View Full Version : Acura Integra
- 2dr gsr tanabe RM fit on 4dr GSR?help?
- handling improvement time!
- HELP!!!! Maintenance light flashes
- 4 door Integra Owners
- shifting auto 4 speed?
- What shocks mated with H&R Race Springs?
- I am buying a used GSR! Could someone check this VIN, PLEASE???
- Really hard time getting into gear, exedy clutch install
- Tornado fuelsaver, Z-max, Timing Booster, Real or Gimmicks ???
- help me identify this "JDM" transmission please...
- I was searching for a GSR/Type R, and look what I found, check this out! (pic)
- thinking about going type R
- Kumho ECSTA Supra 712 tires
- drove in ITR, and drove a WRX today
- Possible?
- can you guys tell me if this car is worth the price??
- Where in the engine bay can you install an MSD ignition control unit?
- pics of red integra with bronze te37's?
- ECU for '00 GSR?
- zc motor ??
- Do i need to lower the compression?
- Possible master Cylinder going out?
- Sprint Extreme Camber kit
- question about low jack
- Reasons why passenger window does not work
- Integra selection HELP!!
- list them all
- does anyone here have RS*R springs on their car?
- cel code fix
- is the engine in the 92-93 ls/gs/rs a b18b..?
- Bronze/Gunmetal/Black 98-01 GS-R Wheels =)
- anybody with a 12 sec turbo ls
- Tacho Bouncing
- fuel filter question!
- u thin i cant chirp 2nd anymore cuz...
- What Honda Emblems will fit integra....
- Will b18a tranny work fine with b18b engine?
- tech question about the RPM meter.
- how many ppl here have lowered car and scaped their header? any pic?
- 5zigen fireball
- Wierd problem...
- V-AFC pics
- What do I need to get AC?
- preppin for turbo
- Apexi Dunk....good or bad?
- Post pics of FAL rear windows
- did you tap it?
- headers from gsr in ls?????????
- all NJ peeps and surrounding areas, check this
- got a problem....
- best pulleys??
- Acura Integra Gen 2 Windshield Fluid Resivoir
- '94 GSR w/ bad crank
- To those who have gone from aftermarket exhaust to type r
- Teg steering wheel problem
- For Real or just full of Sh*t???
- my dyno day results
- LSD and new clutch and final gear?
- wash out header???
- Where to get dent shield for headers?
- LS exhaust same as GSR?
- Anyone ever order one of these shift knobs off ebay..
- Installing a master cylinder
- Fuel Filter Banjo Bolt help
- To install Walbro unit now or not?
- Will a header with a 2.25" collector fit with a 2.5" test pipe?
- Turbo or Supercharger?
- Cam Gear Installation
- Going to a junk yard today
- BSQ DIY Intake revisited (dyno #'s)
- Motorized Antenna
- coolant resevoir boiling
- quick help: how do i remove the backseat?
- Lowering the teg today
- grrr...all I wanna do is install my rear sway bar!!
- new car shopping, keep GSR and move to a supra?
- Skunk 2 Short Shifter Questions
- Here's a quiz for all u Teg'ers......
- Integra RS info wanted
- LS/VTEC question!
- is the skunk2 manifold for the b16 and b18c1 the same?
- need pix of gauges in vtec 5600+ rpm
- Difference between 94-97 and 98+ headlights??
- how do you wire sidemarker so that it'll lit on and blinks with the blinker ?
- Cams: Let the Ignorant One Know: LS
- MUST read!!!
- camber kit suggestions
- where to get or how to make
- What to get with Icebox
- Turbo
- Apex'i N1
- springs questions...please help
- effects of disconnecting the power steering belt.
- wheel hub bearing ???
- Crower Stroker Kit
- intergra wheels or gsr wheels weight?
- Treadwear of FM901, RE010, RE711
- SRS Light!?
- warranty help....
- civic radiator in integra?
- clutch pedal height
- Cutting Lisence Plate
- msd ignition installation???????
- Clutch Replacement at what milage?
- Benen Tow Hooks??
- Typical cost of clutch installation?...
- ls vs. type r. how much difference in autox
- Will a stock exhaust from a 94 Integra fit in a 91 Integra??
- Cam's First or Intake,Header, CAI?
- adding heated mirrors
- Drivin' my Teg is getting DANGEROUS!
- gauge problems... not working right
- TypeR rear sway bar on a GS-R with beaks kit
- Ugh...electronic supercharger...
- damn brakes!!!!
- JDM ITR 4-1 header or JUN 4-2-1 header on a GSR?
- Acura Engines
- Review: ACT HDSS & Comptech 6.75 FW
- Rims And Tires Here
- flywheel ringgear and clutch problems
- Horn and Cruise Controls
- Suspension Q's
- Is this what I need to fix leaky clutch master cylinder?
- Need exhaust
- Need help with my V-AFC
- adding GSR strut bar to another integra.
- gsr with problems....!!
- motor mounts
- i/h/e/ question
- rattling exhaust??
- suspension ?
- clutch adjustment
- I'm Tired of this SH|T, Gotta fix Integra NOW.
- Removing Clutch Pedal Spring...
- Rear brakes making metal scraping noise
- GSR brakes vs ls
- b20b valve cover on 95 b18b (no search results found)
- AEM American or AEM Japanese????
- AEM CAI question
- Bay Area People please check out
- are 4 pt harnesses street legal?
- Car vents stink when on!
- I think I need a new clutch in my teg
- Whats the break in period of ACT Xtreme..
- i need suggestions for suspension mods
- JDM fog light switch
- shocks and 2.5 inch drop springs.. whats the best combination
- Suggestions!?!?
- integras with SI wheels
- How much did a gen 3 GSR cost when they first came out in 94?
- 90-93 tegs new style headlights?
- apexi v-afc in a lsvtec??
- OMG stock teg rubbers suck in the rain
- Need pic of tranny mount
- Click noise............help
- New Wheels ...
- Different head gasket with overbored 0.25 pistons ?
- In market for car. 90-93 tegs!!
- Ill try it here
- broken shock?
- ITR valvetrain
- HELP!!! My back up lights wont work...
- itr springs with koni yellow neuspeed.
- What is a ZC engine?
- Wilwood fastbrakes kit, no dust seals on calipers?
- is my starter dying/seized?
- Camshafts??
- HELP NEEDED!!! Helms Wiring diagram PLEASE....>>>
- Intake Manifold Performance?
- Are all parts for the JDM B18C1, interchangeable with USDM B18C1?
- Yokohama Parada Spec-2
- NEED HELP !!!!! my turn signals DONT WORK
- can someone post a pic
- fuel injector cleaning?
- Quick question about taking valve cover off
- New Yokohama AVS ES100 205/45/16
- will 92-95 Prelude seats fit in a 3rd gen Integra?
- would any kind of shortshifter do?
- Considering selling the GSR for '03 GTI VR6 or WRX
- Is there hope for my wheels yet ?
- looking for 98-2000 taillights
- lol
- Any comments on the Comptech I/H/E setup?
- car has been sitting for over a month
- Hesitation when at WOT
- what mild cams for LS?
- Unorthodox Racing vs. AEM underdrive pulleys
- Integra shift boot
- what is the gsr called in japan?
- Wierd noise coming from back brakes on my gsr
- First time to the track...let me know what u think...
- INgalls install instructions ASAP
- ABS Light question
- HELP! ABS problem?
- Help: 99 GSR losing oil??
- Lightspeed exhaust
- Anyone ever get tired of you aftermarket exhaust and put your stock back on...
- Benefit of Rear Sway Bar?
- how much would it cost to get a b18c1 bored out to 84mm..?
- vafc problem...
- GSR ECU Question???
- Odd pic request...
- 96 Integra RS exhaust fit 92-95 hatch
- Speedvision Integra
- SoCal Dyno Day Sept 7th
- What color 94+Integras had tan/yellow interior?
- FS: Spoon Sports Shift Knob. Brand New, Silver. 50.00+ shipping
- Which Brakes?
- what kind of tranny is what...
- integras need mobile 1 oil??
- strut bars?
- Which Tires Are the Best for Integra's ??????
- Are those fake Type R strut bar any good?
- mugen+spoon+5zigen+comptech exhaust
- fuel pump question
- what are the right cams
- vulcantire
- RS*R down springs and GAB superstroke 4way dampers
- type r sway bar rubbing ..
- Part # for DC JDM 4-1 Header
- Various types of tail lights
- Just got a new muffler installed, 2 1/4 Inch off the Engine.
- Automatic ECU on ebay, does it work?
- need help w/ back brakes
- request picture of black rims on white teg
- Will a 93 GSR master cylinder bolt up to a 90 teg RS ???
- Need Help
- Hey guys, real quick!!!!!!!!!!! Need a price on a used part
- 90-93 integra owners : peep this please.
- Prices for 9005 silver star bulbs
- anyone know the proper torque settings for the cam plates on a cam install?
- whining sound coming from engine
- strange 'sticky shifting' feeling
- JDM Header / ITR Exhaust Question
- helms service manuel for a '99?
- uneven drop in rear! ????
- quick help please. Overheating
- How bad is it to cut aftermarket springs?
- anyone with a direct port zex kit..??
- New gas tank??
- Kyokugen 7-sided key same as Project u key?
- Summitracing.com
- anyone has ITR oil cooler in their GSR?
- Re: Anyone using the JG (Victor X) Intake Manifold on their GS-R?
- Compression Test
- Is this safe? Will i cause damage to the car?
- re: HELP!!!
- HELP!!!!
- Type R header?
- instaling V-AFC on 90 teg ecu for b16a, help
