Turbo GSR Skunk2 Pro1 Cams Idle
Just a little short video I made from Saturday. Was able to get my Supertech Valvetrain, Skunk1 Pro1 cams and my JG Engine Dynamics Cam Gears installed. Ran into a couple of issues though while on the dyno and had to cut my dyno session very short. My cylinder position sensor went out, so now I have to buy a new distributor and also my oil feed line started leaking like no tomorrow! It was really bad but I think I've got it fixed today (Christmas Eve) lol. Well after I fixed the oil leak today I was able to get a video of the idle. I've never tuned with Neptune before, but I've gotten the hang of it pretty quickly. Got my 1000cc injectors to idle at a solid 900 rpm's FTW!! I am pretty excited about that as anyone that has ever had 1000cc injectors knows that it's a pain in the @ss to get it to idle even half way decent. Well try to enjoy my shitty video!!
Who is Mr Robot?
Re: Turbo GSR Skunk2 Pro1 Cams Idle
Clean idle.. oh and thank you for protecting and serving our communities
I might have to get one of your gauge holders... just debating on if I want my center vents
The first two minutes of the vid were not necessary. Good idle though, I see you have the old version pro 1s. What were your final cam gear settings srdftitan??? How do you like the cams so far? ColeD do you have the new version or old version, and what were you final cam gear settings. When I installed mine I ended up at +3 IN +4 EX. I have the newer versions that come in the grey box stamped x by the intake cam dizzy location.
Neptune's idle is great. t1 style ids 1000 cc injectors idle really well. The more fuel and iacv duty cycle you add the smoother it will become. What were your idle afrs anyway? that's why I say the first 2 mins were not necessary. No afr info, just boring stills of stuff. Forgive my rant!!
Just to clear things up...and not trying to be a dick, but there is no old or new version of the Pro1's. I had read about that rumor so i called Skunk2 and they said its just a rumor. They have not changed anything with the Pro1's in years except maybe the packaging.
Did you ever get you pwm problem sorted with the s300?
I understand what you're saying a1320. I didn't mean that the cam profiles or the centrelines changed. The markings on the intake cams are different with the newer skunk2 cams. That's all I meant. My pro 1s were marked "x" unlike the op. Mine also came in a grey box, that's all I meant A1320. No harm no foul, everything is cool.
Yeah, The bigger solenoid i was trying out from my work didnt work with S300. Ended up getting a solenoid from Locash that i know works.
SRDFTITAN
Engine Management and Tuning
14
12-29-2012 07:19 PM
cs_x21
06-25-2003 03:54 PM
