Check me please
Old Dec 11, 2012 | 04:59 PM
Mobeious's Avatar
Default Check me please
ordering parts for my oil lines for turbo
this sandwich plate
which has 1/8NPT inputs
this oil line kit
which has AN4 feed line and an10 return line
all i would need to order is a 1/8NPT to an4 adapter for the oil feed line from the turbo to the sandwich plate ...correct?
Old Dec 11, 2012 | 05:35 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Check me please
It has the adapter for the plate I'm the kit
Old Dec 12, 2012 | 05:13 AM
BigMike0147's Avatar
Yes, you're correct. You'll need a 1/8npt to -4an fitting adapter. It'd probably be wise to make that a 90º fitting/adapter as well unless you're going to use the 90º bend that's already built into the feed hose. I can't tell from the picture what's on the other side of that hose.
Old Dec 12, 2012 | 02:29 PM
Mobeious's Avatar
that is a cx racing oil kit... any others on the market better for $80-100
Old Dec 12, 2012 | 02:46 PM
wantboost's Avatar
Who is Mr Robot?
The npt-4an fitting is already in the kit
Look at the straight end of the hose...
Old Dec 12, 2012 | 03:00 PM
Mobeious's Avatar
wouldnt that be just the an-4 thread on the hose? not 1/8NPT
Old Dec 12, 2012 | 03:34 PM
wantboost's Avatar
Who is Mr Robot?
Ugh... the hose side is 4an
The other side is 1/8npt
Old Dec 12, 2012 | 03:35 PM
wantboost's Avatar
Who is Mr Robot?
Look at the damn pic you posted... two ends of the feed line. One doesn't have a fitting threaded on it... (the 90* side) the fitting for the sandwich plate is threaded in the straight end of the feed line..., and is included in the kit
Old Dec 13, 2012 | 07:06 AM
Yeah, I wasn't sure if that was the case, but it looks like that is a pretty good possibility.
Also, you might need another adapter for your turbo inlet (and maybe for drain too), but you don't know until you get it all worked up. This is where these projects can nickle and dime you. An adapter fitting might cost you $8 if you want to make it look clean and only use one (vs using multiple to do the same job).
Old Dec 14, 2012 | 01:59 PM
carlos8's Avatar
Do you bought the kit already, there are many swandwich adapters better than this i.e G.E,Black works. Your 1/4 line goes straigth.
slamedcivic
Sep 19, 2006 05:55 PM
tslag
Nov 18, 2003 10:18 AM
integranator
Apr 7, 2003 03:46 AM
blowncivichb
Mar 27, 2002 05:04 AM
Boosthead
Dec 10, 2001 11:58 AM
