View Full Version : Acura Integra
- B18b1 Turbo.
- Wire harness
- Transponder 2000 Integra ls
- Stock ls pistons
- B18 to F22A swap?
- Manual Transmission Oil
- Cruise Control Adjustment
- DC power fold mirror housing the same as non power?
- *ECU trouble. 90 integra(obd0) b18b1 swap, p75 obd2 ecu. HELP
- Honda Performance Shops In Los Angeles?
- Shifter Linkage Part Help!
- Overheating GSR
- Retracting Antenna Source
- 98 Integra LS Rear Wiper
- What is this thing!?
- YS1 vs Y1 for highway cruising?
- Knock sensor questions
- Lsvtec Piston cam set up
- Rod length
- Rear view mirror
- 93 Acura integra coilover suspension
- B18C1 Rebuild for turbo help
- 1994 Acura Integra Shuts off while driving
- 91 DA trans (manual) in a 98 DC shell.
- Engine Rev Fluctuation
- what are these sensors?
- Fuel relay problems, please help!!
- Physical slop in steering column sleeve.
- B18C4 Cam Cap
- B18c head gasket leak
- What other vehicles use the same drivers side axle as a 1992 integra ls
- Distributor cap won’t fit
- 1993 Integra GSR Reinstalling Radio
- 1988 Integra
- 2 step
- 1995 Integra battery relocation
- (1993 GSR) what paint should I use?
- Will 94 doors fit on a 93?
- Crankshaft Position Sensor Location?wher
- 1993 GSR getting ready to paint, any ideas?
- Bypass crank fluctuation sensor??
- New to the game. B18c Turbo Build Guide
- 1995 Acura Integra
- I need help!! Crank no start
- 1992 Acura integra gs hatchback
- 99 integra gs taillight problem
- Cams for boost gsr
- Any way to do home programming of key/immobilizer?
- 97 acura integra ls
- Blinking oil light, low oil level
- NIGHT TIME TAIL LIGHTS DON'T WORK
- Acura integra wiring harness
- Help Gap CV Axle B Series passenger inner shaft? normal?
- Vendor for CF hood?
- Radiator Fan Switch/Rubber Boot Removal - 91 Integra LS Hatchback
- Type R LSD ring gear bolts
- Idle and throttle issue
- 1995 Intregra Shifter Dust Boot
- 94 Acura Integra
- Integra Cluster not working and not shifting out of park
- 99 integra LS Exhaust leak HELP
- 94 integra project tips
- 98 Integra LS Rear Hatch Latch
- 00 DB8 GSR w/ ITR Engine needs exhaust help
- Idle issues P75
- Persistent code 23 issue after replacing everything
- Troubleshoot SRS light 98 Integra LS
- B20 swap help
- SRS light
- RS > GSR upgrades/Question
- Please help!!
- No taillights when headlights are on.
- Darton-Sleeved Drivability
- 92 auto stuck in gear, can't shift into park
- Do I need a tune after Cold air intake install
- Turbo b18c1 forced internals can’t figure out why vtec won’t engage
- 1990 acura integra shifting problem
- Slave cylinder 1990 Acura integra
- Tie Rods?
- Low voltage 98 kswap batt relocate.
- Troubleshooting : Error code P1259 '96 Integra B18C1. What to do?
- 94 integra A/C pulley bolt search
- Gen 1 Integra Fuel Pump Question
- HELP! AFC neo diagram for 91 DA b18a
- 1990 integra Bogging
- Gsr bogs when launch
- Integra Swap Research and Developement
- 12v accessory spot on fuse box? 98 RS.
- K swap Exhaust question
- 90 Integra no turn, no brake, no bad fuses
- Help Identifing Drive Shafts
- Looking for Lower control arm OEM equivalent
- what to do
- Check engine light constant
- Timing belt help, off by 1/2 gear/tooth
- '90 Integra GSR
- 90 Integra orange spark
- Shop in the Twin Cities
- Acura Integra 2000 GS-R coming out of storage - pricing ideas?
- P72-1 in 95 Integra shell
- Identifying Wiseco Pistons
- oil light flashes *sometimes* k24 w/RSX-S pump
- Fuel pump not priming
- 94 Integra Misfires When Warm (B20b swap)
- integra manual swap
- auto to manual swap issues
- Stock 98 b20 head gasket thickness
- Tachometer isn’t reading right
- Integra antenna delete/replacement - how to video
- 94 Integra shuts off after key release.
- Integra H&R sport springs installed
- 00 Integra LS Third Brake Light Delete
- 90 honda integra beeping
- B18c1 swap into 1996 DC2
- window regulator w/ motor coupe
- 98 turbo Kswap stock injectors not firing.
- Stalling issue
- I have a lemon. Need help
- Suggestions for my new integra 4 door blue
- What is everyone using for oem engine rebuilds?
- H22 computer questions integra swap
- Coolant line and ecu pinout
- Looking to buy a new integra, you guys have any for sale under 100k or close
- Josh's 1st Gen Integra Build
- 97 GS-R - fix or move on?
- evap in DA?
- DA vs DC... What can and can’t i use ?
- Integra window visor
- Crackling/Popping Exhaust.. Bad for Motor?
- H22 swap questions
- SRS normal...but light still comes on.
- Honda Integra DC1 engine swap
- CEL inop
- Sand dc5 airbox
- '95 Integra, no throttle input while driving/dies
- Good ole` "My car won't crank"
- 99GS Engine bay way too hot
- Rear Bumper Bulge on 2000 Integra GSR
- Idle surge problem
- Was there a dizzy upgrade?
- Rear main seal thread pitch
- Proper gapping?
- H22a4 swap in my 2000 Integra ls
- how to remove main bearing cop from 2003 honda odyssey
- cable to hydro lever?
- 98 LS Door Lock Cylinder not working
- Acura integra 99 leak help
- S2000 steering wheel in an integra
- 99 Integra LS noise help IMPORTANT
- Need help
- 91 acura integra driver side cv axel tooshort
- honda Integra
- 92 INTEGRA COILOVERS
- 91 DA Are the axles the same length for both Drivers and Passsenger sides?
- Bad Hesitation from Idle ((7 seconds!)
- JDM experiences?
- 99LS running lights fuse not getting power
- Thief damaged my hatch key cylinder, can I swap out the broken bits?
- Hi I am new I drive integra 1998
- Integra B20 (high comp) swapped
- 92 integra LS Wipers windows and sunroof don’t work
- How to fix rear windows that stick out?
- Crank pulley question
- Need help please
- 93 Integra A/C Diode location
- Need help please
- Verify a 95 Integra has an airbag and whether it works?
- 1996 Acura Integra RS Smoking a lot
- What is this part
- Replacement trunk steel pan for rusted out one?
- Head bolt stripped
- B20 non-vtec swap, intake manifold question
- Nearing 270k, is a full rebuild necessary?
- Brakes Pumping Up/Locking Up, have searched
- B18c1 swap
- Keep blowing ECU fuse
- Help deciding between motor mounts
- Suspension Bolts
- Where is harness end of CKF Sensor?
- torque specifications
- Troubleshooting: Cranking engine w/ No Start. 2000 Integra LS
- Input/experience: Turbo K-swap driveshafts.
- Chance to buy an unmodified 92 integra with bent valves
- Some one help iso gsr block
- 1995 Integra GSR Sedan
- car acts weird after ac recharge
- 6500 rpm rev limit
- What are close to OEM suspension parts?
- 2000 Integra Cranks But Won't Start
- Grinding noises!
- 98 Integra No Crank No Start
- having issues with front brakes, making grinding noise when wheels turned
- Key stuck in ignition
- NEED HELP! 1996 Integra LS Coupe
- Buying an Integra that's missing the Crankshaft Pulley
- Vtec wiring issue
- Smog question
- 2001 teg ls to vtec
- GSR IABS smoked / melted
- Now it's the starter
- Fuse 23 keeps blowing please help
- B20b losing coolant
- 94 LS bad tranny?
- 1990 Integra fuel gauge wiring
- 94 integra constant problems
- HELP! Misfire on all 4/Rough Idle
- I'm an idiot and now I need new hood hinges...
- Battery light comes on when braking from 40 to 15 mph and RPM drops to 1000
- 2000 Integra LS charging system not working????
- I wanna put spinners on the teggy, cant find any 18's any recommendations or 20's
- Flutter at start then dies
- B18b1 Crankshaft bolt
- Can a stock B20B non vtec use hondata?
- '90 Teg LS won't start. Fuel pump runs.
- 1999 Acura integra with b20 swap
- Alternator load problem?
- Testing the fuel punp without a pressure gauge?
- What happens with insurance when you get into a car accident with a JDM front end?
- What mods can I do with a stock B20B non VTEC
- 98 DC electrical issues, Kswap/JDM-front.
- 2001 Integra LS
- 98 acura integra problems
- Please help no spark lsvtec turbo
- Occasional crank, no start?
- B20b how much HP?
- Need advise
- Help with sensors
- Looking at a 2000 integra gs-r with some work done to it, but motor problems
- Pic request(s): 98+ under dash + hood fuse box sheet
- My 2nd DA
- What are the front mounts that connect to the ac and tranny called on the 96 integra
- Relay
- Integra won’t start something
- Finally got springs
- LED ring install service for 2001 GSR
- iacv options
- GSR head, is this plug supposed to be here??
- 91 Integra GS won't keep ABS/CEL Codes
- Acura Integra Distance
- Unknown coolant leak 98 Integra ls
- Why is my engine burning so much oil. Help
- 1991 Acura Integra LS AUX PORT and FAN blower issues.
- 2000 Acura Integra gs-r turbo running obd1 needs smog help!!!
- Distributor Ignition Coil Resistance Readings...
- Need help with 94 integra LS Auto
- Supercharger
- Da help
- Victor X Intake Manifold - Gotta Love Christmas
