Guess the sleeve
Old Dec 19, 2012 | 07:39 PM
peardrax's Avatar
Default Guess the sleeve
So there is a used block im thinking of buying that has sleeves with what looks like a copper ring in the middle and the owner says "these are the good kind" . Anyone can shed some light on this ?
Old Dec 19, 2012 | 07:43 PM
doood's Avatar
been there done that
Default Re: Guess the sleeve
o-ringing is common. how about you post some pics.
Old Dec 19, 2012 | 10:56 PM
wantboost's Avatar
Who is Mr Robot?
Without pics we can't tell you ****
Old Dec 19, 2012 | 11:27 PM
Discosteak's Avatar
find a different block. I wouldn't buy from someone who doesn't know what they have.
Old Dec 19, 2012 | 11:40 PM
wantboost's Avatar
Who is Mr Robot?
For all you know he o-ringed a stock block
Old Dec 20, 2012 | 07:55 AM
mechanix619's Avatar
I would never purchase a sleeved block without full receipts and/or without having a machine shop inspect it first. Just because a block has say Benson sleeves doesn't mean they were installed correctly.
Old Dec 20, 2012 | 08:38 AM
kf91da9's Avatar
sounds like a NO NO. better safe then sorry
Old Dec 20, 2012 | 07:08 PM
peardrax's Avatar
Here is the pic guys... helped?
Old Dec 20, 2012 | 07:24 PM
TheShodan's Avatar
Moderator
Golden Eagle ductile Iron sleeved with a copper O-Ring. Nice stuff. No issues, no worries, Golden Eagle is the only location that puts them in. Reminds me of mine.. (Still have my original GE sleeved block from 2003, with about 40K miles of street fun and about 50or so road racing events)
You got lucky. No need to replace the o-ring, its fine, looks like a flat surface. Use and enjoy.
Old Dec 20, 2012 | 08:10 PM
wantboost's Avatar
Who is Mr Robot?
Yea very nice sleeves, I would at least check the deck to see if its level by using one of those flat bars and a set of feeler gauges
Old Dec 20, 2012 | 11:02 PM
peardrax's Avatar
Thanks Shodan, and also rest of the guys, lucky is not the word, has cp pistons and manley rods with arp2000's also ....
Side note shodan (or anybody else with experience) setup good enough to make 950 whp guys?
Old Dec 20, 2012 | 11:13 PM
wantboost's Avatar
Who is Mr Robot?
Should, with proper tuning, a gigantic turbo and a totally unusable power band lol
What's the bore size?
Old Dec 20, 2012 | 11:33 PM
peardrax's Avatar
^^LOL on the unusable power band, I daily a b16 EF with a gt2860RS, you want a usable powerband nothing beats that lol
stock bore,Im going to freshen up the motor new bearings etc so I presume I can bore to 84 and just switch out pistons..or would that ruin the sleeve? turbo is an s372R and im trying to run mid 8's or better in a 1500 lb crx with a wheelie bar (my country has no class rules) .. what yall think?
Old Dec 21, 2012 | 08:28 AM
kbouchard1092's Avatar
I would def check the deck for straightness as stated above to be safe. Looks like someone polished the deck
Old Dec 21, 2012 | 08:51 AM
TheShodan's Avatar
Moderator
You can bore out to 84mm just fine, but remember, unless it has an 89mm (LS/B20) stroke to it, there's no point in boring out that far. Don't go for odd sizes like 82mm ,83mm, as gasket replacement may take longer.
Sure. use an S372 if you want.
JDMCIVIC919
Jan 29, 2012 01:54 PM
Boosted_EG8
May 9, 2009 12:12 PM
IndySporty
Jan 27, 2007 07:36 PM
sodacan33
May 2, 2004 05:53 PM
HondaGuy02
Apr 20, 2004 08:43 PM
