Go-Autoworks street vs. tuner kit
Go-Autoworks street vs. tuner kit-
Is the tuner kit more expensive only due to turbocharger options?
The wastegate port location on the street kit manifold looks better than on the tuner kit.
Anyone heard of boost creep when using the tuner kit manifold?
street kit-http://www.go-autoworks-store.com/gostkit.html
tuner kit-http://www.go-autoworks-store.com/gotutusy1.html
Moderator
Re: Go-Autoworks street vs. tuner kit
No. the tuner kit is more expensive because they are using a tubular manifold that is made by hand as opposed to the cast. The material is of a better grade in the tubular, and is able to hold both 4 bolt and 5 bolt turbine housing, unlike the cast which is made more for the 5 bolt turbine housing, limiting your turbo options.. It is also able to be repaired more quickly than the cast. The tubular log IMHO is much more robust than the cast for longevity.
So you're looking at the wrong things here. Wastegate location on both is just fine, and the 90 degree elbow does not cause any boost spikes or creep.
Tuner Kit all the way, baby..
Case closed. The tuner kit has been chosen.
My first thread made five minutes after I finally registered is promptly answered by none other than TheShodan.
My day has been made.
My pants have been ruined.
Global Moderator
I actually was in the same boat as you.. I called Greg at Go-Autoworks and ordered the Tuner kit a couple weeks ago. It should be here in a few more weeks.
I really like those guy's over there.. have taken care of me thus far.
I'm just anxious and kind of nervous all at the same time because I'm boosting my 97 spec B18C-R.
I ordered the street kit today, After thinking over it for a few days, street kit was good with my power goal.
hopefully the wastegate doesnt fall off or runners crack 3 times like me buddys did at the track. My buddy bought a kit from go-auto and had nothing but problems with the ramhorn manifold. They did warrant the repair, which then the manifold was sold and replaced wth a topmount full race. The owner of the new go-auto ramhorn has recently had weld repairs done again.
actually i have local guys who have run both kit on similar setups.
if your goal is under 370ish whp i'd get the street kit.
if your goal is 420ish whp i'd get the tuner kit
this is based just what i've seen in terms of manifold restriction limits.
On both case (gsr turbo) we stopped turning up the boost when we saw that that psi per whp gains began to loose ground.
If you want over 450whp get S-Race ... but anything over 500whp will greatly benefit from going with the ramhorn style manifold with the pro kit.
that's just all IMHO... ask greg... he'll help you out with any of your questions.
Charlie
Charlie
I beg to differ on the waste gate location being fine. Creep with a 90 degree bend is very possible where waste gate size should be looked at more closely. There's a reason why my Full Race AC ramhorn manifold has a 44mm gate rather than the standard 38mm.
Who is Mr Robot?
Creep depends largely on a few things
Manifold design, gross exhaust flow, turbine wheel size, turbine wheel housing size, wastegate diameter, pressure level... and that is the overly simplistic version
Moderator
Example - A setup I had circa 2002 using Revhard's Iron tubular log
20 events, using an older TiAL 40mm Gate (about the same aperture as the 38mm MVS, using at first a GT3540S at 12psi, then an HKS GT30R at 19psi. No creep, spike or issues at about 15 HPDE events in the east coast.
Example 2 -Californiadad's Spoolin Performance tubular log manifold -(C'mon, you know I had to)
At 15, 20, and 24 psi of boost pressure, using IIRC a TiAL 2 bolt 38mm wastegate on a surfer. No creep, no spike, no issues.
There are several other currently running examples of that design being used on running cars right now in several threads.. No issues. I'm not saying that wastegate elbow placement isn't important, especially for Top mount manifolds and Kooks manifolds running a LOT of power over 600-650whp. But more importantly, creating a properly planned manifold/turbocharger/gate combination accordingly without having to resort to bleeding off more pressure is what determines how well these types of manifolds will generally perform..
I'm hoping Tony the Tiger will give some additional insights as well.
Our cast manifolds are grea IMO. We've compiled plenty of info and feedback to make sure they are a worry free, trouble free item. We've also opened up turbo availibilty for them and are working on a 2nd SS cast manifold design. The cast manifolds are backed by a lifetime warranty to the original purchaser.
Sidenote...a look into the mold
That is pretty legit, huh?
Charlie
Charlie
If you ever have any specific questions, feel free to just call or email, I or someone else here will help you.
