head gasket choice?
I have a B16A " stock head " block has polished crank, .25 bore, Arp's, CNP high compression Pistons an a Turbonetics Drag kit t3t4 .57 trim on 7lbs. My ar ran hot an popped the head gasket, whats a good choice an mm should i get to best fit this set up?
OEM
Yes, even with the oversized bore. Honda purposely made their head gaskets .5mm oversized so that when upping the bore, you can still use the same part# head gasket. Up to. 5mm of course..
asubennett
Jul 14, 2005 06:44 PM
