combustion chamber damage?
Old Nov 25, 2012 | 05:26 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default combustion chamber damage?
Just bought this b16 head online and upon inspection I noticed some damage along the edge on one of the combustion chambers ! is this head still good?? thanks for any reply I really didnt know where to post this as i know a few smart people in this FI forum that could prolly give me a good answer! thanks again HT if you need another pic from a different angle lmk
Old Nov 25, 2012 | 05:30 PM
got-vtec?'s Avatar
Default Re: combustion chamber damage?
no expert, but looks like it might affect the hg seal.
Old Nov 25, 2012 | 05:38 PM
wantboost's Avatar
Who is Mr Robot?
You can try surfacing the head but that damage looks like it's too deep in the head to be repaired easily... you could have someone weld over the damage then surface the head but that's still not a guarantee the head is fixed.
The weld work and resurface would probably cost more than another head if the damage is extensive enough.
If you want to part out the head let me know lol
Old Nov 25, 2012 | 05:51 PM
Throwdown's Avatar
it doesnt seem to protrude any ... I would rather fix it if its fixable ,im in no rush thanks for the reply hopefully someone here has had a similar problem
Old Nov 25, 2012 | 06:23 PM
wantboost's Avatar
Who is Mr Robot?
I didn't mean it stuck out. I meant the damage goes too deep into the head to simply surface it.
I'm prerty sure if you surfaced it most of the damage would still be there... and you ca only skim the head so much hence why I said it probably needed to be welded up
Old Nov 25, 2012 | 07:04 PM
SPOOLINmatt's Avatar
looks like the piston got ate for lunch one day. that **** is easily fixable and for pretty cheap if you find the right tig welder. put a nice bead along there, carefully grind out the area that protrudes into the chamber and then resurface.
Old Nov 25, 2012 | 07:17 PM
Throwdown's Avatar
Awesome thanks matt!!
josh green
Oct 24, 2010 07:52 PM
butch11a
Welding / Fabrication
Jan 3, 2005 07:46 AM
