B16A 83mm or 85mm?
B16A 83mm or 85mm?
B16A " boosted " .57t with Cast Nippon Pistons
Was told my motor had been bored .25 over an sleeved, pulled to replace head gasket an no aftermarket sleeves but pistons are there.
Took my head to the machine shop to be re surfaced an he also said he had a 85mm headgasket laying around that will work. I already got a 83mm oem gasket from my boy, which should i use? The 85mm gasket looks real thin between each cyl with minor over lay an the 83mm fits snug with more gasket between each cyl. An minor over lay. Which is better to use?
I am only on 7lbs btw. Sorry for the STORY, just need a answer asap so i can put my daily bak together.
