AN fitting size
Old Dec 11, 2012 | 06:11 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default AN fitting size
I made a mistake. Planning to run -10 drain hardline, i purchased -10 nut and tube sleeve and 0.625" tubing, thinking that -10, being 10/16 = 5/8" = 0.625" OD.
i was wrong. The tubing is too small. i suspect that -10 fitting is made for a hose that has a much larger diameter than -10 itself.
Which leads me to this question, which OD tubing do i need to do a -10 flare nut and sleeve drain, 0.797"?
Old Dec 11, 2012 | 06:20 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: AN fitting size
The tube fittings are listed by inner diameter iirc
Old Dec 11, 2012 | 06:21 PM
ThE HeLLRaZoR's Avatar
Which ever Tubing has the Same OD as the Tube Sleeve lol...
A friend made this same mistake and we just did a Double Flare, then tightened the **** out of it. Been leak free for 3 seasons:/
Old Dec 11, 2012 | 06:25 PM
i purchased them as -10 tube sleeve. i will mic the ID of the sleeve when they arrive.
Old Dec 11, 2012 | 07:01 PM
turbohatch96y7's Avatar
Old Dec 11, 2012 | 07:20 PM
Originally Posted by turbohatch96y7
have anything constructive to add, or are you here just to try my patience?
Old Dec 11, 2012 | 08:03 PM
why are you running a hardline for your drain line?
why didnt you just order up a drain line kit?
is this your first build? serious question/ curious
Old Dec 11, 2012 | 08:08 PM
do you have the data i require?
Old Dec 11, 2012 | 08:12 PM
Old Dec 11, 2012 | 08:18 PM
i've two braided line drain hoses laying around. i want to use a hardline. my first what build?
Old Dec 11, 2012 | 08:31 PM
turbo build man.
I noticed you been asking a few questions in here, just wondering if your taking your first crack at a turbo build.
just wondering again, why a hardline?
Old Dec 11, 2012 | 08:35 PM
yes, this is a first turbo install i have done. i'm no neophyte when it comes to fabrication nevertheless. i ask questions for two reasons, ask people who are much more knowledgeable than me and to generate content so someone can simply search and get answers. the hardline is better in few areas, the cross section of a tube is larger than the hose in the same AN size, i KNOW the quality will be good, unlike the two hoses i purchased, i don't like bolting bought things on and i like the way hardlines look (working with experimental aircraft spoiled me).
Old Dec 11, 2012 | 08:37 PM
Probably because only dumb ******* buy Plumbing anything in Kits and Aluminum Lines dissipate more Heat -aka Cooler Fuel.
Old Dec 11, 2012 | 08:42 PM
Nice. didnt know that about the cross section.
you dont think from all the movement and vibration,plus the heat the engine generates it will crack the hardline down the road?
wtf are you talking about?
how does a return line cause cooler fuel?
Old Dec 11, 2012 | 08:45 PM
if you run the line properly (with a stress relief loop), no it won't crack. we use them for fuel and oil on 8L Lycoming boxer engines on planes all the time.
Old Dec 12, 2012 | 02:56 AM
tepid1's Avatar
Old Dec 12, 2012 | 04:19 AM
LightningTeg's Avatar
Community Builder
Damn a simple google search was that hard?
Old Dec 12, 2012 | 07:09 AM
If you look at the original post, you will see that I have referred to those charts for the initial planning. There is something wrong though, the -10 but arrived do not fit the tubing I bought. I suppose when the tube sleeves arrive everything will clear up.
Old Dec 12, 2012 | 10:39 AM
tepid1's Avatar
The nut will be loose because it wraps around the sleeve. That is what provides your compression. You'll be good to go once you get the sleeves.
Old Dec 12, 2012 | 06:26 PM
as mentioned the sleeve tightened up the fit. i have never worked with -10 size and the tolerances really threw me a curved one.
thanks everyone!
LSEGHATCH
Sep 18, 2007 06:39 PM
LSEGHATCH
Sep 18, 2007 04:01 PM
ki11a8ee
Welding / Fabrication
Apr 11, 2007 03:37 PM
hondaapi
Nov 4, 2005 03:52 AM
RACEPAK
Dec 20, 2004 08:50 PM
