View Full Version : Acura Integra
- Does buying a cheap radiator cap and thermostat affect performance?
- 94 and up B series trani bolt to 90-93 B18A
- What do I need in my GSR motor to handle nos?
- 2.5 piping
- comptech front lip
- which sterring wheel?
- how does the Skunk 2 manifold sound on a gsr?
- 93 GSR rims
- Teg Weights?
- Fuse box layout for Integra (Si or Type R)
- Why do I keep blowing this fuse??? (pics)
- Wheres the ECU?
- CEL problem
- Help Me P0505
- Gen 3 Integra: Side marker wobble fix?
- would this be cool?
- what should i do with my motor?
- Have $500 to spend on my car
- Spring Question???
- Quick Question
- Crashed my baby!
- Cost of replacing syncro in GSR tranny?
- Long Term effect by HID
- 89 PG7 integra ECU pinout
- If you have a 100 shot of nitrous or more on a GSR
- Will a Rear DC2 Strut Bar fit an EK HB?
- Are my stock LS injectors going to be big enough for
- HELP!! question with swapping a b18a to b18b
- K2 HID conversion
- Question about c pillar bar.
- Fenders from 94-97 same as 98+ correct?
- front swaybar
- #1 welder in my book, roll cages, jdm conv & all
- My parts are now for sell
- What kind of cat with DC JDM 4-1?
- control arm bushing replacements
- Master cylinder chatter???
- Integra Frontend for sale!!
- 2.5" or 2.25" exhaust diameter?
- mugen headgasket vs. oem h.g. big pics!!
- valve adjustment
- Want to get an idea...possible JDM front end GSR for sale...
- adjusting the tranny......will it work
- Coilovers vs. Springs and Sleeves
- Will B16 cams work well....
- AEM pulley kit on integra / install
- Which tires? Yokohama AVS ES100, Nitto NT 450, or Toyo T1-S
- are these 1/4 mile times okay?
- steering wheel removal help
- They Got ME!!
- Dash swaps?
- Bumper removal?
- Daytime running lights???
- i want exhaust, not quiet, not loud
- importance of 60k service
- idle problem.....runnin rich
- alignment question
- Want to know other GSR times w/ NOS and what Shot.
- would this work as an oil catch can for my GS-R?
- best aftermarket pistons?
- Quick question!!
- 95GSR 4-door with leather
- H-T members convince me to keep my GSR
- Turbo Kits
- GSR- upgrades
- Integra vs. Accord?
- Need advice...
- Got a tuff decision
- different???
- about the engine bearing colors..
- HID installation
- Need help installing stock suspension. (Did a search)
- opinion: Tanabe Sustec Pro S-S
- was it a good deal?????
- Selecting volts, water, temp, oil, etc gauges
- OCtane Booster
- H & R sports with tokico blues, too low for 17s??
- how long is enough to install turbo
- Integra Seats shipping problem
- Compression test results...
- BRAKE pads that don't give off a lot of dust!!?
- anyone in colorado ever do a honda-tech member meet?
- Can a Motorcycle muffler work?...ideas/suggestions?
- I need an axle back i think
- friend's 4-door ls antenna stays up
- Clutch install question??
- What is the max amount of miles a 94-97 GSR should have for a turbo
- the ultimate sleeper
- Radiator replacement, DIY or Shop for the best results?
- Where the hell can I buy TOYOS?
- 90-91 vs 92-93
- Sand bags in the trunk?
- fluidine radiators..
- Who owns this GSR?
- integra side moldings....how to cover the holes?
- Radiator / AC question.....
- which magnaflow.
- how wide is the 01 LS wheels?
- Please post pics of rota/mugen group N installed.
- Any way to replace the rear quarter window trim?
- Chrome Window Accents
- b16a siR1?(help please)
- SRR lowtie sway bar
- My Crazy Thoughts
- For those with Ground Controls
- Honda Factory Performance
- Integra GS-R Stock Suspension, Need Help?
- J's Racing Intake.
- Parts that are Urban New York City tough
- 98 ecu and dizzy for sale
- Interior Help
- NEED help!!! desperate!! integra dies while driving, #3 spark plug wire popped oFF from distributor
- gutted pics?
- Is this a good deal for a GSR
- Optilux bulbs
- building motor!!!
- Metallic Scraping Sound
- Headlight help...ASAP!!
- KYB GR2 silvers can they handle a 2''in drop with a smooth ride.
- How can I tell if it's an ob1 or obd2 cluster
- If you had 150k on a GSR..
- Front end question.. styrofoam piece?
- height diff between type r suspension and gsr
- 4 Door speed
- Honda-tech meet LI, NY
- Coilovers?
- cambet/washers?
- Energy Suspenion Sway Bar Bushings
- Automatic Teg worthless?
- Agh!! Someone help with this damned fender!
- Pics of Integs with Fog lights
- Inseide light goes on while takin fast corners?
- E-Brake lights fluctuates
- Found an Integra... buy?
- Selling Integra GS-R
- Horn and Cruise Control
- taking out the back seat
- Tanabe hyper medion(review)
- ls auto turbo times
- ctr cams on gsr?
- Brake Rotors
- can someone please carfax this vin for me!!!
- HELP needed in NE Indiana*SUNDAY-11/24 ! ! ! ! ! !
- quick question
- Weight What Weighs More???
- throwing codes..
- What do You Guys Think About H&R Race Springs on a 99 Integra??
- some jerk keyed my car
- help
- PCV valve replacement
- 45 PSI = Boom?
- Anyone have a pic of a G2 integra bumper support?
- Sound/Video exhaust clips
- what psi for azenis tires?
- Time for new shocks??
- Should I buy this integra?
- 4040 brake proportional valve
- any 4 door tegs with a turbo kit here?
- 99-00 Civic Si Lip On a DC2 Integra
- Help needed quickly!
- How do you guys clean your motor? I don't want to jack anything up.
- integra body kit with cut sportlines?!
- leak on passanger side ??!??!?
- After market website?
- WhAt Is DoInG tHiS?
- Does this sound like a good price for this GSR?
- Best engine to turbo??
- Whats an OK price for a set of almost brand new GSR rims?
- Alternator Replacement? easy or hard to do?
- good buy????
- 2nd gen vs. 3rd gen
- Complicated wiper question!?
- O2 Sensor HELP
- Anyone out there rockin KYB GR-2's
- GSR + mud = problems
- Spark Plug wires and Distributor order of instalation HELP!
- T3 oil inlet flange
- B18A into my 94 LS 4dr
- Sound/Video Exhaust clips
- Master Cylinder ?
- the wind
- Removing VTEC badge
- b18c intake manifold
- injectors
- shocks?
- How Do I Remove?
- To you weight reduction whores...
- finally tuned :^)
- JDM Spec specials now fully updated!!
- inTeg show off erz methods
- Front end conversion...
- Eibachs or H&R springs whats better
- Those w/ tokico illumina's 5 way adjust. shocks
- Anyone know why one side is lower than the other on my teg!
- Sleeve & Spring Coilovers
- Code 41 CEL. Please help
- Anyone Using Kumho 712's?
- anyone w/ CATz ZETA system?
- Leakage in Trunk
- which cams are better??
- where can i by a HKS Hi-power Carbon fiber, just Muffler that is 3" Dia ??
- Brake Problems
- I weighed my car
- Wow I am lost
- tips for 94 ls integ???
- integra leaking oil?
- Headers...???
- a-1 only part of label i can read on 91 integra with b20 can anyone tell me ??????
- Crazy Idle Just Disapears?
- Some car problems, need help figuring out
- NJ/NY people....Anyone need a spare GS-R Swblade rim?
- Changine Redline?
- 94-97 oem foglights worth?
- Oregon/Washington meet
- Does anyone know where I can 4 door Type r Interior???
- Different tires placement
- H22A throttle body on GSR intake manifold?
- Brake Problem?
- Heated mirrors?
- why don't i have permission to post in the classfieds
- need help/drive axles
- Keep generic CAI or get akimoto funnel ram III intake?
- tire balancing
- anyone know what this is?
- swapped exhaust with my friend today...but um..he ran my car up on the curb
- People with coilovers
- What would be my next best mod for the money? anyone?
- My GSR is using oil
- H&R Race
- Any have dunlop FM 901 tires?
- ctr tranny in a gsr?
- ecu codes??
- Offset Q
- JDM dc header
- Integra Stock Cd Player?
- which tire to buy: kumo 712 kumo 711 or yoko avs es 100's
- swaybar
- Anyone have experiance with hankook tires ventus k102?
- Anyone with a JDM front end...
- power steering pulley..all the same?
- i have a big problem.
- Check your car for Recalls: Attention Teg Heads!
- Front Bumpers
- ITR 5 lug conversion
- do itr cams just bolt in gsr head?
- What is the lowest front lip u can put on 98 Integra???
- Sprint Camber kit $200 is it worth it.
- Nov.24th Honda-tech meet read on ...
- 02 sensor voltage range?
- Competition more and more
