need help with gsr turbo
i need some help with my gsr this is going to be my daily driver so i need some reliability. I dont want to pass 14psi of boost
what i have is a 98 gsr head with no port and polish or anything like that with skunk2 stage 2 tuner series cams, ferrea valve, supertech valve springs and retainers, skunk2 intake mani with 68mm tb
the block is bore to 81.5mm with micropolish crank, arp main bolts, acl race bearings, brand new type r oil and water pump
i just want some advise on pistons rods compression ratio what turbo kit injectors stuff like that, also the car is going to be tuned on a hondata s300
Re: need help with gsr turbo
*advice
Eagle rods
Cp pistons
10.1:1 compression.
1000cc injectors with injector driver if not using ID. Injectors.
Not a fan of kits so your on your own there.
Can't recommend a turbo based off of psi.
Search youtube find a horsepower level that looks fun and go from there.
Good luck.
Eagle rods
Cp pistons
10.1:1 compression.
Good luck.
Man U FTW
Man U FTW
Power goal impacts a lot...until you decide on a goal, its going to be hard to answer a few of the following questions since power goal and the parts you buy are inter-related
Which turbo are you running?
What size injectors?
Which fuel?
Which spring in the wastegate?
Do you have a boost controller?
Compression ratio?
Which fuel?
Compression ratio?
If the motor is apart and your building it you should think of strengthening the cylinders so you don't end up putting thousands of dollars into it just to rebuild due to a cracked sleeve.
Ok lets say i want at least 300 to 350 on stock sleeve and i dont have any turbo turbo kit just want some advice i know i want cp pistons, eagle rods, rc injectors and is going top be tuned 93 pump gas with a hondata s300
The Grumpiest
So, in other words, you don't have a clue. I say that seeing as how you only answered one of the questions put to you. You're just clicking off names like it's supposed to mean something.
^^ no i don't have a clue but i see that you do so why don't you post what compression ratio and what turbo will take me to my 300-350 hp goal with what i have thanks
The Grumpiest
Where did you pull 300-350hp out of? Some arbitrary number?
FAQs. Read them. Many times. Stop asking for it to be handed to you. Spoonfeeding is not beneficial when dealing with forced induction.
If you loved me, you'd all sell me your magic cards to me today
