View Full Version : Acura Integra
- gsr wit 185,000 miles wen should i rebuild?
- Optional Integra Rear Valence question...
- h22 pics
- what the hell?
- Gsr cams in my b16??? acting weird
- Teg Cluster wiring problem
- installing 404s sunday
- Full Catback for a 2001GSR 2dr?????
- Negatives to sleeving/headwork?
- Greddy Evo Exhaust
- drivers side wiring diagram?
- Would this fit on a 94 LS teg?
- S2000 HID conversion
- LSD?
- already searched....car sputtering while cruising at about 3k rpm
- need help on these ecu codes
- will new intake help?
- changing integra tan dash to black dash
- Oxygen Sensor Wiring Question
- ITR Wing Installation
- I know someone can identify this piece!
- is my starter going out?
- help indentifying some parts and sensors (PICS)
- oil pumps
- help my car keeps dying
- header and exhaust combo...
- Adjuster arm
- 99-00 civic si b16a2 in obd1?
- help please
- My ABS light one on after I blew a fuse. Please Help.
- 4DR DA BUMPER TO 2 DR DA will it fit
- Best matching Gauges
- Trailing Arm Bushing Removal
- can't adjust ground control
- spolier
- Having a problem with my DA B16 swap not cooling correctly
- Wondering if you can put a Vtec head on a B18A1?
- Stock flywheel on aftermarket clutch? Pro's and con's?
- B and D Series Alternators...The SAME???
- SHOULD I GET A b16 Tranny For My GSR???
- how much timing is thrown off from stock when a spoon 2 layer head gasket is installed ?
- new hi flow cat installed...
- What could cause a distributor to go bad?
- DA seat belt stuck WTF
- Rim fitment
- Da9 retrofit dc2 type r suspension question
- How to: Taurus cupholder conversion for DA
- Compression Test Results
- DB8 Coilovers
- exedy clutch
- Has anybody figured out a source to get 4 amber lightbulbs for climate control?
- right hand drive turbo gsr sedan *PICS*
- f/s zc motor
- Clutch putting lots of pressure on gears
- illuminas and H&R race springs problem
- Picture Request: SSBP Integra
- gas question..
- 97 ls......fast enough??? What can i do to get more??
- Motor swap help
- Accord o2 sensor in Integra?
- EG Hatch w/ GSR motor won't start up. HELP!
- B17A1
- need some help
- used car help
- Anybody know if a set of 15X6.5" +27 offset work on a 94+ Integra?
- oil on my spark plugs???
- snaped a few pics of my whip today tell me what u think
- Strange squealing noise coming from my GSR?
- New clutch squeaks? Is this normal?
- is there an aftermarket cat that will past emissions/smog and not give a CEL?
- My new teg
- Rims
- Hello everyone
- gsr timing
- b16 SIR engine into a 94 GSR
- Busting Axles??
- rims
- flushmount decklid spoiler on DA
- Break Peddle Only Sinks When AC is On.
- 92 gsr shaking under half throttle acceleration??
- Who has the integra with the ITR style cluster???
- help brake shaking like crazy
- HELP AC PROBLEMS
- LS- Vtec------?RS-Vtec
- no horn, frustrating the crap out of me
- Problem with GF's DB8, windows wont go up or down, and mirrors wont move?
- JDM ITR cluster in 94 RS wont operate
- Rocker Arms
- need help (searched)
- skunk2 manifold over gsr manifold with a few extra mods....what types of numbers can i expect???
- OBD1 vs. OBD2 alternator plugs - which is which???
- What's louder: APEX N1 or Buddy Club ProSpec I?
- UKDM Parts
- funny clutch vibration/roaring noise.....wtf?
- Help with value of my low mileage Integra GS-R......please. :)
- part number?
- Help P28 chip?
- OMG SUPER JDM XSI TURBO MANIFOLD!!!!!
- oem style rear valences
- Car stopped......
- $2000 to spend
- b16a3 head onto b16a2 bottom end
- damn passwordjdm 3 point strut bar
- help msd installation 6al
- CABLE TRANNY:shortest gear ratio?
- Car overheating in traffic, but reseating relays and fuse solved it, what could it be?
- 5 lug conversion...
- Video - Whats goin on with my B16A teg? Knock sensor ECU limph mode?
- Need Help for an LS
- good exhaust?
- Difference b/w JDM LS and USDM LS motors?
- GSR with no sunroof?
- jdm integra headlight question
- ls LSD or stock b16 tranny?
- never seen these
- Skunk 2 springs on a 90 DA
- How far can i raise up my stock DA exhaust?
- People that have used the Summit racing battery relocate kit.
- keyless entry help
- GSR SMOKING
- Engine building recommendations
- maybe a dumb question.... but please help
- Damn My Tranny
- Type-R shift boot in a DA6?
- what color is this wire?
- For sale integra RS
- obd0-obd1 conversion dizzy problem pics* searched**
- Fans for Fluidyne radiator
- Acura Integra GSR exhaust system
- weight?
- Will a 97 gsr stock muffler fit a 99 gsr?
- Where to get RHD Integra parts?
- NA GSR setup: 180-190 WHP possible? Check it...
- Building B18A1 need shop
- maint req. light when start up
- fog lights
- Can someone carfax this for me? I'll pay
- Noobish question.
- LOST INTEGRA KEY AND ALRAM!! HELP!
- New radiator wont fit
- Apex World Sport 2 exhaust
- Pics of Greddy SP2 and APEXI WS2 PLEASE!!!
- rear disc brake help
- Hood Release Relocation
- Not passing smog do to NO levels to High!!!!
- WHICH IS BETTER? AUDI OR ACURA
- why?????
- help car warm up like crap
- How do I clean my OEM GSR wheels??
- Clutch Master cylinder?
- DB8 Exhaust Systems
- vtec isnt working right.
- check engine light
- is my flywheel going
- Rev Limiter?????? Impossible!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!
- DA Thin side moldings??
- alternator sp sensor?? integra
- RE: SNL* Twin Loop Muffler 2.5Inch
- advise on purchasing a used engine from a wrecked GSR
- Outer CV boot change
- New Clutch Needed, Need Some Advice
- Remote Radar Detector Installed - Pics
- EF cage, fit in DA?
- gsr blades w/ tire size
- NEWB QUESTION
- pics of your gsr motor
- what kind of suspension?
- My exhaust piping is cracked :( could that be causing a low idle?
- skunk2 slip over coilovers
- quick b20 question..
- anyone with da have hard time finding pcv valve?
- ecu you problems!!!!
- Gsr horsepower
- Fuel/air Reason Why I'm losing Gas w/ 95 LS b18b1
- maintenance required light(and yes i did a search first)
- Stage clutch
- G3 fuel pump replacement.
- profab
- will a DC armrest fit in my DA?
- o2 sensors on obd1 LS
- side marker question
- GSR REPLACEMENT PISTONS
- Noob to H-T Going through de-rice
- buying a 94 GS-R, was stolen, need opions ASAP!!!
- My Integra nearly stolen at Mall of America this weekend
- ABS booster on non ABS DA, will it work?
- Buying B18b engine in So cal
- planning to rebuild my turbo 00 gsr
- cheap cams on ebay?
- H22A in my DA
- How to adjust IDLE on 00 GSR?
- Short shifters
- Oil in Spark plugs.
- Gears Really hard to go in
- GSR cam upgrade
- p72 ecu on a b18c5
- [FAQ] Purchasing blocks only?
- my DA blower motor or ac system went, I need help with the blower motor.....
- GSR Problems after mods
- Pics! Oil inside where spark plug is..??
- obd2 to obd1 conv. for hondata?
- Good quality HID Kit
- honda access window visors
- overheating...
- HELP w/ EXHAUST - T1R or SPOON ?!
- please help
- car fuses
- tach install help
- Hondata Tuning
- torque patterns for b20
- 2009 Civic Turbo diesel
- Heat Shields
- Getting ready to do a trans swap, question about VSS
- New to Honda-Tech
- are other b-series crank pulleys same size as gsr?
- How much boost without cylinder sleeves?
- sideskirts question
- obd2 to obd1? pass or fail?
- NEED HELP TAKING OUT FRONT STUDS ON A 96 GSR
- ABS Relay(s)?
- trouble with removing axles on a 91 integra ls
- upgraded the brakes
- Need help ASAP please!
- Help me w/ my oem LSD install!
- engine knockin
- cable tranny question
- Help please, Door Lock Diagram NEEDED!
- fmu or injectors
- another skunk 2 lowering spring question
- turbo on aluminum motor?
- could i add my cams if....
- need help no fule
- Skunk 2 springs
- does anyone know where the o2 sensor's located at on the 96 Integra LS ??
- DA Integra with hydraulic tranny, where to get mount? Running hydro master and all...
- my antenna motor is broken
- pass 7k?
- Already searched but found no answer..(What's the + and - on a sidemarker)?
- is my tranny mess'd up? 94 gsr!
- gs-r future??
- abs light
- How do all u install ur sidemarkers?
- 95 acura
- hesitation when i give it gas need help
- timing belt b18a vs b18b
- ACL bearing
- reinstalling A/C....
- NO fuel and no spark
- Integra LS Automatic Antenna
- 92 GSR QUESTION
