2 questions! (d16y8)
Old Nov 23, 2012 | 09:20 AM
hjdanzi's Avatar
Default 2 questions! (d16y8)
Hey Guys, been long time.
1) I was wondering is someone remembers where is the d16y8 oil pump port and shim tutorial... i searched but i cant find it.. i remember there was one?
2) Would it be good to send the crank to the machine shop to do that extra oiling hole in the crank?
Since im boosting this d16y8, i thought that some acl main and rod bearings in STD size + ported and shimmed y8 oil pump + extra holes in the crank.. would be nice...
If anyone can help me out, it will be greatly appreciate it.
Thanks.
Old Nov 23, 2012 | 09:26 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 2 questions! (d16y8)
Not looking hard enough.
https://www.google.com/webhp?sourcei...w=1829&bih=802
http://www.d-series.org/forums/diy-f...g-porting.html
Swap the crank for a Z6.
Old Nov 23, 2012 | 09:32 AM
hjdanzi's Avatar
Originally Posted by grumblemarc
Thanks man, i didnt google. I just search in the faq section of FI and civic 92-2000 only here in HT. Thanks a lot...
I cant get a z6 crank... in my country everything is hard to find and very expensive... the machine shop work over the crank isnt an option?
Old Nov 23, 2012 | 09:36 AM
The Grumpiest
And pray tell, what would you ask the machine shop to do? Port the pump. Shim it if you must. Been running a stock pump ported for 3 years now.
Old Nov 23, 2012 | 09:39 AM
hjdanzi's Avatar
I was wondering if i could tell the machine shop to do the extra oiling holes in the crank... ive noticed the z6 has 2 holes per journal and the y8 only one... i was thinking in making them do the other ones? would this be a good idea? (besides porting and shimming the oil pump?)
Old Nov 23, 2012 | 10:53 AM
hjdanzi's Avatar
Can someone please confirm this last thing please... i really dont know what to do here...
i cant find a z6 crank in my country, would it be the same to take the y8 to the machine shop and make them do the extra lubing holes in the journals?
Old Nov 23, 2012 | 10:56 AM
Charlie Moua's Avatar
i wouldn't do anything like that to the crank.
Just buy a z6 or a6 crank for $70 + shipping. they don't go for much more than that.
Old Nov 23, 2012 | 11:00 AM
hjdanzi's Avatar
Thanks Charlie. I thought it was something that was already tested and done, but i wasnt sure... so, i guess.. its not an option...
Old Nov 23, 2012 | 07:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
With the "book" you wrote, you sure are asking basic questions.
More pressure is not needed as the D-series can't even provide the RPM necessary to facilitate this. The other side of the coin is proper bearing clearances combined with oil weight to get proper pressure. Extra volume can be had by porting. The limitations will come from internal block passages.
As said before, just get rid of the Y8 crankshaft all together. The time and money spent to "do it right" you could have already had a good condition replacement "upgrade".
jdmreed92
Apr 28, 2014 06:37 PM
Efjams24
Jun 17, 2012 07:12 AM
SOHC Warrior
Mar 31, 2012 08:33 AM
98civicEX
Jan 26, 2003 05:34 PM
