View Full Version : Acura Integra
- clutch has no pedal pressure!!!
- LS TURBO SETUP
- where are my o2 sensors?
- Diagonosis of B18C problems
- K20 In the DC, PICS!!
- Alternator Problems
- ECU Code 13
- ITR Bushings, Upper Mounts???
- GSR vs LS vs civic si brakes
- WTB: 94-01 radiator, hood, black front seats
- i need some help! 94 Integra LS
- -----LS owners chipping their ecu?------
- fan switch or relay?
- coolant leaking ....
- Question for the mod who locked the following thread...
- Hitting Fuel Cutoff
- Quick question
- Help!!! Temp Gauge Problem on GSR
- Idle Air Control Valve (IACV), Bypass (IAB), Fast Thermo (FITV), HOW DOES IT WORK!??
- front end 2 and 4 dr same?
- Best prices on new clutch
- Need suggestions for a Throttle Body
- THEIVES ARRHHHHHRHHHH
- um..is this normal?!
- Hard to get into gear (all), no grinds, any help appreciated
- grrr bolt!!!!!
- Car has'nt started in 2 days --help!
- Car has'nt started in 2 days (alternator, distributor, timing!?)
- ~~Anybody want exhaust?~~~
- *Video* Snow Drift Continue. Did i say DOmmit?!? 12mb..
- Is patdemps around? (someone in Classifieds looking for him)
- What to do...
- Need some help!!!
- anyone have a B20?
- 93 teggy rear wiper removal
- Anyone know what happened to G2IC??
- JDM ITR doorpanel question
- Need Help Installing A JDM SRS wheel on a 95 GSR
- where are my O2 sensors? 1994 GSR
- GS-R Vtec swap into a LS
- ? for those who have removed sound deadening
- my stock LS rods with ARP's, hold 8500 no problems?
- How much would you pay for this ys1 tranny?
- How do you tell a Short vs. Long block?!
- Body kits
- Oil change (bolt sealing)
- Anybody have replica ITR lip?
- How much and how hard is to find a hydro LS tranny?
- Integra Idle Help
- overheating
- too happy :D
- help air fuel gauge install??????????
- 98+ Conversion
- Question
- o2 sensor sending wire
- axle quiz for you axle know-it-alls.
- ahh noisy head!
- passenger airbag tray?
- Really need help!!!
- Stay with the LS or move to a Type-R?
- Help What Motor... H22a (jdm) or JDM Type R
- help me out with this little problem
- p30 pistons
- B18C5 into a DB1?(or DA)
- Free CEL light with install of RSR EX MAG
- AEM Cold Air Induction System
- Diameter of Tein coilover springs and GC coilover springs
- first car
- obd0 conversion to obd1; harness prices and wtb
- h&r race springs with 205/50/15
- difference btwn gsr and itr crankshaft?
- does the cat need hangars?
- dropzone springs
- tanabe racing med
- Need someone to look at their gauge cluster really quick!!!!
- my headlights have condensation, how can i fix that?
- My Gsr isnt turnin over, may be ignition problem
- how do u adjust the headlights?
- Clutch for b18c1
- smog question...
- OBD0 ECU
- Will Civic Coilovers and shocks fit in my integra??
- Looking for a hand (PA/MD area)
- How to tell which ys1??
- obd2 head bolt onto a obd1
- Exhaust System Question
- Converting Body To Type R
- Tail light gasket
- Clicking when off of gas
- 94-97 door panels in 98-01 integra
- skunk2 control arm....
- Reliable way to 13's for daily driver
- breaking and city lights?
- horn doesn't work
- 2000 gsr to obd1
- Exhaust install
- who makes this kit
- Opinions on injector leak..
- 1/4 MILE TIMES ON LS ON THE BUTTON?
- Help me find the topic " how to convert R front end"
- Tire Size Question
- PS pulley question
- type r muffler?
- Epitaph to Stolen GS-R Story
- GSR met it's demise the other night...
- window problem
- Check this out
- block heater ??
- konig heliums vs. gsr blades
- Best offset for 16" Grids?
- Speedometer not working???
- notchy shifter feel
- H-series or B-series for 4dr Integra ??
- Does switching from p/s rack to non p/s rack require alignment?
- skunk2 im + gsr comptech intake/icebox
- question about intakes
- Which suspension?
- Comptech Ice Box
- 98-01 front bumper
- seat not rolling foward
- halos???
- tranny problem???
- Strange Situation
- auto to 5sp...
- pulls to right....
- 4-2-1 or 4-1 headers for gsr motor...dc sport ones
- Just to make sure THis is the full exhaust system right Link Inside
- jdm dc 4-1 header vs usdm dc 4-1 header
- how much would u spend for a b18c5?
- her is the link
- 2.5 inch - 2.36 inch considered a bottleneck?
- are first gen JDM b16 cams same as 99 si cams
- ls/rs/gs??????????
- GSR Wieght??
- Any Thunder Grey Metallic teggy owners out there?
- Spoiler weight trunk whatever weight
- Has anyone tried Rhino Ramps???
- thinking of buying a 96 4 door RS, need some advice
- NEED ELECTRICAL HELP PLEEEEEASE!
- help identifying ecu (serial #: 37820-pr4-a60 )
- 4dr integra seats in 2dr
- OVERHEATING!
- Idle/Choke
- Tip&Muffler VS Canister Exhaust
- type r
- Fuel Line help!!
- spoilers
- socketed ecu with hondata
- is there such a thing as a gsr auto???
- will a JDM clutch master cylinder fit in a USDM DC2?
- greddy header on an ls?
- Interchagable parts for 90-93 Integras
- DC headlight trick???
- Rebuilt Brake Capilers
- Oil Pump gear
- Air con whines with Revs
- Are my JDM headlights authentic?
- Attn: VA/MD/DC area
- Anyone else want a 4000hp Integra!!!!!
- how much is this integra worth/what should be offered?
- I am bored, so I am asking dumb questions
- converting to rhd
- anti-squeek washed off?
- 90-93 four door question
- header.. but no exhaust
- taking apart 2pc rims?
- B18C Valve train differences - Auto vs 5 speed
- lsvtec spark plug gap? b18a1 specs or b18c1 specs?
- Distributors, Are they compatible?
- OverHeating, High engine temp when idle
- Which Clifford Alarm???
- axle nut removal
- gsr vs b16
- im looking for a new exhaust... your imput please!
- diff in years of itr trannys
- Please Help (Brake noice maybe?)
- Anyone got the RS-R GT2 catback on there teg?
- will dents on ur header reduce airflow?
- Stock LS Bore size??
- HELP b20 head
- urgent help needed from my fellow integra ownerz
- belts help?
- looking for video of a jdm gsr engine in action... anyone help...
- Did some basic maint on the teg.
- need opinion/info on suspension parts
- Grounding Question
- n00b.. sorry can't post in OT or whatever yet
- help with gauge install...
- my car eating alot of gas? help?
- Weight
- Skunk2 IM and throttle body
- need HELP..MAJOR tranny problem
- Car wont keep battery charge?
- Idle Problems
- Traveling Long Distance With teg? (NY Residents encouraged)
- Whoa whoa whoa alright...
- under or overcamming this setup?
- 94 gsr into 99 gsr?
- DC2 picturessss, give advice!!!
- smog check w/: intake, exhaust, and headers
- Greddy SP2
- How do I get the seat belt light to go out in my DA?
- 98+ Hole frontend 300$?
- Just installed some H&R race springs on my DC2 (pics)
- Hey Guys, New here and have a few questions.
- Best tranny for b20z
- RATE MY TEG<><><>94 ls
- how much for rebuild?
- what exactly does a vafc do and how to use it??
- Will a spoon N1 muffler off an eg fit a dc2?
- Which Motor Swap
- My Apexi N1 review
- 74hc373n is it really needed for chipping p28
- Summit Battery box install: help
- whats the difference between 94-97 and 98-01 front lip?
- is this any good?
- High Idle problem
- Crower 403 Stage 2 Cams In A LS
- AC Filter
- h22a turbo teg, radiator?
- slightly bent rim, need opinons
- how to advance timing?
- Type R cams causes detonation?
- Tranny Removal and Install
- b18c1 and b18c5 bottom end?
- help disntingushing DA and DC knucles !!!
- can an ES OVAL universal muffler on an EG fit on a DA9?????
- What's the lift and duration for stock LS cams?
- I got my block =0)
- Tanabe Pro S-0C Coilovers or Tein Basics?
- 94-01 4dr fitment
- New Member W/2nd Gen Teg
- quick tranny question
- removing header heatsheild?
- 91 GS engine problem please help
- 92-93 GSR cluster in 90-91 integra...
- Short Shifter Brand?
- B16 swap w/ an LS transmission
- how is this for a streetable setup hopefully smogable
- aem fpr seal / o-ring
- 96 gsr to 98-01 Conversion
- transmission fluid
- Timing belt w/ LSvtec
- itr 5 lug hubs
- Car idle stays at 1100 when braking....
- itr tranny bought , gonna install in 94 gsr , anything needed to make it work ?
- 94-00 LS and GSR Header
- i was wondering about type r final drive
- b 18 a1
- Do-Luck Vtec Indicator
