Looking for some experienced suggestions.
Old Dec 9, 2012 | 06:05 PM
Dc2 all day's Avatar
Default Looking for some experienced suggestions.
So i'm considering turboing my new unmolested Gs-R and i'm hoping for about 300-350whp. Aside from Arp headstuds, eagle rods, and JE 4032 pistons what else should i get to safely make this my DD? Should i get bigger injectors maybe an aftermarket fuel pump? And I also could use help on selecting a turbo as I'm completely out of my league when it comes to them. I want something that spools from about 3k and maxes boost about 4k-4500 but i don't want to lose top end. I was thinking maybe a GT3076R as i heard they spool quickly.
Old Dec 9, 2012 | 06:12 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Looking for some experienced suggestions.
You'll have to have bigger injectors and fuel pump to make any kid of power. A gt3076 won't spool that quick but it will close.
Old Dec 9, 2012 | 06:18 PM
Do you know of any that spool quicker and what makes a turbo spool faster just for future reference i would like to learn in case i decide to shop for a new one later on. I want the boost early so i as i reach higher rpm's i can keep traction instead of spinning through all of my gears lol. All in all i want a mustang killer. But, keep in mind it will be my DD as i start another project.
Old Dec 9, 2012 | 06:27 PM
ekcoupeh22's Avatar
You can go with a precision sc61 quick power great spool for the power your looking for
Old Dec 9, 2012 | 06:37 PM
doesn't a GT30r lag less than a sc61?
Old Dec 9, 2012 | 08:42 PM
wantboost's Avatar
Who is Mr Robot?
Sc61s are laggier than **** and really old technology
Old Dec 9, 2012 | 08:50 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Disco Potato, the GT28RS
Old Dec 10, 2012 | 06:50 AM
4genaccordfreak's Avatar
Yes, you will need to utilize larger injectors, a larger fuel pump and some kind of reputable engine management.
The GT3076R is what I am currently running. I see spool about 3500-4000. Max boost about 5000ish. Although I am running about 9.0:1 C/R and a top-mount manifold.
With your stock 10.4:1 C/R and a shorty ramhorn manifold you should see spool closer to 3100-3300. max boost before 4500rpm.
Not sure what c/r those pistons you mentioned are (im at work, can't look them up) but atleast you will get a general area of spool-up and full boost rpm range.
The 3076R also has no problem holding power all the way to 9000-9500rpm and is a great all-around performer with room for you to bump up the power if need. It also sounds like a diesel truck spooling up aswell which is always nice to listen to.
Old Dec 10, 2012 | 08:46 PM
Thanks, all i've heard is good when it comes to the GT3076R and just wanted to confirm the whole top end problem. If anybody has any other suggestions as to parts i should add with the turbo let me know as when it comes to turbos i know NOTHING lol.
Old Dec 11, 2012 | 04:24 AM
gabocastano's Avatar
If you want a faster spoolup try the Gt 3071r or the Gtx 3071r
Old Dec 11, 2012 | 07:56 AM
Schister66's Avatar
Man U FTW
Either one of these would be a great choice. Also, the GT2860r would one to look at. Your goals are very realistic given the engine build, but for the utmost streetability, i would go with a T3 flanged GT2871r or GT2860r
91SIR
May 4, 2010 04:38 AM
ccssk8ter11
Feb 13, 2008 07:05 PM
97dc2
May 30, 2005 10:30 PM
BorderM3
Jan 13, 2003 04:30 PM
fast[R]
Apr 17, 2002 02:50 PM
