VTEC and Boost
Old Dec 11, 2012 | 11:09 AM
Steeve_Civic's Avatar
Default VTEC and Boost
Hello,
I set my VTEC at 5200 but my T6766 boost around the same RPM and tires spin a lot.
What do you advice me please?
Old Dec 11, 2012 | 11:48 AM
4cylfiend's Avatar
Default Re: VTEC and Boost
What software are you running?
Old Dec 11, 2012 | 12:53 PM
TheShodan's Avatar
Moderator
Won't matter. Big turbo, good rpm, low displacement = spin tires. Changing VTEC points won't help your situation.
Old Dec 11, 2012 | 01:34 PM
4cylfiend's Avatar
I was thinking along the lines of: If hes running a boost by gear setup, he can control the wastegate duty cycle and ramp boost in much easier rather than pouring everything in at once.
Old Dec 11, 2012 | 03:03 PM
OK, thks, I need to buy tires first
I use Hondata S300 on my B18C1 engine
Old Dec 11, 2012 | 03:44 PM
TheShodan's Avatar
Moderator
To a degree yes. But it will not help with any of the responsiveness of the turbo at all. Even in the higher gears, I wouldn't be surprised if he still had difficulty considering the behaviour of the turbocharger on that platform. BBG helps but doesn't solve the issue, especially if he doesn't the room like in the U.S. to utilize it.
azandford
12
Nov 8, 2009 02:58 PM
elmalo
Engine Management and Tuning
May 2, 2009 05:27 PM
civicboy1128
12
Jan 12, 2009 09:15 AM
civicboy1128
Aug 5, 2008 12:39 PM
greengangsta
Jan 2, 2002 12:29 PM
