low voltage problem
Old Nov 25, 2012 | 02:47 PM
alperx's Avatar
Default low voltage problem
hi
when I was logging, I realized that I have very low voltage sometimes as seen in the picture.
what can be the problem ?
it wasnt like this before..
Old Nov 26, 2012 | 03:36 PM
TKERacer619's Avatar
Default Re: low voltage problem
I would check to make sure the ecu and the actual measured voltage is the same.
If you are only getting 11v probably a bad regulator on the alternator. I would get that checked out.
Old Nov 26, 2012 | 03:46 PM
wunfstgsr's Avatar
Loved
Community Favorite
most likely the alternator..
Old Nov 26, 2012 | 05:27 PM
turbohatch96y7's Avatar
Check your battery fuse in the under hood fuse box and the alternator field fuse in the cabin fuse box
Old Nov 26, 2012 | 05:29 PM
Do a load test on your battery with a multimeter.
If the battery has less than 12v with the car off you most likely have a bad cell in the battery.
Old Nov 26, 2012 | 05:44 PM
th3pwn3r's Avatar
Be sure to check all your connections period. Sometimes it's a bad ground that is creating problems with low voltage.
Old Nov 26, 2012 | 07:17 PM
Muckman's Avatar
Moderator in Chief
Double check the main wire from the alt to the battery. If thats fine then its the regulator. Isnt datalogging great for troubleshooting problems?
Old Nov 26, 2012 | 08:31 PM
Spawne32's Avatar
If im reading the datalogs correctly, your only having a low voltage problem higher in the RPM's, so I would check the belt, if the belt is fine, I would replace the voltage regulator/ALT
Old Nov 27, 2012 | 05:47 AM
alperx's Avatar
thanks for all the answers.. I will check ALL and let you know..
sdots24
Honda Motorcycles
Dec 16, 2011 09:41 AM
Annihilator
Oct 14, 2009 04:55 PM
BIG_WILL
Nov 16, 2008 05:04 PM
b16a1eg6
Jan 19, 2007 03:10 PM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
