Boost Creep?
My Setup up:
AFI Front Facing Exhaust Manifold
PTE 6766 A/R .68
1x Tial 44mm (12 PSI)
I never take the same pressure on my AVC-R with this setup.
AVC-R OFF I always take around 1.02 or 1.12 on my AVC-R screen and I have ever seen 1.38b
Do you think I need to put another Tial 44 W/G or change my boost controller?
thks
PTE 6766 A/R .68
thks
I remember that you told me that point on this thread
https://honda-tech.com/forums/drag-racing-36/my-eg-drag-car-3075732/
I cannot add another tial like that I need to change or modify the Exhaust manifold.
I connected the Tial W/G with the port above,
like this
perhaps I need to use the 2 ports first?
like this
Hook up the wastegate directly without the boost controller and see what boost level you are hitting. If you are still too high then your only choice is to cut and weld a new wastegate port. This is not uncommon for a lot of setups depending on the turbo/engine combination. For 60+mm setups I almost always recommend dual 38/mvs wastegates right off the bat to eliminate this risk on a street car.
Air is lazy and goes the path of least resistance.
If the car is pretty responsive on boost response you can go up in a/r on the turbine side and that will help your boost control with what you have now.
http://www.turbosmart.com.au/wp-cont...1/10/5530.jpeg Here is a link of proper w.g. location.
AFI told me to put a lower spring inside like 5 PSI?
I will try this week
I believe the lighter spring will affect the over all pressure that you can control with the boost controller though. With the lighter spring, you may not be able to reach the maximum level that you are wanting to reach
Who is Mr Robot?
I've seen people with creep on divided manifolds running twin tials use 3lb springs to eliminate creep. They seem to be able to get 25psi out of those springs with an ECU controlled boost controller... however every setup is different.
There is nothing Wrong with the Angle at all, other then the Top lies on the Damn Runner! I would look more at your plumbing first...
Just done some tests tonight.
5000 RPM to 7500 RPM I have 14 PSI and past 7500 to 8400 RPM it goes up to boost cut @22PSI.
I tried to connect directly the W/G to the Turbo and same problem.
I will try with lower spring and after I will add a W/G...
Have you checked for leaks on your wastegate? Buy a vacum pump, or a compressor and check it for any leaks before you rip apart your setup.
It doesn't matter if its new double check, its the easy route.
I'm not suprised no one in here mentioned it.
