limits of b20z sleeves on nitrous? (no noobs!!)
I am tryin to figure out a stock sleeve setup pushinga 120 shot. I have an ls bare block i could bore out to 81.25 or buy a b20 from attarco to tear apart. Both shortblocks will recieve bearings, block guard, arp headstuds/ rod bolts and higher compression pistons with rods. Could b20 sleeves handle a shot upwards of 100? Im goin for a two stage direct port setup
Re: limits of b20z sleeves on nitrous? (no noobs!!)
ARe you using OEM pistons and rods?
It could handle it if its TUned Correctly Ie.using a Standslone for nitrous control. Get rid of the block Guard its pointless
Maybe look into the CSS for added insurance . Talk to your tuner. Listen to him
DO IT ON ALL FOURS
Wait, if you don't want "noobs" OP, then why are YOU here? B20 sleeves can handle ANYTHING the LS sleeves can handle power wise. They are more prone to damage from detonation and RPM abuse.
btw .. not too sure if OP is running pump or race gas?
CSS will be like almost a grand after parts and install. either sleeve it or you don't. but that's just my opinion..
Posted from Honda-tech.com App for Android
noob here: i thought B20 sleeves would be weaker since its a ls block but bored bigger making the cylinder walls thinner?
It's wU to the sOLdiEr!
This photo is a damaged block but you get the idea
B20
B16-b18
I'm curious to what u mean by "tuned" right. are u referring to the amount of timing retarded and tune the AFR via. ecu or jets? if so, what's a good target AFR to aim for, and amount of timing taken away for the OP's 120shot?
I have a 35 shot im pulling about 4-6 degress of timing pending on the RPM. Im Turbo tho so things are a little different.
Good post above on explanation of Sleeve differences.
Good catch...i didnt notice. Yes you are correct tho, its clear on cylinder #2
Weird i dont see it in the front of block tho
Does look like that block is posted. Pretty much seems like it matters on tuner and block condition. B20 Here i come. Please post B20vtec nitrous time/ dyno numbers
soontohavecrx
10-31-2002 11:32 AM
