View Full Version : Acura Integra
- New Timing Belt: New Engine Noises?
- 90 integra MAJOR SHAKING/VIBRATION
- 14in civic steelies clearing integra brakes?
- Alittle help with a tuning situation..
- What's this part of the body called...?
- should I buy?
- How do you tell
- some night shots. nothing special
- another New B gosh....... freakin idiot!
- High cr pistons
- s100
- revs up drops revs up drops..TPS/IAC???....
- map sensor problems
- 91 civic and 2nd gen teggy interchangable parts?
- New High Compression Pistons In a LS
- obx lsd?
- my compression #'s are confusing
- Skunk2 IM: Do you have to upgrade your ecu/fuel??
- trying to do an engine compression test but not sure if im doing it right
- stock internals for turbo?
- 96 teg exhaust Q
- hondata s100 question
- STR Dress up kit
- screwed up jdm sidemarker install
- toyo RA1s or something else
- If you throw a misfiring CEL ...
- 95 GSR Firing order Quick help
- hayden transmission fluid cooler
- alternator thing...
- i want to add a ECU chip
- LS dizzy with ls/vtec?
- 17's effecting 1/4 time?
- distributor keeps blowing
- Crank Pulley is wobbling/making loud noise suddenly?
- Need someone who knows what there talking about. 98 GSR
- 94 rs + type r sway bar???? fitment???
- Another DAMN starter problem... 90-93 DA9/6s
- High Rev after Skunk2 IM install
- Shift Linkage
- Engine Knock (Street Tune Log Inside)
- JG Edelbrock Manifold
- quarter rust question
- Driving a MAnual....
- Recaro SRD rubbing against door panel???? anyone else??
- lights?
- having trouble with removing axles
- washer camber trick?
- Integra Type R Front Lip ABS install help?? Doesnt line up?
- Check Engine Light On!! Please help!!
- CRV engine? B29 with B16 head? is it possible?
- Car thermostat going to red
- need help!!!!trunks makin a squeekin sound
- need USDM foglight switch pinout
- for those integra owners who piece together their own jdm front
- jdm teg climate control install
- KYB AGX's What do owners recommend for spring/Coil
- is this correct?
- Type r ecu
- BOMZ Intake Installed
- coolant problem
- removing air conditioner, Gain!?!?
- i hope this will work
- ARC intake chamber fit on GSR with Skunk2 IM?
- Water leaking in my car
- GSR brakes/Clutch etc. Interchangeable with Type R?
- my new car
- metal brackets underneath rear passenger seats
- I need pic of rims
- ===possible for a DC to have a top fuel style pillar bar combo===
- my 3rd honda project car... needs lots of work
- Dim Tail Lights, Clock dims when i brake
- Done with my GSR few problems.
- Using a motorcycle muffler on the Integra
- Oil pressure switch
- OBD2 to OBD1
- Bad cat or something else?
- Comptech sway bar, tie bar combo. (Subframe Reinforcements)
- Help With Suspension Parts
- would you rather have an older teg, 94-01, or an 02-06 RSX??
- another low idle question
- WTB USED aftermarket exhaust for a 00 gsr
- acura loss of power
- Japan Pics
- anyone in here with a apexi n1 non turbo muffler
- Coolant overflow tank, filled or not??
- obd2 gsr with cel code 92
- VAFC Adjustmen? Need Help!!!
- CAR GRINDING GOING INTO 3RD GEAR, ANYONE KNOW THE PROBLEM!!!
- Just moved to costa mesa (OC)
- Anyone with a satin silver gsr
- price?
- need pic of knock sensor
- 91 integra low idle&power
- What would be a good intake manifold to put on a GSR?
- Exhaust installation
- Tsudo N1 Catback Exhaust for a DA
- SI Rims W/ NEW TIRES!! Trade for GSR blades
- Questions for VAFC2 Install on B18A1
- speakers in the rear?
- Need opinion on body rust..
- What is...?
- Squad Member Decals
- new shop in charlotte
- Will a cable ls case fit on a hydro b16 trans
- Stock Intake manifold
- gfs integra got broken into....
- tail light cutoff switch??
- throwout bearing
- Need new radiator for 00 GSR
- parting out 91 teg cheap parts!!!!
- turn signals dont turn off after turn
- what header should i get?
- Should i go with a GSR or LS/GS
- Apexi ws2 for 00 GSR?
- I NEED A 95 integra front bumpER RED !!!!! HELP :)
- Car sitting or 1yr+ what else to do????
- i just realized, my torque curve has an equation
- I need a integra data link connector wire diagram
- Timing question
- Spark plugs are white!! help!
- rims on a DA teg
- HELP turbo ?'s
- overflow bottle
- b17a rebuild
- Trial User?
- wheel pattern for DA integras??? HELP!
- Exedy Stage 1 Clutch Problem...
- how the radar working for ya
- Jump time?
- MUGEN MF10 question
- Engine knock when cold
- DA Bumper
- how to change raditator? help.
- ::what is the maximum size resonator size on 00 GSR?::
- Trannsmission trouble code help
- Question about Tokico Illumina ?
- ebrake problems after new calipers
- can i PLEASE get a CARFAX on my 94 acura integra gsr.....?
- Does B18c half shaft fit B16a?
- Supertech Pistons
- front bumper fading?anyone?
- someone wrote on my car with permanant marker...HELP!
- JDM EG6 main interior harness same as JDM DC2???
- Question about B20 swap into a DA
- Free 95 3dr GSR shell in SOCAL California
- Help with Caspes 02 simulator install Part# 104054
- Missing Parts?
- vtec not working and a few easy questions
- flywheel question/advice
- new car inspection
- p72 (gsr) cylinnder head on b16a2 block with ITR pistons?
- Bridgestone Potenza S-O3 vs. Yokohama AVS-ES100
- FREE 40 point inspection from Honda dealership
- exhaust resonator question
- Quick Question - Weight of Stock Wheels
- Carbon fiber interior
- my friend and his dumb 350...
- How to make your car hard to steal
- HELP: Integra GSR Fender BENDER
- vortech fpr
- power wire length
- Possible Starter Problem?
- Why is the ITR valve cover so hot ?
- --Distributor Install---
- Oil Pan Gasket leak...Oil all over my left control arm
- head gasket smoking after replacement
- sir-g front end?
- SirG foglights
- Half way there, what you think?
- front camber kit
- Music?
- 1988 Integra wont Fire why????
- What kind of lip kit is this?
- Oil Pressure Sender, where does it go?
- REbuilding the B18c1
- possible problems?
- oil leak maybe?
- DA shocks and DC2 shocks interchangable?
- Mirrors 4 the 4dr
- To Ebay or not to Ebay
- Misc carbon fiber pieces for 94-01 integra
- 94-97 / 98-01 Valve Covers, interchangeable?
- 11" Brake Swap + 14" rims.
- 94 GSR with JDM header and Catback..
- What to do with useless empty pocket under headunit?
- Compare the B18C to the B18C1
- Brakes - List your setup
- Brake Question
- Help! with battery.
- will 2000 integra cd player fit into 1995 integra harness
- Help to complete suspension
- sir integra
- Anyone make a power steering removal kit for 90-93 tegs?
- Engine colours?????
- Recently imported integra XSI (b16a)... what to do now?
- JDM Parts at good prices
- Used and New JDM parts for Good Prices...Imported!
- p61 ecu....
- pr3 pistons in B18C1
- got new toy for my teg sorry no pics
- FS: 2000 Teg GSR
- what is the best bang for the buck, high performance wise.
- stupid roommate
- b16 pulley
- sidemarker installation on a DC
- Amber corners ques??? remember....??
- O.Z Superturismo GT Rims
- Brake Kit continued
- Tenzo R's are shinning with a new coat o paint
- JE pistons
- Lambo door conversion on a 91 integra
- question for integra gsr gurus
- MAINT. REQD code!
- Where to buy 98+ Type R Lip.
- suspension upgrade?
- Integra GSR motor hard to start smoke son start up.
- anyone know where i can get a decent price on a pre built b18c1 block
- how to install momo hub and nrg quick release
- Drag Radials - opinions?
- do i need to change my motor mount
- 5th gear, foot on peddle, 4500-5000 rpm's, feels like car dies, rpm's drop !!help!!
- I cant get my wheels off?
- gsr studder
- Intake Air Temp Sensor CEL Help on 97 GSR
- Distributor question
- change my redline???
- JDM Type-R Gauge Cluster Install??
- VAFC wiring *installers please help
- COdE for my cd player
- Newbie DCI integra
- Local Orange county place that sell Integra Typr R lips?
- progress camber kit
- Steering wheel hub/QR combo?
- UEGO INSTALLATION? HELP!!!
- Oil Leak..Tranny Mount?
- lowering a DA6 - scrapheap challenge
- Is it common to have problems with Autozone axles??
- lowering a DA6
- Axle?
- Low Power Weak Timing Problem?
- Looking for a V-Tec Head & Block
- Air/Fuel... What Wire is it?
- recaro bracket questions
- new user with a strange problem!
- TRANNY HELP PLEASE!!!!!!!
- coffee color?
- moonroof
- vtec not engaging
- GM sychromesh ok for J1 LSD tranny?
- rust spot???
