New fuel pump (now too rich at idle)
Old 11-30-2012, 12:33 PM
carlos8's Avatar
Default New fuel pump (now too rich at idle)
hi, my fuel pump went out in my ls vtec turbo,i replaced it with a new walbro 255lph, now at cold start the car stay in the 10's afr's till warm up. Nothing
was touch only change the pump.
p.s. The old one only say 255lph no brand.
Old 11-30-2012, 12:36 PM
Moderator in Chief
Muckman's Avatar
Default Re: New fuel pump (now too rich at idle)
Maybe your fuel pressure got bumped up with the new pump.
Old 11-30-2012, 12:48 PM
carlos8's Avatar
the gauge read the same pressure but i have another gauge i going to switch them.
thanks
Old 12-01-2012, 05:51 AM
turbodano's Avatar
thanks
Sometimes the return side needs tending to when you increase fuel flow. At idle is when the return side is returning the most fuel.
Old 12-01-2012, 06:13 AM
Charlie Moua's Avatar
get it retuned....
Old 12-01-2012, 07:29 AM
carlos8's Avatar
thanks Turbodano, i will try to make the line a little more short.
Old 12-01-2012, 12:14 PM
carlos8's Avatar
problem seems to be solved, changed the return line from stock to 5/16" idle
like before.
Old 12-01-2012, 03:05 PM
carlos8's Avatar
change the fuel gauge and i see a bump of 2-3 psi at idle. But with the new return line idle fine.
machine4321
08-16-2010 07:37 PM
b16b18
09-23-2008 07:47 PM
Green94GSR
08-18-2003 11:35 AM
HybridCoupe
07-10-2002 09:47 AM
GSRwBOOST
01-07-2002 11:44 AM
Quick Reply: New fuel pump (now too rich at idle)
