View Full Version : Acura Integra
- Where to buy weather-stripping?
- caliper paint on valve cover?
- OBD 0 to a OBD 1
- JDM Da9 seats
- boost question
- INTEGRA TAIL LIGHTS!!!!!1
- need help please! DID A SEARCH
- whinning sound from the dash
- speed governor on 97 Gs???
- jdm oem foglights
- crx to integ
- valves ticking?
- automatic compression?
- Question on headers.....?
- HONDA CYLINDER HEAD IDENTIFICATION CODES (CASTING CODES)
- Axles
- need help on steering wheel
- Questions for ls/vtec owners.
- Where to find good car cover for 94+ integra 4dr
- help pleeeees
- Flushmount Spoiler
- front main seal problems
- air intake question
- I smell burning
- Factory alarm
- red acura emblems
- breather question? stock or aftermarket?
- swapping in a jdm b18c from hmotorsonline
- well i'm out of ideas....rear transmission mount won't go
- have anyone snapped a bolt on...
- vafc 2 question
- gs intake arm into gsr
- rotor screw striped
- valve adjustment
- quick question
- replaced clutch cable, now the pedal is real stiff
- Autometer D-PIC guage!! Does it work?
- headgasket make vtec problem??
- ITR tranny
- NEED HELP!
- b16 tranny vs GSR tranny
- steady check engine light?
- WhAcha think? =)
- need haynes/chilton online manuel?
- ITR VALVES
- Do I need to put this back on? (sensor on the back of the block)
- skunk2 Im on LS High idle problems
- Carbon fiber hood and hatch ?
- Brighter gauges...tried leds
- question on selling integra
- Motor sqeeks when i give it a lil gas
- Problem with New Taillights!
- royal purple oil question?
- ecu stolen
- ls vtec ?
- h22 help please
- 00 LS won't Turnover
- Alternator and Power Steering Belts - Which is longer than other?
- URGENT PLEASE HELP
- Clearing my ECU, need help!!
- car tempeture
- Street hp limited
- Clock,Interior Light, and Radio Problems!
- Need help with tranny pull
- TRANSMISSION HELP PLEASE
- choices
- cam question
- my car is stuttering
- 89 teg
- different JDM fronts for a 94-00 teggy?
- Semi built my head! Now VTEC BOGS!
- Need to know what to torque bolts down to on transmission please!!
- Is this street legal???????????
- Rim bent slightly
- aebs intake manifold for a GSR
- black FMIC????
- LS/turbo what kind of HP are you getting.
- PLEASE HELP ASAP STARTING PROBLEMS
- Thinking about turbo options, what would you guys do?
- HELP ME CHOOSE WHICH ONES!!!!!
- Restore - Engine lube oil question..
- why u shouldnt do a ricer driveby....
- think this is legit?
- b16 TB on LS intake manifold...any advantage? plug and play?
- 00 GSR- Car Lightly Jerks at low rpms
- how to remove outer door handle??
- 02 sensor code... GSR Harness..B18c Help please
- Wheel Offset DA question.
- car not acting right
- Installing S2K seats on my DC2, what is needed, as far as seat rails your to go, who sells a set up?
- Rim Leak
- New Interior for an Integra?
- axle woes
- code 20 and 21? on a non vtec?
- idling to 3000 then 250 and so on. finally does after a little bit
- Double Clutch
- got new rims, what size tires should i run?
- ecu help
- My ground control Springs?
- URGENT HELP! exhaust/engine problem
- b17a questions
- turbo b20 redlining at 4k!!!!! HELP!!!
- Cams and Intake manifold
- new to honda-tech
- MSD SET UP
- will a gsr valve cover fit on an ls head?
- will it fit???
- HELP CAM qestion
- shipping info
- HELP ME WITH CLUTCH!!
- integra w/ 16" rims?
- what the heck is code 22?
- greddy evo2 2dr on a 4dr...
- People on this site need to get over them selfs
- heat keeps blowing when the switch is off wont turn off
- Where to order a Timing Belt Pakage on line???
- 1992 Integra Black For Hatch Or Integra
- Exhaust Setup Help (What to do?)
- BRAKES HELP!
- jdm power fold when power off?
- JUST a real question
- Which shifter is best?
- need new tires soon, ES 100's ???
- 98 GSR manual transmission with LS 5th gear
- Stock GSR?????
- How much stock whp on a gsr
- DA bumper change 1990 too a 1993
- custom turbo kit
- some kinda banging noise in the engine bay, need some help
- Clutch Engagement Issue
- camshaft question
- Looking for a 3inch test pipe
- Quick 02 question
- Are integra's known to be looked after by the cops
- In the middle of changing back brake calipers.
- Maint Req Liight on
- on my way to work....
- cheap alarm system would work bad?
- Timing belt question!!!! DID SEARCH!!
- Changing Clutch Does a Lighter flywheel help acceration?
- ATTN: For those of you who have Koni's...Question
- Electrical problem DA
- gsr or itr?
- help i have a si wiring harness is round but my zc one is different can you repin
- Is it worth it
- Anybody install jdm itr doors??
- DA needed!
- brake question
- integra question
- **good size tire for 16 inch rims**
- more to the teg
- Any tuners in or around st.louis, MO this threads for you!!!
- Pics of my new header
- RS-R Race Springs Vs. H&R Race Springs
- B&M command flo
- ignition timing / compression test
- one jacked up/riced out integra!! MUST SEE
- Spoon mirrors
- A little help with my radiator please!
- uh...oh....
- how good are the Falken Azenis RT-615 in the Rain?
- Which Wiseco pistons for B18A/B?
- axle backs
- Engine harness question
- sugar in gas tank
- can anybody help me to find a seller for type one racing battery, cheers
- what will a bad Cam sensor do on a zc motor
- removing the vents/climate
- Specs ?
- idling help
- 215 size tire??
- DAs How much are you guys weighing in at gutted?
- where can I get real bright LED ??
- how to fix abs code 11 and 81 for 98 integra
- 90-93 Acura Integra DA H22A motor mount kit
- Replacing the Door Handle and/or Handle Mechanism
- Anybody have any Useful website.................
- can i put rear break pad to front?
- exhaust advice please
- how much would honda charge for a timing belt change?
- JDM LS Transmission
- transmission problems
- Integra Headlights JDM? or Tinted?
- will any switch work?
- Pic request
- lucas gear oil. anyone use it?
- building my b18c1....need advice
- Injector Resistor Box
- how do u get steel wheels shiny...
- need help with gauge cluster / speedo cable HELP PLZ
- Need to install a fuel pump on a 90 integra LS
- Plans for a 1990 DA
- ignition timing question
- Need headlight for 96 LS coupe
- Innovative Mounts DA Kit
- Q on falken azenis' (not RT615s)
- 95 GSR Seats in DA
- b16 tranny in DC2 clutch line question(plz help me so i can order the part)
- Crankshaft pulley won't come off.(Bolt is out)
- What are the 4 knock-out panels next to the e-brake for?
- V2 * ARC Induction Box * Zero1000's PowerChamber
- Where's the Stickers?
- swapping in a 98+ bumper on a 94 teg??how hard
- noise coming under hood when pressing pedal????94 gsr teg
- integra won't start
- Tranny needed ASAP
- Stock b18b1 used pistons and rods for sale.
- Free CarFax
- Strut bar for a 2 door will fit on a 4 door
- doing swap tomorrow...
- MAD vibration problems again on GSR
- da9 hks exhaust
- airmass header
- 90 integra question
- car overheat
- how do i get my shift nob off?
- need bearings
- Will the 94 civic radiator fit on my 94 integra ls
- Transmission Diagram?
- is the vigor motor inline 5?
- where can I get some fog light????????????????
- **NEED HELP B20 GIVING ME PROBLEMS**
- i opened the valve cover and i found...
- GSR TURBO NOT SPOOLING CORRECTLY
- YS1 Transmission Removal
- apexi n1 exhaust question???
- should i trade
- header!!
- JDM ITR non-hid and hid black housing headlights... whats the difference?
- CF hood/fenders
- Sanding CarbonFiber Canards......!!!???
- swapping pistons
- Cheap jdm power folding mirrors
- Is this trade a dream? or possibility?
- 96-00 civic tie bar fit 97 teg?
- obd-1 ls computer swap
- my Turbo GSR
- Integra Front End...Where to Find?
- painting my rims
- Removing DC Interior???
- GS-r rebuild question.
- how to back down timing?
- oem exhaust question ???
- paint job needed
- ok who has an ctr crank pulley on their gsr or itr in here
- Image Exhaust
- Don't know what's wrong widds my car
- JDm folding mirrors question
- Knock sensor wiring non-vtec --> Vtec
