use vacuum block as oil block?
Old Dec 28, 2012 | 03:33 PM
Mobeious's Avatar
Default use vacuum block as oil block?
Anyone ever do it ?
Old Dec 28, 2012 | 04:51 PM
Muckman's Avatar
Moderator in Chief
Default Re: use vacuum block as oil block?
Why not use the oil filter sandwich?
Old Dec 28, 2012 | 06:12 PM
EsotericImage's Avatar
Retired Moderator
Old Dec 28, 2012 | 06:24 PM
turbohatch96y7's Avatar
Dont see why it wont work out..
only way to know for sure is to mount a pressure gauge before and after and monitor the data..
Old Dec 28, 2012 | 08:30 PM
effin's Avatar
Originally Posted by EsotericImage
rofl
Old Dec 29, 2012 | 01:22 AM
rich7777's Avatar
I don't understand the question. OP, please explain your self boy...
Old Dec 29, 2012 | 02:30 AM
wantboost's Avatar
Who is Mr Robot?
Why? Nothing you're using requires that many ports...
You really only need an oil feed and if you're running an ls/VTEC then you need a feed lime for the head. Oil temp goes in the oil pan... pressure sender can use stock pressure sender location.
Why over complicate it. Besides the vacuum block wouldn't provide equal oil distribution, the port closest to the feed would get more flow than the last one on the block.
totsie7944
May 1, 2008 04:52 AM
em1 Ziggy
May 12, 2006 11:08 PM
Adam R.
Dec 16, 2004 03:06 PM
redboost10
Dec 9, 2003 01:15 AM
2000vsm
Jul 20, 2003 01:19 PM
