can you help reading my spark plug ?
Re: can you help reading my spark plug ?
WAY TOO HOT and lots of detonation.
Is it tuned? What fuel ? how much boost ? what power level ?
If thats Cyl 1 then im sure Cyl 4 is worse unless that is just on cyl 1 and not the others.
it was tuned. after tuning - the turbo is converted to a water-cooled center and rebuilt.(it was leaking oil)
fuel is 95 octane.
10 psi
turbo is garrett t3/t04B - 57 trim
the problem was : I didn't know that there was a voltage problem. The car's voltage was dropping to 11v and the AFR was around 14-15 at full boost. I solved the voltage problem, so should I change the plugs and see whats going on ? or should I make it retuned ?
fuel is 95 octane.
10 psi
looks like when i tried adding nitrous with just the fuel regulator cranked up! 13+:1 mixture. an hour on the dyno will sort out problem i dont see why its always a retune (400-1000$)! good stuff to know though
as far as I could check from the last log before taking the plug photo, it is between 12.6 and 13.1 when boosted..
edit : it wasn't like this before, I don't know if it is because of turbo or anything else..
