View Full Version : Acura Integra
- ctr cams or itr cams or skunk2 which are better?
- cruise control not working
- a/c fan not coming on?
- ecu tuning help!!!!!!!!!!
- auto to manual swap question
- gsr compression help!!!
- swapped gsr vtec not kickin lke it should...
- Shooting ecu codes new help please!!
- jdm front end light size
- Car is missing and running rich
- radiator fan thermo switch?
- Can someone tell me what the following reads?
- Nedd info on how to re-dye seats
- Need Help w/Info on how to do a 5 speed convdersion!
- Maintenence Required light on(1995 Teg ls)
- Distributor problem!!
- 88-91 Short shifter in 90-93 integra
- B18c1 burns whole oil tank in 500 miles!! Need help!!!!
- brakes!
- Difference Between DA And EF Motor Mounts?
- how much does a complete block weight?
- LS Vtec problem
- fuel injectors & camshaft
- integra body swap questions
- Skunk2 Pro series intake manifold and throttle body
- 94 GSR Engine Timing Chaos
- Is it me, because the GS-R doesn't feel as hard as it use to feel?
- INTEGRA with a b20b motor??
- Need HElp! my signal lights aint working
- Bolo: Chicago, stolen 1994 ls jdm front
- To All the INTEGRA owners who had their car stolen
- Newbie.......Need Help!!!
- bad iacv
- head gasket
- Do you torque a aluminum flywheel with factory torque specs?
- B20Z into 94 integra LS ***STOCK*** What ECU to use
- How to take off antenna???
- Obd1 jumper harness, please help
- distributor question?
- ► Humbly requesting your support...
- How much is my DA worth?
- Green 94 Integra STOLEN!
- 92 integra won't start
- Help w/ Drivetrain...
- integra.LS/GSR evo2 exhaust problem
- Need front headlight kit for 91 Integra...
- Front Bumper
- 95 ls Alignment
- Coolant flush
- 98 Rear seatbelts
- Low Oil Pressure
- Lets talk integra traction and how to get it
- 98 GSR with low compression
- Glove box question
- DC2 black integra stolen. Miami, FL
- 94-97 si-vtec fogs
- no start?
- stock 99 gsr blade tire size
- arp headstuds help
- OEM TSX HID Ballast Input Polarity - Help Needed
- will a 96-99 Ls motor pass smog on a 93 integra?
- ELD code 20, what does it have to do with EM
- Spring release fork
- 00 integra idle problem
- Are Da Lca's the same length as Eg's or Type R?
- overheating?????
- car don t start
- 98 integra rear window visor????
- gsr engine question
- How can you tell which crank it is
- Fuel issue
- 2001 GSR. I need to find a catalytic converter...
- after swap problem, fan
- Godspeed radiator cap questions
- Looking into buying this car! Help
- lexan windows did search but no luck
- Injector flow rate for '96 RS?
- surging idle caused by ECT?
- H22a4 into 94 Integra
- b16a valve lash adjustment
- LS/VTEC with no VTEC!! Please Help!
- ipod connection on stock headunit
- New clutch, wayyy less effort to push clutch in now?
- Crower $6 for shot peening/peened rods
- jdm itr 96 spec cluster into a 98 ls
- Ground Control Spring Rates help... Mixed use setup
- kocking/vibration noise when engaging clutch
- ls crank or gsr crank
- 91 da axle
- da help
- help!....engine cutout
- Rough Ride!
- DA integra injectors???
- avid steel mounts???IDK
- 90 Integra fan help
- transmission rebuild or swap?
- irratic idle overheating p0700 p1783 obd II codes
- have anybody change this rubber thing before?
- what happened to my clutch???
- dsm injectors?
- engine wiring harness ?
- Water leaking just behind glove department
- Group buy TDM x bars
- VSS? Or Speed Sensor
- 90-93 da info
- how do i remove speedo cable!!
- Headgasket problem. b18b1. PLEASE LOOK!
- Wheel bearing size
- Motor Problems
- Waste gate questions
- Good price for a gsr??
- integra micota hid bulbs
- radiator question
- Any Ideas??
- CV Axle
- do i have a bad head gasket?
- 94+ ls tegs
- Shifter bushing installation costs?
- Red JDM FRONT INTEGRA Stolen
- NEED so i can get the b18 in
- ABS question
- fuse box problem
- I need help...
- B18C1 knock sensor questions
- Help b18c1 Block Oil squirter ? I need, + O-Ring
- DA 93 integra swap
- what dizzy nd ecu should I use?
- Tires...???
- Wierd Vibrations
- 91 integra
- will EG suspension fit on a 92 integra?
- 98 gsr with 95 gsr motor
- gsr air fuel ratio
- I have to go to the referee
- Question about stock fuel pressure on gsr
- vtec Wiring
- HKS and Blox????
- 91 integra motor mounts
- Mugen strut bar. Real????
- Pipe diameter size if AEM or INJEN SRI?
- 92-95 civic exhaust on dc.
- Oil evaporating like crazy on a fresh rebuilt head. Need help
- putting on my type r side skirts...need help plz
- Possibly burning oil? Also, stumbling on acceleration..
- ABS Light
- 89 ls fusebox diagram
- bad engine noise
- Having Starter Problems.
- Quick question pleas help!
- 91 acura 2000 rpm beeping noise.
- Success on ABS Conversion (2nd Gen)
- Help me install my halo lights please!!!
- Starter problems
- Transmission question
- boosted teg traction bar
- Getting some new wheels need Input
- 1996 integra gsr OBDII engine check light p1381 HELP!
- Collison parts
- Quick Overheating & Steaming
- 94 gsr coolant leak
- will this work??
- crv calipers and rotors?
- Help! 94 teg brake problem!!!!
- will a GSR throttle body fit a b18a1?
- stripped block
- 94 Teg With GSR Trans Problem
- 94-97 GSR 4dr exhaust fit my 2000 LS 4dr?
- what are the best cams for my set up
- need help!
- **stolen 97 integra ls bay area**
- lsv throttle body
- Kill Switch for a 98 LS?
- Which Acura site do you use the most on purchases?
- New engine start up
- Wussp Honda-tech pPl
- knock sensor install
- Need some wheel help. Can I run these wheels??
- help wit part #
- 90 LS, GSR Engine, Throttle cable
- Resurfacing a flywheel?!
- Aftermarket oil sending unit??
- Vtec selinoid!?!
- help im stumped
- my new car
- 200k mark....
- Weird power door lock issue...
- Gear Box Is Stiff
- timing belt
- Does anyone know?
- 99-00 si rims
- Question about seats
- do 92-95 civic shift linkages bolt straight up to 2001 integra gsr?
- Project gilapi DD
- 94-97 climate control removal (ive searched)
- Skunk 2 intake manifold suggestions
- gsr tranny making noise
- help 98 integra gsr
- B18c1 or b18c5
- B16 oil pan fit LS?
- Need help my 01 integra is bogging bad!!!!!!!!!!!!!
- Not sure whats going on???
- hypothetical dart tall block build
- Price for motor
- Spring weather in Feb. Night mini shoot.
- i need help with hazard light problem
- My suspension.....
- B20 block Good for a B16a vtec
- Question about TDC sensor (91 DA)
- cooling issue
- I need to know what code 8 is
- JRSC on LS integra
- Transmission Problem 5th Gear and Reverse
- 94 integra what temp should my fans come on
- which A/T fits my 2000 LS hatch?
- gsr msd cap and blaster ss coil question
- suspension question help me out
- Question for those with a JDM bumper cover, and USDM bumper
- sugestions on intake mani and throtle body
- Need teggy parts...
- oil pan question
- valve tool that works
- the difference between these sides and the other ones
- Custom Exhaust in SoCal...Help
- problem with my H22a Integra
- need help with my 99 integra
- 92 GSR questions
- H Brace Install Problem
- overheating 92'b16a TEG
- Rebuilding a DC2 GSR
- Removing Rear Side windows?
- 92 integra boost or vtec??
- Keep blowing fuses
- 96 Ls B16 swap...keep tranny or go full engine swap
- 93 integra axle removal help
- When were mesh wheels first introduced?
- VTEC motors smoke? GSR stupid question.
- GSR Should i sway the tranny?
- Emission system problems? 99gsr??? Helpp!!!
- Calling all 2.0L B-series owners....need California smog numbers
- Any pics of a tint srip on the windsheild of tegs?
- camber kit installation
- LS Pistons and Rods
- stock quarter mile time
- GSR cloth seats ??
- 1992 integra b16 wiring help
- wekfest is San Francisco
- Need Help: 2001 OBD2 GSR Wire Harness | 1996 Integra
- LS Vtec
- 98 integra gsr cel code 67
- 1995 GSR engine smokes under load.
