View Full Version : Acura Integra
- G3 hatch and G2 hatch same size?
- B-Series (S1) countershaft locknut size??
- How to plug ITR wing hole?
- type r lip with these skirts
- Nitrous install question
- stock hole in the trunk
- Tein suspension?
- gsr conversation....
- rear wheel drive conv?
- 4Dr Type-R spoiler install
- help car stoles in rain
- FINALLY! A video of my Fully built 62404 Stage 3 ALL MOTOR LS
- need help
- got in wreck, airbags didn't deploy?
- Mugen Micro Mesh Brake lines....
- good place to order jdm 5 lug suspension?
- prepping bumper already painted
- Should I trade b18c1 for a 99 jdm b18c-r long block
- ******* trade SI rims for ROTA SLIPSTREAM **************
- LS/GSR VTEC vs GSR???
- How do you remove the oem radio out of a 1990 integra?
- how much for a itr wing
- 90-91 integra front bumpers the same as 92-93????
- question about converting my ls into a type R
- eibach and skunk2
- heads up I'm selling my stock type r exhaust
- will this work with ITR swaybar?? (pics)
- whats an ECM
- obd1 ls header on obd2 gsr?
- Suspension or LSD first?
- 92-93 integra: fuel probs!! motor is flooding-too much fuel=car wont start!! help
- hydro lock question
- Engine size
- Cam Question- big buildup- Will CTR cams work in my gsr. have stage 2's already
- Poly Motor Mounts *BAD*
- mirrors
- question on throttle body gasket..
- 98-01 taillights
- ABS Unit Location???
- gsr
- Auto GSR's
- Interior Dyeing?
- Is this a good deal?????
- 180,000 mls. on an 91 LS, is it worth doin engin mods
- Can somebody help me step by step.....
- where to mount tires in maryland
- steering wheel fitment
- snaped valve cover stud please help ASAP!
- WHAT WATER PUMP FOR A GS-R???? HELP! WTB: STUFF LOOK!
- Head Swap, what needs to be replaced
- where should i spend my $ -quick p0ll-
- Paintless Dent Removal in Toronto
- New member, couple of questions (gs-r nitrous)
- A/C mount broke, crap! engine mount inserts or need replacement?
- Trying to eliminate a few possiblities
- Do leather integra's have leather wrapped e-brake handles?
- Will shocks and string from a 89 CRX Si fit in a 96 GSr.
- Do I have a bad Pr3 ECU?
- Am I crazy?
- Itr Cams with Nos?
- Need Help....Ignition timing on n2o
- Sorry for such a dumb question, but...
- h22 teggy in the making
- why did you put turbo?
- Stupid question
- evo vs. magnaflow
- 95 GSR Turbo or N/A???
- need upgrade path suggestions for a 98 LS.
- Anyone have any engine heads they want to get rid of?? Or sell very low??
- where to mount zex purple box on gsr?
- Cam shafts???
- Well, that's a problem
- ITR lips for $124???
- climate lighting problem
- type r exhaust
- changed brake pads
- Short circuit? Wiring experts please read!
- where to mount nitrous and purge switches?
- Oil plug/bolt - size?
- Traded my wheels for a pup............
- 4-1 or 4-2-1 for integra LS?
- 13 sec. Gsr is it possible
- you guys really need to check this out..
- camber kit question?
- Want to Buy a Cable Tranny
- 95 GSR STOLEN *SO CAL*
- Just ordered the Apex'i N1 Exhaust!
- help needed! rattling sound under my car
- compression ratio on gsr with ctr pistons
- compression ratio question
- Got free US itr stuff for my gsr
- JDM integra front end
- JDM Integra for Sale
- Engine Swappers / Experts... Advice Needed
- Does anyone have the Field Vtec Controller Instructions in English??
- Exhaust question
- 01 type R oil pump on 94 gsr block....
- DA Mounts. 90-91 ~ 92-93. Difference???
- Header?
- 5-Lug Brake Lines
- Replacing Brake calipers on an ABS Integra
- GSR wheels
- visual differnce between b18 and b16?
- Code 20 fix
- headers
- integra specs?
- JDM DC2 MOMO Steering wheel horn
- How do I stop my cd player from coming out??
- which carbon fiber interior pieces fit in a DC2's interior
- axle replacement ?
- autometer water gauge
- Car bogs down in first gear! please help
- are 97 headlights made of glass or plexiglass
- Opinions needed - Paint question
- after regulator install
- gsr and ITR flywheel specs
- Test Pipe Install
- Gotta question about the Catalytic Converter!
- anyone running USDM ITR pistons in a b18c1?
- HELP! my brake pedal goes down to the floor!
- Free AEM Intake!
- spark plug help!
- i/e/h question
- It took ripping out the interior but.....
- what will a chip do for a turbo integra?
- Over heating problem, how drastic is a coolant leak
- Tranny question. 5 speed ls
- fuel pressure regulator
- anyone with 95 ls?
- size
- what should i be pulling w/this setup
- will factory bumper lenses from my 98r fit a 95 gsr
- tranny gearing question
- Messed up rear brakes, dragging!!!!! HELP!!
- To all of you that have had your Teg' stolen.
- Can you resurface a Clutchmasters lightened flywheel?
- I got a hand-me-down from my brother
- I found some thing in my intake tube?
- price for cam install and valve lash adjust?
- Type R motor in 00 gsr: Wiring Question
- acura integra gsr 2 door for sale
- recommend me a dual tip exhuast
- where can i get a bsq/ beaks kit
- difference in the head on the auto and manual ls
- b18a1 LS flywheel specs
- Holy crap, I think I found it...
- INTEGRA CAMSHAFTS
- Just installed JDM ITR 4-1 and cat
- Will the guy that was suppose to sell me the gsr throttle body please im me.
- Header to exhaust question...
- Where to buy FPR gauge?
- Thinking about getting a 92 Integra LS, need opinions please...
- What caliper/pad combo to use with Brembo blanks?
- Will these all bolt up together? (exhaust Q)
- Weird VAFC PROBLEMS - SEARCHED - Bet ya never heard this one.
- Help ! Koyokogen lug is stripped & key is crap !
- JDM ITR Front
- rear sway bar for g2?
- G3 Teg bumper lights question
- compression test results.....
- over revved bent valves possibilty
- Lifespan/Durability of Camshafts (oem and aftermarket)
- Az peeps***STOLEN ACCORD***
- recaro srd
- is my cat shot???????
- ls turbo
- ls gearing
- A head swaping question
- How to mount Harnesses on 3rd gens?
- which cam shafts for street and POWER GAINS
- please help me identify ECU....
- a bug in my overhead lights!!
- Test pipe problems?!
- JDM B16a with 92 LS Tranny
- any one here in colorado
- gas tank
- white smoke
- Hose to PCV valve?
- Newbie needs info for Integra LS
- JDM H.I.D headlight bulb
- Turn Signal Relay
- show off your carbon fiber lips/wing/side skirts please on yout eg
- i need help with a LSVTec
- exhaust
- GSR Motor match to LS tranny?
- what could this setup yield?? GSR
- Ebay water pump
- JUST INSTALLED JG MANIFOLD
- spongy brakes on JDM DA6
- Want to Buy: Cold Air Intake
- b17 tranny different from b18c1 tranny? Swap possible swap?
- NEED QUICK ANSWER ON 4 LUG WHEELS
- tein SS settings and camber?
- fiber image hood
- question on gsr spoilers
- lemon law.. what does it apply.. (friend had tranny changed 3x under warranty)
- GM Syncromesh, regular or friction modified?
- Have 1989 Manual or Intimate Knowledge?
- vtec question
- Skunk2 Camber Kit Problems
- Slanting s2k antenna
- ITR cams with GSR cam gears?
- which exaust should i get need help
- Gsr 4-door or gsr 2-door. I need to make a decision
- ITR sway bar install question
- 96-99 greddy turbo kit
- passenger side mirror not working!
- Why is my car shaking?
- HORN Doesn't Work! Fuses OK, what else can it be?
- Removing pulley
- 98-01 Integra Rear Hatch
- Test pipe and fuel mileage.....
- $2200
- brake problems . . . pads ..
- Apex'i N1 & Apex'i Dunk catback Piping...
- Anyone have pictures of a apexi n1 on 94-01 integra??
- Grounding Wires... worth it???
- I need new o2 sensors, what's a good brand an place to buy them?
- Rear hatch glass!!!
- Torque value for exhaust collector nuts and flange nuts?
- What Lip is this?
- NEW JDM TOYS
- stupid question, broke one of the emblem prong holders on my trunk
- KYB AGX on 2gen tegs..
- Clutch Gone. Replacement/Warranty?
- is this a good deal
- Big thanks to tornactive.com
- GS-R fuel pump on 91 RS with b16
- Looking to replace valve train and retainer?
- underdrive pulley question
- Drive Shaft, torn CV boot **Question**
- 1.3 drop
- what to do with front tow hook
- Problems using ITR SWAYBAR with ITR LCA... experts wanted!
- Worst Oil Change Ever!!! Weirdest too!!!!
- crappy night
- Show off your 4-doors! I need great setups for 4-door integ.
- ITR springs versus eibach pro kits
- QUESTION
- question about headlight removal in 95 gsr
- Want to buy GSR motor
- Pictures needed of 98 RS Prop Valve and MC
- itr rear sway w/ neuspeed rear tie bar
- I have an RSR b-pipe and I was wondering if I can put back the stock Type R muffer with an aftermark
- jdm headlight bulbs
- LOL, No wonder why domestics suck...
- itr front lip install
- Help! How to remove the Thermostat housing nuts on G3 Integra.
- will itr rods fit on gsr crank?
- Seats
