My 99 SiR build
Old Dec 26, 2012 | 01:12 PM
TGonie's Avatar
Default My 99 SiR build
Shout out to all fellow honda lovers from Edmonton, Alberta, Canada
I have always used this site for info over the years and finally decided to share my honda history
The SiR is my 2nd honda and my 2nd build. I used to work at a Honda dealership and never used to be a fan of hondas until I drove a 00 Sir that was lowered with all the bolt ons that came in for service. Set the wheels in motion for my first build.
I had plans for a turbo build even tho I didnt even own a honda at the time. So i bought a complete b16 swap just to get things started while I was shopping for a donar car. Disassembled everything as soon as I got it for a full rebuild and new bottom end with low comp pistons and eagle rods
But then a minty 92 coupe came into the lot on trade in... only 142000 km... I bought it the next day haha
Instantly pulled out the stock d15 and swapped in the b16
A turbonetics t3/t4 ball bearing turbo and countless other mods later and this was the finished product before I sold it to buy my SiR shell and block
SiR Build starts now
Old Dec 26, 2012 | 01:45 PM
TGonie's Avatar
Default Re: My 99 SiR build
So after owning my ej for 3 years it was time to move onto something else... A friend of mine had a 99 SiR he was doing a turbo build on but he had un foreseen problems and had to part and sell. I told him I would take the shell and listed my car for sale. I had a few calls right away, took one guy for a drive and he bought it on the spot.
I went and picked up the SiR and started getting a engine together. I originally wanted to go with another turbo build but ended up doing a mild NA build and came across a used nitrous kit. Then I installed a JRSC for a summer and now i am currently underway on a new turbo setup lol
I have made a detailed build thread on a local forum and will take forever to make another thread that detailed again so here is a summarized version to get caught up. Its been 3 years in the making at this point
Golden Eagle Sleeved B18A bored to 84mm
11.5cr JE pistons with eagle rods
ARP head studs
New bearings
Type R oil/water pump/moroso oil pan
PR3 head
Supertech valves/springs/retainers
CTR cams
Toda Replica headers
And came across a used direct port nitrous kit
New AEM cam gears
Skunk2 Intake mani and 68mm TB
B&R fuel line and breather setup
Old Dec 26, 2012 | 02:15 PM
TGonie's Avatar
Timed the engine
Installed the clutch masters clutch/flywheel
and installed the transmission
And going into its new home
Made a new injector harness to for the larger nitrous fuel rail and changed to a smaller cleaner looking nitrous line
Got a different set of headers and finished installing everything else.
Mishimoto rad/fan/shroud/reservior
Cf whale ***** and breather. Nitrous solenoid wiring and wired in a resistor box for the dsm 440cc injectors
Got a skunk2 2.5" catback from a friend and made a test pipe
Installed a pair of ITR recaros in need of a cleaning. Striped the back seats and truck. Mounted the nitrous bottle and battery
Got a AEM wideband. Autometer Nexus control module with nitrous and fuel pressure gauges.Also mounted my nitrous arm and purge switch
Installed NRG wheel, skunk2 shifter and ****
Also cut out my glove box to mount my Hondata S300
Skunk2 coil overs, camber kits, Function7 LCAs, BWR sub frame brace
Old Dec 26, 2012 | 02:28 PM
TGonie's Avatar
Fired it up, got it warmed up and timed. Backed it out of the shop and drove it to the car wash. So dusty from sitting for almost 2 years
And a trip to the dyno
see links for video of a few pulls
http://www.youtube.com/watch?feature...&v=Z5Jm9QcX04o
http://www.youtube.com/watch?feature...&v=Ytz1wfQjzD4
http://www.youtube.com/watch?feature...&v=FJgMwsLrWP0
http://www.youtube.com/watch?feature...&v=6NGevcioWQo
Some rubbing issues solved
Honda Love
Old Dec 26, 2012 | 02:52 PM
TGonie's Avatar
The nitrous wasnt enough so after some shopping around I found a JRSC. Used some elbow grease and gave it a new look. Replaced the tensioner bearings and got new belts
Installed the JRSC and made a new intake arm
Got a another autometer nexus gauge to match the others. Vac/Boost this time
Got some CTR rep headlights, yellow halogens and some new fogs to replace my cracked ones
Old Dec 26, 2012 | 03:23 PM
TGonie's Avatar
Well another trip to the dyno
The clear coat on the cf hood was pretty fucked so I had my buddy wax/polish my car and re clear the hood. Turned out ****** great
Before/After
A few pics
Old Dec 26, 2012 | 03:38 PM
TGonie's Avatar
Got myself some more nitrous reserve... Picked up two 10lb bottles and polished them up.
Also got a aluminum battery box
Needed a new stereo head unit and have always wanted a navi/touch screen
Then this came across my eye
Made myself a bezel and got it wired up and fully operational
Old Dec 26, 2012 | 03:42 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Damn I like what you have done to your civic!
Old Dec 26, 2012 | 04:01 PM
TGonie's Avatar
After this season when I parked the car I pulled the engine again. Plans for the turbo build have finally come. Should have just stuck with boost from the start but it was good experience. Not many ppl have had every kind of induction on their car.
Last drive before going away for winter hibernation to my dads shop
And out goes the engine again
Cleaned and bagged everything to bring back to my condo with me to begin the turbo build. Started by selling off the things i wouldnt need anymore. JRSC, headers, cat-back etc
Old Dec 26, 2012 | 04:10 PM
TGonie's Avatar
The plan is to do a piston swap from 11.5 down to 9 for lots of boost. 1000cc injectors and a topmount turbo.
After lots of research i made the decision to order a Top mount kit from Greg at Go-Autoworks.
Old Dec 26, 2012 | 04:14 PM
TGonie's Avatar
More turbo goodness
Old Dec 26, 2012 | 04:17 PM
TGonie's Avatar
And this is how it sits today. Need to get myself some pistons and injectors and I can get this thing back together and running. Dyno is booked May 25. Myself and 14 other ppl have booked Turbogixxer to fly up to edmonton and tune our cars. So stoked for this!
http://www.turbogixxertuning.com/
Old Dec 26, 2012 | 04:26 PM
cetcivic's Avatar
no one wants to hear the truth
u doin it big,man
glwb
Old Dec 26, 2012 | 04:42 PM
EE2bitsk's Avatar
damn that motor/turbo look mean on that stand like that.
car looks bad *** dude.
Old Dec 26, 2012 | 05:43 PM
phaphon's Avatar
clean good progress
Old Dec 26, 2012 | 08:10 PM
TGonie's Avatar
Thanks for the compliments! Ive done all the work myself. I really wanna do a wire tuck and clean the bay up while the engine is out again. Just started a new job 2 months ago and havnt had alot of time to work on the car
Hopefully I can make it happen
Old Dec 27, 2012 | 10:17 AM
JReal's Avatar
Nice. How much power were you putting down with the nitrous/jrsc?
Old Dec 27, 2012 | 01:49 PM
speeddave's Avatar
Looks good TGonie! (I'm holset hatch on the local boards) Nice to see you come over to the turbo side. You've got the right parts to make some great power. Maybe I missed it but what fuel pump are you using? Any plans to strap some slicks on it and make a few runs?
Old Dec 27, 2012 | 09:18 PM
TGonie's Avatar
Thanks man! I knew I would be back eventually. Snails are addicting.
Im running a 255lph walboro pump. I am planning on getting a nice pair of slicks and beefy axles eventually, sooner the better. I really wanna hit castrol as much as I can this summer since I should be able to put down some quick passes now. Pistons, a rehone and injectors are top priority right now tho. I still gotta save some cash for the tune and my portion of kennys accommodations in may. I forgot how expensive this turbo **** gets lol
Old Dec 27, 2012 | 09:34 PM
TGonie's Avatar
Made 183whp NA, 238whp on a 60 shot
Ran into fueling issues with the jrsc tho. Unfortunatly the jrsc was a spur of the moment buy, I didnt originally build the engine for boost. 11.5 comp ratio maybe even higher with some decking and flat valves.
I wasnt expecting good numbers, just had a opportunity I couldnt pass up. Even running only 6 psi there was detonation as soon as we started to give the engine any timing. Only made 202whp with a super conservative tune. Rich and retarded on boost. Definatly picked up alot of low and mid range power tho.
The whine of the blower still made it all worth while
Oh yea, running Husky 94 octane
Old Dec 28, 2012 | 02:31 AM
wantboost's Avatar
Who is Mr Robot?
You didn't have enough injector for the jrsc, 440s on that much compression won't work... and if you had a meth injection kit and bigger injectors you would've been fine... can't run that high compression without e85.. 10:1 is about as high as you can go with forced induction of e10 (standard pump gas)
Old Jan 7, 2013 | 05:17 PM
JustDoinMej2's Avatar
feels like fast & the furious all over again!
Old Jan 7, 2013 | 10:05 PM
TGonie's Avatar
Unfortunatly we cant buy e85 in canada I dont want meth injection either. I came across the jrsc and had to buy it. I was planning on getting the LHT upgrade and the piston swap this winter. The piston swap is happening but instead of upgrading the jrsc I decided to just go turbo again. Double the hp for nearly the same price.
When I had originally built the engine I had no intentions of boosting it... But **** happens and now im just doing what I should have done from day 1.
Ill have more updates as spring gets closer and I get everything back into the car and running
Old Jan 7, 2013 | 10:12 PM
TGonie's Avatar
Bro, I live my life a quarter mile at a time
Lol but in all seriousness constructive criticism is welcome
Old Jan 7, 2013 | 10:36 PM
hahhahaha nice one.
naaaaa man I like it, my fault if it comes off wrong! subscribed to the build
