View Full Version : Acura Integra
- Program with TYPE R Lip...
- New England Meet...Nov 2nd....
- Acura Dealership in Bay Area California...
- LS\Vtec v.s. GSR
- Horrible sounds at idle & 1600rpm
- DC JDM 4-1 Install on an 01 GSR
- Southern Cali help???
- Suggestions on 95' LS
- Wheel theft in NYC, please help!
- how to find the electrical problem!!!!
- Hella turn lights???
- exhaust
- Which cams are better Toda,Skunk2,JUN....for there PRICE?
- B&M Short Shifter Rattle
- New or Used clutch cable for 90 integra??
- coolant system bleeding, bolt not on thermostat housing?
- Car won't start, suggestions?
- Has anyone been to import revolution?Is it worth it?
- Aftermarket Cat vs. Hollowed Cat
- tell me if this sounds like a new(er) timing belt
- 110k, want to do a mini rebuild, what should i replace?
- where to get an aem bypass valve asap
- drilling holes in a carbon fiber hood
- alternator & battery problem -- need advice
- when do u see yourself giving up teg?
- bolt on upgrades
- What kind of gas do you normally get?
- where to find cheap comptec 4-2-1 header?
- Does anyone have pictures of Smoke front Corners??
- How do you get a perfect adjustment with hids on a integra......
- LS 1/8 mile time slips
- Vafc question
- B84 engines...
- Someone Stole My "ACURA" Wheel Covers, Now What?
- Shift and clutch problems
- what tires for track and daily driven
- how many people drive in the rain with their COLD air??
- New Tranny
- Anyone know where to get Neuspeed Koni shocks??
- squeeky sound........... Annoying.
- How to tell the difference between jdm and usdm ys1 tranny?
- Max Lowering on 17's
- chicagoland GSR
- How are Azenis in the snow?
- Anybody running Crower stage 2 or 3 cams on their b18b?
- 94-97 model integras completely identical?
- Lug nut size?
- Bay Area Body Shops?
- my plugs...
- real quick question on a 89 integra engine
- Auto LS-VTEC??
- 93 integra air box modification??
- 3rd Gear ???
- Is it possible to bypass IAC & Fast Idle Thermo Valve?
- How to tell if your shocks are blown?
- anybody have a spoon flywheel..??
- Check Engine Light How To check With Paper Clip?????
- how often do pistons crack when seperated from rods?
- i threw a code 43???
- Door install .. what tools required?
- Whats Wrong Now Car Is Still Drying On Me!!!!
- Aftermarket Clutch
- Tires
- bent valves???
- Code 41 question
- LONG ISLAND NEW YORK cruise night this saturday night check it out..
- help?
- Time to replace altinator belt....
- anyone want a 3 piece wings west wing?
- insulated intake manifold gasket
- So the Apex'i N1 doesn't fit USDM Teg's eh?
- Koni Regulars vs. Neuspeed Konis
- go giants
- has anyone built a custom turbo kit for integ LS ? help me!
- 2 questions: Miami Honda mechanic reccomendations & car not starting problems
- fs: zeals function b6 for rs/ls/gs/gsr.....non-type-r
- CEL code 67
- Thoughts on a Thinner Head Gasket
- Intermittent Brake Lights
- Any negative effects of using oversized filter??
- No aftermarket support for 92 gsr Help me out
- 1995 GSR
- Will this steering wheel fit on my car?
- how to maximize the blow off sound?
- clutch pedal help
- Honda-Tech Representation
- long vs. short intake?
- Hi, I'm new here
- Exhaust!!!!!!!
- 95k Service
- is JayDM.com a reputable site?
- Turbo Kit for the GSR
- Comptech exhaust sound
- machine work on a b18b1???
- I made an in-car camera mount tonight
- is there a governor on the b18c1?
- 90k service
- Should I paint sideskirts same color as my car??
- Thread size for Integra LCA bolt??
- what's this tinny noise?
- Intergra speed
- Need help finding tranny part!!!!
- How Low Can I Go w/ 17" Wheels
- Fuel Guage or Sending Unit? guage doesn't reach full mark
- How much HP does a AEM CAI give you?
- any one know how h22 dc2's handle?
- Headlight Fogging
- vtec to non vtec?
- another tranny problem, help me=(
- How to rechip an ECU?
- h22 into a integra hard to do
- problems with integra: rattling, cruise control, mpg
- Brembo slotted and drilled brake rotors with Axxiss pads
- where is master cylinder located...?
- G3 Clock no worky please help!!!
- can someone please tell me which front lip this is?
- Need Part Number
- Question about radiator and coolant
- Problem (need help fast)
- Why the F**K does my car shake over 80 MPH
- lowering questions - please help
- rear sway...
- 94-95 LS hubcaps on a 90-93 LS, what would it look like? andy pics
- Tire Size
- 10psi pulley on a GSR
- Battery: Honda OEM or Die Hard?
- my Ls wastes stupid gas
- Eibach Pro kit springs vs Sportline springs
- exhaust for gen2???????
- comptech rear sway bar help
- Adr Rs Limited 18" CHROME
- How much compression in my gsr???
- I have 2000 GSR and CIVIC SI stock parts for sale!
- Someone tried to jack my car
- 92-95 civic Neuspeed Strut tower bar?
- dude red line in 3rd on freeway....
- Check Out This Site, WICKED!
- Do the JDM ITR headers fit good on a GSR, or a GS LS.
- car overheats or temp guage goes up when my car is idle
- Sway bar...
- cold air intake people!
- What other cars can share the same...
- What does the charcoal canister do?
- Lo Jack success
- why my teg is gay
- Help!
- major problem please help
- Got new Volks for the RHD XSi!!!!!!!
- FS: 1994 Acura Integra LS $6500/obo
- Install On New Distrbutor Cap / Rotor ???????
- Will a COMPTECH ICEBOX fit on most short ram intakes?? HELP!!
- My new ride .. best deal on a car that happened to me
- stock gsr wheels?
- ATT: Bay Area peeps need P75 obd2 Ls Ecu this weekend will pick-up
- What do you think of this 95 GSR deal?
- I need....
- Calling out HELP from all you HARDCORE INTEGRA fans!!!!
- How do you properly launch an automatic?!?
- Cams2Get?
- Online Parts Store Similar to NOPI?
- Suspension Setup - Yea or Nay
- Type R tie bar
- Clear bumper lens...
- AEM Cam gears??????
- i am in need of head
- okay BIG problem!
- need a radiator?
- DC2, DC5?
- where can i find out if my timing belt has been replaced?
- Best Performance STREET pads
- how big is a GSR header collector?
- temp guage Problems
- Got my Blizzaks
- new here with clutch tranny problem?
- Hello all new here...
- Noise from left rear wheel?
- Gsr people in tennessee please help!
- Spring problem? info will help.
- Integra rear seat has some play
- How much abuse can stock clutch hold up to?
- Diagonal Slit in Timing Belt
- Welp, I actually found the complete oem bodykit for sale...
- What can I do with my coolant?
- type R wing
- Question about stock 96 Integra shocks
- Skunkworks DC2 rear sway bar: Reviews?
- what kind of gains with itr pistons alone?
- Can low tranny fluid do this?
- thanks for all the input
- Would you buy- 2000 gsr w/ 7,500 for 14,ooo? (salvage)
- Hwlp w/ Timing advance
- which part is the exhaust donut?
- integra 99 ls ?
- Comptech Power Pro S/S Exhaust
- Springs OR Coilovers ???
- Attn: (98-01) GS-R Owners
- Will this part fit my b18a?
- Recommended Clutch
- remove engine anyone?
- radiator install
- Things i need to sell!!!!
- Very Basic Suspension Question- Want to remove shocks and coilovers today!!!
- Average price on Timing belt from the dealer?
- ls vtec/sir ii/gsr/itr?
- Fast 97 integra
- Wierd Cluster electrical problem
- any GSR with Legend or NSX caliper brake updgrae?
- I need ur opinion
- Cam Gears, Crank and underdrive pullies
- different rotors on 90-93 teg compared to 94 up?
- has anyone tried AEM brake pads?
- compression test on a motor ..
- Do stock integra springs have color's painted on them?
- GSR Tranny gear switching?
- Do you guys think this FRANKIENSTIEN TEG is a good deal?
- comparison of the 9005 with a OEM HID
- Are the primary and secondary o2 sensors the same?
- head lights?
- what is the size of the axle bolt?
- WTB 1991 integra interior hatch
- anybody have problems w/ excedy clutch
- Is this a GSR intermediate shaft? PICS
- Rubbing alcohol in gas does it work???
- got a good deal on a brand new clutch but have sum Q's
- 225 40 18 rubbing???
- Anyone else have a rattle from 7600-8000rpm?
- canards...how much do they help??
- Other than comptech, why doesnt some company just make intgera oem skirts and lips
- will coilovers off a DC fit a DA??
- B18C1 rebuild completed - moobie
- Battling Rattling?
- help me with turbo engine
- Could any LS owners feel the difference with cold air intake?
- touching up the interior
- H22A into 90-93 (DA2) series Integ's
- 91 teg arm rest jdm
- 94+dash in 91 teg????
- Cam cover seal
- GS-R question
- NX wet on gsr...
- Does anyone make thinner headgaskets for B18A1/B18B?
- teggy n00b
- Problems With My Integra How Much to Fix??????
- fixing dent header in socal...
- anyone know...?
- comp.. and smog
- skunk2 stage1 or stage 2?
- Custom B Pipe?
- G3 Owners - Is this how your windshield is like too?
- Anybody know what a JDM GSR front end looks like?
