Jackson Racing D16 crank pulley
Hi guys,
I have the chance to buy a JRSC for my EG sedan.
The point is, that the kit will only include the supercharger, s-tube, supercharger pulley and the belt.
I miss the crank pulley and the tensioner with mounting bracket.
Now is my question can I buy this parts and is the crank pulley a special pulley or a normal Honda OEM part.
Thanks a lot guys.
Thanks a lot guys.
R.I.P. Mark
Re: Jackson Racing D16 crank pulley
you dont need a special crank pulley
and the other parts might be avialible through magnuson but youd have to call them
as it wont be on there website also ask in the JRSC thread for help
okay thanks.
the crank pulley is a OEM honda part and when I will increase the boost I will change the supercharger pulley.
is this right?
is this right?
R.I.P. Mark
you need the following pulleys to upgrade
D Series swapable crank pulleys A6 5.79"/ Z6 6.04"/ Y7-8 6.29"
you can also change the charger pulley as you said
down load the d series Calculator this will help you work things out
http://ftlracing.com/JRSC_calculators.htm
