View Full Version : Acura Integra
- SS Brake Line Install
- just wondering...b16-->b18
- Goofy Q: Can you center mount a baby seat in an '01 Integra sedan?
- HIDS for teggy
- Hi
- NEW engine? or Build up on Bolt-ons? this is bone stock...
- Getting GSR tranny swap and...........
- wierd metel clanging noise
- Spring Autocross ---> Time to choose my suspension!
- 205-50, or 195-55?
- cat removal gains???
- bypass coolant hoses to iac valve?
- Hondata Question
- power steering
- RSX Seats in Integra
- front camshaft seal
- Mid pipe question
- motor dying??
- who steals bumper lights?!?!
- Need Opinions On this (Security Related)
- Cosmo racing intake?
- susepension prices?
- Exhaust And Headers -- Sources Of Info
- side skirts
- CARJACKING in Bay Area
- Radiator problem
- will a stock axle back section bolt to an aftermarket mid-pipe?
- MIL Codes??
- anyone had this problem???
- rim problems!
- gsr weight
- Bosch +4 spark plugs
- car vibrates abnormally.
- Old BAAE Meet pics...
- watch ur head
- 98 GSR babied
- Simple yes or no clutch b18a/b
- 2000 Gsr Head on a 1995 GSR Block
- HONDATA VS V-AFC
- Life Time wheel alignment for $99
- Release Fork Spring Question????
- Teggys are so nice.
- upper mounts for springs?
- When do distributors normally break?
- Sparkplug wire keeps popin off distributor, why?
- Neuspeed springs?
- Automatic Transmission Slipping?
- RSR Ex Mag catback exhaust
- Will an exhaust that fits a 2dr, fit a 4dr?
- loosing more power FWD or RWD?
- need pics of aem fpr on a stock fuel rail....
- any particular paint i should use
- Where to Buy a Fujitsubo RM01A For the GSR
- Cleaning CAI filter
- Irritating Main Bearings...
- Where to get these parts!
- Where's my F@$KING car?-----Thats right it was stolen.
- bell housing
- The big brown van came to see me today and left a present
- how to get the most out of my B18C1
- need help with drive shaft
- JDM front end install
- SPOON N1 XHAUST in a DA9
- Swapping front and rear springs on a Tein SS coilover set.
- how many bulbs are in the gauge cluster & climate control
- opinon on ls/vtec
- what Hondas use same thermostat?
- tightning valves?
- disableing door locks...
- Where is patdemps?
- Toda Spec B Cams in a b18c1
- AEM CAI help
- Shipping a itr lip?
- car just shut off...???
- Which header would you choose?
- dropzone coilovers
- 2001 Owners - Asking for pictures
- My dash reflects onto the windhield like crazy. Im blind!
- LS non vtec have NA potential?
- New DC2
- Any good dyno shops in socal?
- safe to use a sock as a VERY temp air filter?
- anyone with 7.5'' wide wheels?
- anyone heard of jdm jama wheels?
- TEG problem...
- Rasing Compression
- jdm front end
- Weird Spots on Inside of Windshield?
- I'm considering purchasing a gsr with tranny problems...
- so is the suspension from a g2 swapable onto a g1??
- Auto transmission interchanging - CRV vs. LS?
- Civic style radiator in a G2 help...
- ACT 4 PUCK
- integra parts for sale!!!!!!!
- Tokico Illumina's
- Some pics nerdsports took of my car....
- b20 vtec question
- blown ls @ 115k
- anyone know where the hang out spots are in southern cali?
- VAFC question
- 5zigen canaster internal rust*
- lost performance after cam install?
- Driveside headlight leak?
- How long will the G3 Integra remain in style?
- is 13.5s possible with this setup
- Back from the dead!
- CAR WILL NOT GET SPARK !!! please help
- Help!!!! Brake piston won't go back in!!!
- B18C1 + JDM ITR Piston + JDM CTR Camshaft
- My early 60k tune-up plans, and a few Q's
- Looking for Euclid
- Good Exhaust shop here in Los Angeles area?
- ecu chips
- 1990-1993 INTEGRA (DA) MANUAL TRANNY MOUNTS PICS WANTED!!!
- thoughts about venom 400 module
- clock and radio not working!!!
- Need help w/catalytic converter on a GSR
- diagnosing weird oil leak (pics inside)
- any advice before i...
- What's THIS part called?
- anyone want to go in on this?
- Dyno Tune Questi0n
- obd2 to obd1 conversion
- Greddy Turbo kit Q
- civic 97 it the same iacv of the gsr 2000?
- A MAJOR INTEGRA QUESTIONS FOR YOU SMART ONES!!!!!!!!!
- .035 milled head & PR4 pistons for LSVTEC
- Good Exhaust Shop Needed in Northern Virginia
- RSR GTII exhaust help!!
- Help me with this....
- How much Boost can I run?
- Where could I find replacement nuts and stud's for my valve the valve cover?....
- ls/ gsr conversion
- Installation of Walbro in-tank fuel pump
- gm syncromesh, GM as in general motors
- -springs finally!!!
- Type R tranny
- Will this work???
- brake problems help please
- car fax please~!!!
- a type r lip on 98+ front bumper?
- finding 1993 Integra GSR
- Are 94-97 and 98-01 rear rotors the same?
- Pin in shift linkage while removing motor
- noooooo coolant is escaping! :(
- Is this my IAT?
- removing b-pipe. cat bolts rusted.. what should i do
- gsr spoiler removal
- What are these wires?
- Thought tranny grind was blown 3rd synchro...but was shift linkage prob?
- Pics of nice Integs???!?!?!?!?!
- help : how to install extended wheel studs (ARP)
- Has anyone ever hooked up power door locks in a RS?
- type r spoiler on gsr??
- Passanger window motor mess up
- How to Install a Camber kit...
- Teg was broken into (Puyallup/Tacoma, WA)
- Can u use stock seat belts with Recaro Srd seats?
- Im kinda new to this but... a conversion?
- Any one have custom exhaust done in ct?
- darn acura radiators......
- Does anyone have a picture of Integra with the optional wheels on?
- bolts rounded off from collector to cat. What the hell do I do?
- Jdm Integra Hid Bulb went out.....
- is it time for me to change shocks, what do you guys recommend
- Any Mechanics here?? PLEASE HELP!
- Thermostat in my 94 Integra?
- Claying your head lights? Works great!
- Header install, nut locked and pulled stud out of the head! Help!
- Concerning vibration in the steering wheel
- Which header?
- Damaged fuse box
- found oil my leak!! help!
- What is there was an SMSP group buy?
- Car won't start - no spark
- DA seatbelt assembly on DC2 (Corbeau) rails
- Hood will not close after LSVTEC install.
- need a Part# for passanger-side front windshield lining
- Whats the difference(searched)
- Help! leaking oil from headers
- intake question
- Pics of the DA
- JDM b16 Cams in a b18c1
- stay with 98 integra engine?
- another idle problem(B18C-R)...I gave up...
- whistling from throttle body.. how to fix??
- Bigger Injectors worth the money?
- Anyone have nice Spoiler?
- Sea Foam: Review
- can you help me figure out my problem? *vid clip*
- i want to know my camber adjustment
- ABS Axles vs Regular Axles
- redline@6500?
- whats this black liquid coming out of my tail pipes
- I need true, honest opinions, and advice. Read please.
- Anyone wants fully exhaust system? out of 95 teg
- HELP!!! Car wont start???
- Air Bags
- '98+ tail lights fits '94-'97?
- best IM and TB??
- how to put a gsr head on a 97ls how do i do the wirring
- Possible problem with ECU
- N1 vs. Ws
- The Honda song
- Need step by step instructions on Skunk IM
- '03 Civic Si rear rotors on 4-lug Integra
- What do oil catch pans do?
- Kumho Ecsta Mx
- best camber kit?
- Noise when braking
- gears/tranny questions
- How many miles on your 5-spd trans?
- skunk 2 intake manifold??
- Possible to fix a bent steering column?
- Aluminum VS Chromoly flywheel.. Pro's & Con's..
- need your opinion guys.
- JDM 4-1 '98up ITR header question
- what kind of clutch for a turbo gsr
- seat belt getting stock
- Help needed, shuddering, extended starts?? Long drive soon, help asap.
- radiator question...
- Tranny problem please help ?>?????
- Quaife and Possible Final Gears
- new to honda-tech
- Will headers designed for a 97+ Integra Type-R (US MODEL) fit on a 94 GS-R? Direct fit or not?
- air fuel adjustments?
- Crap... My exhaust finally rusted through... :(
- Gsr fit on ls with modifications?
- Opinion on how much my car might be worth..
- compression results..
- Apexi Dunk Exhaust?
- Moisture in Headlights
- Free Stuff
- Power mirrors don't work!
- Don't want to use the Acura Dealer here in N.Y.
- Smashed my front, need used parts
- 97 integra gs...temp guage is going nuts
- how do i know what year my p72 ecu is?
- seat compatibility between DA & DC2
- stupid lemon....i need help!
- Where to buy cheap OEM replacemement parts? Just melted a tailight...
- installing jdm headlights
- is the front tranny mount important?
- IAC Bolt torque
- b16 swap
- OUCH...distributor seized up!!!
- gay or not gay?
- omfg!!
- rear 1/4 panel
- AUDIOBAHN
