turbo question
Old Nov 11, 2012 | 01:39 PM
toothy91's Avatar
Default turbo question
so heres what im thinking
z6 + y8 head
stock pistons and rods
block gaurd
vx mani with t25 (2g dsm turbo)
walbro 255
390cc dsm injectors
boost controller set at 4-7 lbs
wideband
all in a wagon still obd0 with resistor pack
now the question is how bad will my afr be if i run it with out a tune for a little bit?
Old Nov 11, 2012 | 02:01 PM
Freemananana's Avatar
Default Re: turbo question
z6 + y8 head
block gaurd
walbro 255
390cc dsm injectors
wideband
Your Air/Fuel ratio will be jacked up and you'd risk destroying what you just spent all that money on. Doesn't make sense not to tune it. I think you'd have to change your ECU too, probably obd1 with MPFI instead of obd0 and DPFI. The computer stuff is the reason my current Civic is still unboosted.
Old Nov 11, 2012 | 02:46 PM
toothy91's Avatar
mine is rt4wd so its obd0 mpfi
Old Nov 11, 2012 | 03:20 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
4-7psi equals...what?
dont use psi as a gauge for hp. also to run that low of psi you need to make to when the wastegate opens
Old Nov 11, 2012 | 05:23 PM
toothy91's Avatar
from what i was reading the internal wastergate, it opens at 8psi....
Old Nov 11, 2012 | 05:39 PM
4tika4's Avatar
he wasnt
Old Nov 11, 2012 | 06:11 PM
If it opens at 8lbs then you wont be able to make 4-7...well you would make it but it stop until it hits 8lbs
Old Nov 12, 2012 | 06:36 AM
mtflyboy25's Avatar
WTF!?!?
Old Nov 12, 2012 | 07:35 AM
Let me rephrase
If you have an 8lb spring in your wastegate you can not set your boost controller to 4lbs. If you want to achieve 4lbs...then you need a 3lb spring. Your spring has to be lower then your lbs you want to make.
Old Nov 12, 2012 | 02:37 PM
toothy91's Avatar
alright lets change it to i wanna run 8lbs still how will be afr's be? will i be to lean or rick running the 390's?
Old Nov 12, 2012 | 05:54 PM
your afr will depend on the turner dawg
Old Nov 12, 2012 | 07:19 PM
toothy91's Avatar
well im just wondering how bad it would be with afr to drive 5 hrs to get a tune...
Old Nov 12, 2012 | 08:00 PM
Hidenplanvew's Avatar
wont be to bad, you will need to run stock injectors... Just stay out of any boost at all... I would trailer it
range hadies
Mar 12, 2012 10:42 PM
lilsicsoul
Nov 27, 2008 06:58 AM
almostjdmeg
Mar 7, 2008 03:45 PM
CRX Si
Sep 14, 2003 07:41 AM
