View Full Version : Acura Integra
- how often do you change your oil?
- Apexi WS2 wit gutted cat
- All wheel drive kit for DA integra, is there one?
- different between LS and RS and GS motor.
- 93 Integra Trunk area leaking problem
- GSR intake manifold...what happens if i remove the dual stage butterfy system in it...
- 1 pc headlight polishing?
- cat converter cracked off....will a new cat-back exhaust help???
- EIBACH SPORTLINE SPRINGS on TEG
- skunk2 full coils
- itr sway bar
- IDLE problem!! help idles low on start up
- alternator.......
- i'm having a problem with a 96 ls...
- Preferred Cams For B18A Turbo Build
- WTF??? my fan wont turn off???
- b18a question
- help please!!
- looking for ITR motor
- new to honda-tech
- Removing the silencer on a new N-1.. help
- header question
- what kind of transmission oil you use?
- Will it work?
- boosting line pressure???
- anyone kno wat these are called
- Kevlar Clutch
- lowest compression oem stock pistons for b18a1
- what lip is beter quality???
- car is loping... reving from 1500 to 2500 rpms
- 94 integra gsr
- Replaced my IT mani. and now my car is........
- obd-i P30 chip in an obd-2 b18c1 gsr?
- camshaft question
- where can i get rear break calipers for a good price...also Q about rotors
- 94 gsr abs problem?
- How hard is it to change input shaft bearing on 94 gsr
- how to repair crack in JDM 1pc DA headlights??? is it possible??
- turning vtec off?
- **HELP** I NEED A SPEEDO SENSOR FOR MY 5 SPD Y1 w/LSD TRANNY !!!!
- searched! please help
- How do you feel abou these.
- dh-racing manifold/TB combo??
- Maintenance required light
- integra calipers
- engine rev problem on a gsr
- b18 fireing order
- new rings, what should i get OEM? and headgasket? is there something good out there?
- Misfire, bogging and sounds like a wrx under load
- RPF1 4x100 look so hot Integras......
- GSr question
- new jdm gsr swap
- Stronger clutch?
- rear quarter panel
- Injectors???
- '93 teg won't start, ECM lit solid?
- cams???
- Plastic undergaurd?
- ls and gsr header...
- header = ricey buzz?
- oem gsr rings and valve seals, 2 different part numbers?
- gsr exhuast
- paint job
- just got a oil pressure guage, what else do i need to make it work? HELP
- Removing wing off your hatch
- 2001 conversion
- ???? Cams for Gsr turbo
- Rattling sound
- good shops in your area? post where you go to help others out!
- What do u thinkof my 01 gsr????
- auto to manual tranny???
- muffler question
- itr lsd
- what
- b18c jdm block with b16a2 jdm head
- Muteki lug nuts... each set keyed differently? or all keys work for all muteki?
- RPM/Vtec problem
- nology hotwires
- question for those who have stock GSR strut bars
- pics of integra, new to import world
- ECU - PR3-J01
- need help
- Where do all of you guys get your charts from?
- **95%** DONe with my ROllBar install..
- Clutch Problem
- Tranny Swap.. Socal
- high flow cat
- b18bno number whats it out of?
- need some ideas on how to fix this....pls help
- GSR Or Type R intake manifold on a LS head
- integra rims
- engine bogged out and is flooded
- gsr crank??? (quick question)
- Master and slave clutch cylinders be changed at the same time?
- in need of acura part numbers. anyone have a diagram?
- need help FAST on my signal wiring!!!!
- 99 to 94-97 front end conversion
- Engine Swap
- SoCal: where can I get a valve adjustment done around south OC or SD?
- piston question
- '94 LS with GSR Motor. P72 ECU, solid CEL when VTEC hooked up.
- reversed jumper cables help..
- Off the wall 5-Lug conversion.....97 Prelude suspension?
- How could i stroke my 1.8 up ??????
- Wider tires
- B Series Intake Manifold
- smoke
- what happens when both battery post touch the ecu?
- Car lighter broke???
- Head cleaning...remove valvetrain?
- question about wheel bearing
- Is this a normal VTEC behavior, or is mine just retarded??
- i need help
- JDM DA headlights with HID projectors?
- Just a heads up for all you 94-99 integra GSR's
- LS Vtec will pass california smog? anybody
- old new ht member, tell me what you think of the new life gsr
- Broken door lock
- ANSWER ME! haha..
- park lights wont work
- i'm retarded i drove my car without the oil cap
- 97 integra front clip
- Trouble bleeding abs
- I need a distributor ASAP!
- will a DA radiator fit a dc?
- h22 integra!!!!! advice
- Removable ECU?
- thermostat? radiator? water pump?
- About to buy an Integra... What do you think of this deal?
- Injectors OBD0 (searched)
- GReddy New Product!
- 2.3 turbo k series...stock...
- 1997 integra LS 2 dr hatchback automatic trans trouble
- HELP!!! Power Antenna Replacement
- How to clean 97 integra headlights
- Need help with flywheel bolt removal
- wut the a ground wire kit do
- Integra Front Lip
- What up H-T...im new on here !!!
- nissin brake rebuild.....where can I find parts?
- Side moldings
- leaking oil
- how to replace ducts
- upper control arm/Ball joint...
- kwick lsvtec question
- jdm conversion
- Clean ITR ? shaved doors without the bar? im not sure
- Oem exhuast manifold bolt size?
- is e-manage good?
- CAN SOMEONE CONFIRM WHAT A 92-93 CABLE GSR TRANNY IS ??????
- Tranny Question?
- Replacing brake pads
- da with b20
- 5 lug conversion
- cam timing
- my new lsvtec build
- Which Header?
- HELP PAITING LIGHTS!!!!
- 1995 gsr ecu for sale anyone??
- ..... ITR video inside........ what exhaust is this?
- i searched but didnt find..
- NON-Vtec B18B Dyno (Integra GS 96')
- Any group Buys on DC2 CF front lips?
- What is the best place to tap for fuel?
- where can i find mugen wheels?
- who has pic of the kalamari (spelling?) side skirt?
- ls mounts b16 motor(need a quick answer plz)
- 91 Teg, New things ... need advice
- first time posting
- does any one have a obd1 ecu for a 1990 integra
- south florida dyno pulls
- Radiator installed and doesnt cool engine
- FOR SALE 1998 ACURA INTEGRA..MANY MODS...
- how do i fix code 71???
- car stalling for no reason...
- Sh$T, Stripped Oil Pan Plug
- Please Help...B18C bogging in vtec
- what happens when the battery post touch the ecu?
- Damage from car sitting on ground without wheels?
- Clutchmaster Stage 3 with 9.75 ib flywheel
- Best place to get fuel?
- Pics of 1g Integra
- What is B20B red zone?
- Leaking and burning oil?
- Hooking up sub, searching for hole in Firewall Help?
- ignitor coil question (searched) help needed.
- Exedy stage 1 or stage 2
- H22 clucth on an 99 F20b which year is interchangable??
- air and fuel adjustment on 92 LS
- Question about Brake Switch
- k20a swap
- who else is using the diy icebox setup?
- DC Sports Header nuts and bolts
- b20vtec vs. b18b vtec
- What is everyong using for All-Weather Floormats in their Integra?
- getting parts numbers for brake lines.
- First gen integra motor???
- Lifes little problems...
- t3/t4 turbo on my ls
- wiring water gauge
- B20 head vs B18 Head---Performance wise--smog issues?
- ABS light keeps coming on
- h22 in 93 integra
- REPLACING TIMING BELT?
- northern va maintenance shops
- help with brake light
- Pic request: Spoon mirrors on white DC Integra.
- help... need to find gsr trans. or prof. trany work in the northeast
- Tranny Help!!!
- vapor shield part number?
- ls vtec smog question.
- KYB AGX NIB 94-00 Integra also works for 92-95 Civic
- cam seals?
- ABS light is on
- 97 DC Clutch Problem Continued
- 96 GSR vaccum lines ( i just install a blox intake with RPM TB)
- Hello all!!!
- WTB gsr block
- will a jdm b18b pass smog in cali ?
- 92gsr seats in my 91 DA
- Type R spolier for LS
- having a real stupid problem with this website. help please.
- Is it worth it.
- pic request
- 94 Integra Questions .. .. ..
- 94-01 Teg vs 90-93 Teg Stainless Steel Brake lines: Are they the same?
- New/First project teg
- temp guage problem
- skunk2 stage 1 cams
- Question about the bore of a Skunk 2 intake manifold for a B18B ?¿?¿
- what are the symptoms...
- Brake master cylinder....
- i think i runnin lean searched but no help
- having tranny issues
- what does alot of white smoke from exhaust mean ?
- stuck
- Best place to hide nitrous setup?
- DIY or Not?
- need answer asap
- bezel
- reverse sensor getting cracked while cruising.. what should i do? (pics )
- integra headlight housing question
- info on swapin h22 in da
- water pump?
- how much should i lower
- clutch problems, PLEASE HELP!
- New Teg pix
- Integra Quarter Mile Times
- Exhaust question?
- failed smog obd fault code PO325 knock sensor 1 ckt malfunction
