New b16 nippon question.
Old Nov 17, 2012 | 04:13 AM
Balor_Gr's Avatar
Icon2 New b16 nippon question.
Hallo guys.Im gonna give a try this pistons.
http://www.ebay.com/itm/Nippon-Racin...80896038294%26
They are Nippon pistons.My question would be what should be the piston to wall clearance for 450 whp b16.
Im kinda confused cause they are cast pistons.What about .001 for every 100 whp like vitara pistons?Im thinking of .0045-.0055 to be safe.
Thanks for your time.
Old Nov 17, 2012 | 07:41 PM
Brice.Hayden's Avatar
Default Re: New b16 nippon question.
Don't think you'll see 450wheel for very long with cast pistons. The consensus seems to be 300ish+ whp with oem pistons.
Old Nov 18, 2012 | 01:27 AM
Balor_Gr's Avatar
Yeah but arent the vitara pistons used by d16 guys also cast?
Old Nov 18, 2012 | 04:55 AM
JDM3JDude's Avatar
I have cnr pistons an i was told not to go over 350whp with them in my b16A
Old Nov 18, 2012 | 10:58 AM
Schister66's Avatar
Man U FTW
Those pistons are cast and very similar to a stock piston. If you're looking to make 450whp, buy forged (CP, JE, Arias, Wiseco).
Old Nov 19, 2012 | 12:41 AM
Balor_Gr's Avatar
And that will be done.
Old Nov 19, 2012 | 05:46 AM
v8eatrr's Avatar
I will be tryin these as well
Also aiming at 450
Old Nov 19, 2012 | 03:58 PM
Schister66's Avatar
Man U FTW
You can still make that kind of power on Nippon pistons, much like you can make that power on stock pistons, but the longevity and sensitivity of the setup is questionable. Pistons/rods aren't that expensive...and a lot less of a pain in the *** than fixing a melted piston/cracked sleeve
Old Nov 19, 2012 | 05:34 PM
v8eatrr's Avatar
Also the pistons he has the link posted of are made of te same material that Mitsubishi has there pistons made with for there 4g63 so they have to be a little better then any old cast n/a pistons
Old Nov 20, 2012 | 06:01 PM
dcmatt's Avatar
People have done over 400 on nippons more then once. They have thicker ringlands then stock. One guy used the high compression nippons and put down 399 on E85. Tuning is key. And of course forged would be better if its in the budget. You can use the nippons with afyermarket rods but its like $50 extra for the machining.
Old Nov 20, 2012 | 10:12 PM
Yeah but for how long? Longevity is the key. Which I said in the first reply.
Old Nov 21, 2012 | 02:00 AM
dcmatt's Avatar
https://honda-tech.com/forums/forced-induction-16/nippon-turbo-pistons-2878572/
Old Nov 22, 2012 | 03:51 AM
Balor_Gr's Avatar
Ok guys.Afte research ive done about the chep pistons.
They seem to be 4 options
NPR pistons(NIPPON PISTON RING CO., LTD.)Yellow package
Its an japanese brand but it says america on their boxes pictured at ebay. http://www.npr.co.jp/english/
YCP pistons(Yong Chiang Piston Co., Ltd.)Taiwan manufactured by the japanese standard aluminum cast. Blue box. http://www.ycpiston.com.tw/
NIPPON racing.NIPPON RACING LTD.They came in a white box whith made in Japan writen at the bottom of the sticker.The only ifo i could find is the distributor named in ebay Uyuni sales http://members.ebay.com/ws/eBayISAPI...userid=uyunira.
And the rs machine we know.
Since the budget droped im ginna try npr PR4 81.5mm pistons with oem rods with arp2000 rod bolts.Im gonna keep it 350whp to see how it goes.
Old Nov 22, 2012 | 09:23 AM
Schister66's Avatar
Man U FTW
I'm not arguing that it CAN'T be done. I was arguing that it isn't worth the "upgrade" to Nippon pistons from stock pistons. You can make those same power numbers with E85 on a bone stock bottom end.
Bottom line: If you're going to take the time to build it, do it right (forged) or leave it stock
Old Nov 22, 2012 | 09:53 AM
Balor_Gr's Avatar
kinda believe that too but if an engine is not at good condition its OK i believe.
Anyway what the stock b16 rods "safe" limit?They seem to hold very nice due to small length and 1.75 rod/stroke.
Old Nov 22, 2012 | 11:08 AM
Schister66's Avatar
Man U FTW
With pump gas I wouldnt push it harder than 325-350whp and with E85, 350-375whp...maybe as much as 400whp. The stock ringlands will most likely be the first part to let go, but with good tuning, you shouldn't have any issues.
Old Nov 22, 2012 | 12:15 PM
dcmatt's Avatar
Like I said if its in the budget go forged if not the nippons are a cheaper alternative. I get the whole do it right the first time arguement. But people dont realize not everybody has that option. And of course the standard answer for that is well you shouldn't do it then. Cheaper is not always gonna end tragically.
Hey trickeng, what was it.... 9.14 on stock sleeves if I remember. Too bad they didnt give up when they didn't have a sleeved block.......
Lmao they deleted his comment
GrenadaEG2
Aug 9, 2009 01:32 PM
totoy
Sep 29, 2006 11:01 PM
DarkSolPR
Mar 22, 2005 03:49 PM
