Anyone else have a rattle from 7600-8000rpm?
Old Oct 21, 2002 | 07:37 PM
jabroni95gsr's Avatar
Default Anyone else have a rattle from 7600-8000rpm?
My Gsr has developed this rattle that presents itself around 7600, and then gets progressively noisier as I approach redline. It seems like it could be cat rattle from the heat shields, but maybe the shifter?
Chime in if you have had a similare experience.
thanks
Old Oct 21, 2002 | 09:17 PM
akhom's Avatar
Default Re: Anyone else have a rattle from 7600-8000rpm? (jabroni95gsr)
yes same problem always wonder what it is.
Old Oct 21, 2002 | 09:27 PM
VaporTrail's Avatar
New User
i got that too, it seems to dissapear when i hold the shifter in gear more. I think it's probably in the shift linkage, just a loose something or the other. Do both of you have the mount inserts? I do and figured thats what was causing it.
Old Oct 21, 2002 | 11:50 PM
akhom's Avatar
Default Re: Anyone else have a rattle from 7600-8000rpm? (akhom)
I do not have motor mount inserts.
However I have ES shifter bushings
Old Oct 22, 2002 | 03:16 AM
ragejed's Avatar
Es bushings rattle my shifter too. im use to it. prothane motor uppers here I come
Old Oct 22, 2002 | 06:42 AM
Default Re: Anyone else have a rattle from 7600-8000rpm? (ragejed)
no, i haven't touched my shifter or the bushings...do you think that could be causing the problem? where are you getting the prothane bushings from?
Old Oct 22, 2002 | 08:56 AM
ragejed's Avatar
http://www.suspension.com
Mark671671
Honda S2000
Oct 26, 2012 08:26 PM
HondaCivicSE
May 12, 2011 03:26 PM
SoullessJapaneseMachine
14
Apr 11, 2010 11:21 PM
zenon8890
May 1, 2006 01:08 PM
rasta420
Nov 25, 2004 09:57 PM
