Fried piston... :(
Old Dec 13, 2012 | 03:49 PM
JDM3JDude's Avatar
Default Fried piston... :(
3rd cyl Piston went when my car ran hot.
? I wanna order the Nippon racing 10.95/1 piston's that i have so i won't mess with my tune. Do these only sell on Ebay?
Recomendations???
Thanks
Old Dec 13, 2012 | 08:01 PM
SiRCiviC94's Avatar
Default Re: Fried piston... :(
You should re tune anyway what caused the over heat?
Old Dec 14, 2012 | 02:39 AM
JDM3JDude's Avatar
The pin i had to my coolant fan fell out so it would not turn on an the thermostat froze shut
Old Dec 14, 2012 | 10:21 AM
kbouchard1092's Avatar
What??!!
Can you explain fried piston? it melted? Your rings are shot?
What are you tuning with? ....You said you dont want to mess with the tune, and it seems thats exactly what you're going to need to do.
Old Dec 14, 2012 | 01:08 PM
carlos8's Avatar
the most important question how your piston look at?black,orange,purple,cracked and where?
Execisive engine temperature can damage a piston.
Old Dec 14, 2012 | 06:02 PM
JDM3JDude's Avatar
Pic of what happened when i pulled the rings off. " to the left are the peices "
It def. Had carbon build up on top of each dome but they where brown around the edges where the Teflon either melted or rubbed away. The cylander walls are still in great shape though
Old Dec 14, 2012 | 07:03 PM
MRGRIM's Avatar
R.I.P. Mark
that looks like the ring lands have broken
I agree with above look at your tune
Old Dec 14, 2012 | 08:12 PM
wantboost's Avatar
Who is Mr Robot?
Too aggressive of a tune for stock pistons... detonation broke that piston
Old Dec 15, 2012 | 04:45 AM
JDM3JDude's Avatar
Figured it may have been a mixture. When the new pistons come in it will def. Get a re tune after i let the rings seat in good. It was running pretty lean before the ring lands went, but lasted 20k miles. Once i get this running an settle into my new place next month I am gonna search for a B20 block to build an sleeve with a lower compression. The Nippon's are 10.95/1
Currently running a B16A with Arp's, stock polished crank an rod's, Nippon Pistons 10.95, Ported/polished head, OEM Honda HG, Turbonetics Drag kit with .57trim t3/t4, 3" exhaust, DSM injectors, SSQ Bov an Tial Waste gate on 7lbs tuned on S100 "hondata"
Old Dec 15, 2012 | 08:26 AM
SiRCiviC94's Avatar
How much power or how fast in te 1/4 before it broke down?
Old Dec 15, 2012 | 08:58 AM
Muckman's Avatar
Moderator in Chief
its time to step up to forged pistons.
Old Dec 15, 2012 | 10:01 AM
JDM3JDude's Avatar
Made 268Whp an 197ft trq on 7lbs didn't get a chance to run it on the track. Nearest track for me is 2hr's away
yeah, i wanted to while i have it apart but i don't have the funds at the moment being the Holidays are so close. Maybe after income tax ill build a B20 block "legit" an do a CRVtec build being i already have a Full B16A and Gsr Lsd tranny.
Old Dec 15, 2012 | 12:06 PM
xenocron's Avatar
Stock pistons are like a coin flip...I've seen ring lands crack that I know we're under timed for safety sake...it might have been too aggressive but you can't say that for certain
Old Dec 15, 2012 | 02:27 PM
wantboost's Avatar
Who is Mr Robot?
Yea that is true, but I've never seen just cylinder pressure break omr, normally it's a spike of some sort
Boyle.R
Jun 21, 2014 12:38 AM
janiscrulzz
Feb 5, 2013 04:39 AM
RC000E
Jun 5, 2007 12:09 PM
Sliced Beard
Jan 22, 2004 06:55 PM
