, 2012 | 01:09 PM
MurtazaDSM's Avatar
ok so i put installed my fire took it for a spin and still no boost and no i am not free reving lol I drove it around my block and I can hear the turbo spool but it wont produce boost. There is no exhaust coming from the wastegate anymore either and the turbo does spin at idle now but will not make any power
Old Nov 29, 2012 | 01:21 PM
wantboost's Avatar
Who is Mr Robot?
boost leak... or your turbo is shot, check for shaft play. ebay turbos can fail on the first startup
Old Nov 29, 2012 | 01:28 PM
Schister66's Avatar
Man U FTW
Check for boost leaks. If you cant find any, take the compressor housing off the turbo and look for scuffing. If the turbo has a bad bearing or the tolerances are too loose, it will wobble and contact the housing. It will spin, but never fast enough to make positive pressure.
Old Nov 29, 2012 | 02:40 PM
wantboost's Avatar
Who is Mr Robot?
did you physically go look at the turbo and check it just now?
Old Nov 29, 2012 | 05:08 PM
1lowek2007's Avatar
what lb wastegate spring do you have? Do you have one at all? are you sure you have your vaccumn lines hooked correctly? Is your Blow off valve stuck open?
Old Nov 29, 2012 | 05:33 PM
hybridmiklo's Avatar
What kind of wastegate? some like tial need a vacuum line hooked up and it also depends where its hooked up. Top or bottom. Plus, my turbo setup didn't spin at idle either.
Old Nov 29, 2012 | 07:00 PM
MurtazaDSM's Avatar
I think it might be the bov noob question should i set it to soft or hard
Old Nov 29, 2012 | 09:59 PM
MurtazaDSM's Avatar
I dont think its a boost leak since i triple checked everything and the turbo is new and has no shaft play
Old Dec 1, 2012 | 09:34 AM
MurtazaDSM's Avatar
its a cheap egay wastegate but its new and the turbo doesnt have any play bump
Old Dec 1, 2012 | 10:23 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Lmao
Old Dec 1, 2012 | 10:24 AM
What did expect from a poor quality part?
Old Dec 1, 2012 | 10:25 AM
grumblemarc's Avatar
The Grumpiest
Miracles.
Buys cheap part then wants some trick to make cheap part perform like it was the real part he should have bought in the first place.
Keeps saying "think" or "I don't think" A lot. Indicating he doesn't really know. "Duck season! Rabbit season!" "Wastegate! Blow off valve!"
Old Dec 1, 2012 | 10:36 AM
Classic cartoon argument
Old Dec 1, 2012 | 03:18 PM
MurtazaDSM's Avatar
Lol i understand ebay got a bad rep but it was my bov it was all the way soft
Old Dec 1, 2012 | 03:20 PM
MurtazaDSM's Avatar
Also i just installed my injectors and walbro i have a chipped ecu with basemap butthe car has bouncy idle from 1000 to 3000
Old Dec 1, 2012 | 03:33 PM
Not a fan of the "chipped" ecu gang, from my understanding, you really don't know what you have. Your wastegate...it's a knock off...do you understand? eBay isn't bad, if its not a moving part. I buy items for my car from eBay but they're the real thing and not a knock off brand
