View Full Version : Acura Integra
- how do i go ls-vtec?
- help with lowering car
- Part number for Eibach Pro-Kit
- Screws stuck in door jam...need to adjust door
- engine bay washing?
- Whats the proper way to convert a 2000 gsr disty to obd1
- what type of clutch do i use?
- hid tsx, ebay pnp kits...help
- what wheel size best for integra?
- HELP JDM HOODLATCH JUST MESSED UP ON ME!
- eibach sportline for dc
- b17a1 motor
- dc shocks on da?
- Someone Please HELP!!!!!!
- Timing light issues
- Questions on b20 vtec boosted.
- gsr p28 chip
- optional sides and rear weatherstripping question
- is this possible?
- jdm power folding mirror
- RS,GS,LS
- 95 b18c1 short block build
- where sells honda mtf online
- Need sideskirt removal help please.
- Best way to tap into my valve cover?
- 99 civic si power steering pump on 92 integra
- Shake it shake it shake it shake it!!!!
- alignment problem: toe in
- arp gsr bolts question
- Clunking from passenger side front suspension..need ideas
- What years of exhaust manifolds would fit...?
- quick 91 integra LS question
- Getting power steering pump to work B18c1 in DA body
- RS or LS?
- 4 door exhaust question
- DA with gsr fat 5's?
- Misc. turbo stuff for sale
- Picture Request:!: ARC intake Chamber on DC2, well on anything really...
- main relay question 1990 integra
- 94 GSR Engine Start
- Wheel Bearing?
- Car bogging and Tach jumping
- DIY/how to install turbo kits? i know there was one on HT
- Will a 96-00 rear 4dr door handles fit a 94-01 integra 4dr front doors?
- integra gsr
- LS/VTEC Kit removal
- 1994 acura integra ls electrical problems
- ITR Spings/Struts & LCAs on 98 GS-R
- GSR Manifold sensors?
- What other parts do you change besides timing belt?
- i am going b20 vtec what do i do bore it or sleeve it ????
- ls/vtec oil line
- Fuel pump diagram?
- Timing help, please.
- Test Your Electrical Skills (Heater/Cooling Fan)
- Clutch replacement procedure?
- Need help! Finding source of my problem.
- Which seat rail would I need for theses?
- skunk2 intake manifold question
- b20 bottom end?
- what to go with for a cat/test pipe?
- if i remove my door panels do i also have to take the window with it or no?removing door panels
- 91 Ls..w/ b18b motor...wont pass smog
- spark plugs and spark plug wires?
- Problem: Code 92 flashing - Evaporative Emission Control System Insufficient
- J's Racing Fender Brace?
- Changing final drive gear? help in acceleration?
- best size tires for 16's
- ► Official Integra Picture Thread** ( No commentary, read rules before posting) **
- fuel injectors
- Help, failed smog test only
- b18b1- more power without bolt ons?
- just got a ls block and the crank will not move at all
- 92 gsr overheating....
- Low Idle problem
- B18C1 210-35-210-210
- cd player cut off
- Atlantic Used Car Parts in Lowell MA
- Help with Window issue plz
- spark plug grip handle broke
- Whats the difference between the RS and LS?
- what kind of gains and gas mileage could i get from this setup??? PLEASE READ!!
- ?: 90-97 Accord Springs on 91 Integra?
- Braking: What's the best way to do it?
- What's the name for this?
- Questions for mounting ITR wing.
- Solution to the P0300 through P0304 Codes
- Gas mileage
- BIG!!!!!! headlight problem
- can an integra run on e85
- Teg dissed on national television??
- clutch issue
- AEM Fuel Pressure Regulator
- wat are the best mods for a stock ls
- Engine ID location
- Where can i get a single mount?
- differences in sensors from obd1 to obd2
- car wont crank...please help
- 94 integra obd1
- starting issues
- ? regarding putting in a hydro teanny in my DA!
- spacers for rims?
- electrical...
- Need help using this site
- Is my Clutch gone?
- tps problem! Help
- Sorry im a noob...tried searching. will a header off a vtec engine fit a B18?
- Headlight indicator 'ding' not working
- Studs non buyable?? need to start Dremeling! help me find...
- 3.0 VTEC V6 in 98 Integra?
- Another MIA
- where to get a T4 manifold?
- Question on 1 piece headlights
- b16 bottom end for $350..good deal?
- new to hondatech shoutout!
- Skunk2 Intake manifold?
- motor mount inserts
- Car won't Start after using it...??
- 91 integra b16a2 sir II swap
- integra with front mount intake system?
- 2 step help!
- 91 integra OBD0 LSVTEC help
- sem paint
- buddyclub spec 2 vs spec 3?
- axle brand suggestions?
- tuning an integra
- Black Smoke
- suspension help
- aftermarket seat w/ stock seat belt
- installing suspension! one quick question?
- cd player don't work!!
- Water Pipe all the same?
- 92 integra ls automatic stall when slowing down to stop
- Anybody work for Acura???
- difference gsr vs type r pistons
- Need some Tokico HP struts
- interior carpet help
- best low price DA exhaust
- Custom Exhaust
- b16a in da integra
- oil in turbo manifold
- need some help with rod/main bearing. CANT DECIDE!!! suggestion would help!
- Main relay probably?
- JDM Motor wit USDM Ecu/Emissions
- 96LS Struts on 2Dr same as 4Dr?
- Noob question. Head removal.
- what rod/mail bearing should i just
- Is there any way that this intercooler piping is going to fit?
- quick question about O2 sensor
- Magna flow catalytic converter 2.5" inlet/outlet problem for Apexi WS2?
- Question for you teggy owners
- K24 powered DA...
- Turn signal's dont work?
- 9000 rpm on ls vtec!?
- Dash Harness HELP!!!!
- Removing the distributer and timing Question.
- ingalls camber kit (pics)
- Installed my tranny, not sure if it went alright....?
- Help with door handles
- Apex'i GT-Spec
- exhaust/emission issues
- help
- B18C1 With B16B CTR Head???(Question)
- problems with gsr
- Myth buster, bust this myth
- best exhaust for a DC2??
- Shaking Problem
- help me out compadres
- BUYIN NEW TEGGY.. SPOILER QUESTION
- where do you get this plate and this bracket from?
- gsr tranny clicks in fist gear hard pull
- Cruise Control
- Cross drilled rotors?
- hard shifting
- my new baby
- bypassing the fitv
- Car wont start
- Where to buy JDM ITR lip.
- New here: Advice & comments welcome!
- dc sideskirts on da
- turbo b20
- question on glass
- is it good for my engine
- car wont start(no fuel, no spark0
- steering problems
- quick swap question
- Engine throtle and a/t overdrive
- ls/v question
- 94 ls/v?
- All motor GSR???
- difference between comptech and jdmshit lip
- pr4 help !!!!!!!
- need help launchin my geezer..
- Tach jumping ?
- lightening trunk! how?
- ITR Pistons into my GSR???
- help with a axle problem
- CC of different heads.
- Acura 90-93 suspension question
- Bottom Engine Mounts Gone, Really needed?
- Auto Tranny is getting jammed
- crazy noise.. could be ps?
- suggestions on a good daily driver coilover?
- 94 GSR wont start unless i push start it
- Tan to black interior swap, Need advice
- "i hear dead people": suspension squeaking on DA
- engine wire harness
- clutch feeling
- shifting gears problem!!
- interesting question for the buddy club exhaust owners
- Can someone prove me wrong: B17 Header Question
- new to hondatech
- got a state referee ticket got some questions plz help
- cutting off partof jdm type r catback muffler
- Pro Series IM....
- need help with Torque Specs
- tie bar problem!!
- bad rear engine mount
- Wheel and tire sizes
- b20a5 intake on b18c1
- Sideskirt Paint Question!!
- ITR exhaust with test pipe
- rod bearing ?
- ecu question???
- bad lower ball joint driver side question
- Intake setups - what is your opinion?
- new headlights for dc4
- DC2 JDM ITR front end conversion HELP
- What oil to use?
- Type R front end swap!!
- replacing quarter panel.
- Comptech rear lower tie bar?
- Steering Upgrades
- What is this?
- Clutch Choice
- wideband controller ?
- is this a good deal or am i getting a shitty deal?
- broken fuel rail stud...
- If this DA was yours, what would u like to see done to it?
- Torque Spec on Transmission mount?
- c- pillar question
- New member....and his DB
- gsr lsd
- Remove the back seats
- 91 da teggy brakes on 94 gsr teggy
- Exhaust sound got louder?
- Cylinder Head Reassembly [B18 LS] : HELP!
- G1 integra swap update (since last one was locked)
- is it worthwhile to swap an obd1 b18a/b into a 90-91 DA?
- 92 gsr rebuild
